Old 12-21-2017, 04:47 PM   #15
Lust
Drives: 2017 Subaru BRZ
Originally Posted by Iceman View Post
AD052 are WAY more expensive than Cup 2's on stock size(14X euros for the Cups against 2XX the A052). I was considering those for the future but after watching that review video, i would not consider the Yokohamas at all, i expected better performance.
I'm on my way to my 4th set of Cup 2's(always on stock size) and i can't think of a better tire for the money. Period. I use them all year and everywhere, and it rains a lot in my area.
PS: AD08R's always get great reviews but i can't see what all the fuzz is about, had those on my 205 and i wasn't impressed. At all. Pretty decent on dry tarmac, and that's about it.
PS2: If you can afford them and want the very best, take a look at the Pzero Trofeo R. Available in 205 or 225 but well worth it. Better than the Cup 2 all around, but at the expense of a shorter life i suspect(i have these on another car but they're still "new").
PS3: yeah, i'm kind of a tire geek
How did you not like the AD08 R? Are you sure you’re getting them up to the proper temperature?
Lust is offline   Reply With Quote
Old 12-21-2017, 07:27 PM   #16
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
AD08R like 30 PSI hot too
Surok is offline   Reply With Quote
Old 12-23-2017, 08:00 PM   #17
Iceman
Iceman's Avatar
Drives: GT86
Originally Posted by nikitopo View Post
The issue is that currently the PS4S is targeted only to higher end cars (with 19'' wheels or larger) and it looks that they left the rest with the PS4 tire. The latter is inferior even to the AD08R tire. They are saying to have around a 90% of the dry grip.
Correct, that's the issue for now... But the regular PS4 is a very capable tire on dry, and excellent on the wet.
If you think about the current range and how good the PS4 is in smaller sizes, and having the Cup 2 for those of us who want the very best dry handling, having 3 sport/performance (or 4 if you add the remaining PSS sizes) tires makes little sense.
Originally Posted by churchx View Post
nikitopo: yes, PS4S very probably will be more competitive/better .. but is PS4 that bad of choice? IIRC at least by Michelin data it's capabilities were reported as being on PSS level, with slight loss at just one of dry track tests, but slightly better everywhere else, especially wet. So you get almost same as PSS, but at even wider sizing choice and better wear (also important thing, even on track, as can reduce spendings on wearables). If PSS are still considered as competitive choice, why not non-S MPS4? Even more so for dual-use tire choice. MPS4S most probably will be better, but until they are available at R17 size, i'm still considering getting non S-es for next season in spring.
I agree. PS4 is a good substitute for the PSS in small sizes for most users. You loose a bit of dry track performance but if you really care about that, you'll go PSC2.
Originally Posted by Icecreamtruk View Post
You said it yourself, slightly less than PSS dry grip. PSS dry grip is already shit compared to real performance tires. If you think PSS have grip, you havent driven on a performance 200TW tire or even "cheater" tires (RE71R and friends). PSS is an exellent tire for the rain and daily drive, nothing more, it cannot handle the heat at all and the sidewalls are made of cardboard.
PSS's dry grip is really good, even now that it's a bit outdated. And they last long even if you use them on track.
Obviously you can't compare to more track-oriented tires, but you have to keep in mind it is a road tire. And a really good one.
I don't know why, temperature/pressure wasn't the issue. Perhaps i just had really big expectations after all the good words about them. Dry handling was good but they lasted less than 10,000km on a car weighting less than 900kg, which is quite absurd considering i am a smooth driver. Wet handling is not very good because of how hard the sidewalls are, which also had a big impact on ride comfort.
Youtube channel: https://www.youtube.com/c/ÓscarFaraday
IG: @oscarfaraday
Iceman is offline   Reply With Quote
Old 12-23-2017, 08:27 PM   #18
churchx
churchx's Avatar
Drives: 2014 GT86
Iceman: if AD08R lasted only 10Kkm, now imagine how long cheater tires like RE71R might last . If one of pros of Essex BBK kits was hailed cheaper & longer lasting wearables (much thicker pads of common shapes) that let BBK to pay-off soon, then imho many underestimate tire wear importance for self-financed track day enthusiasts.
Old 02-24-2018, 08:46 AM   #19
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
A052 vs. RE71-R
[ame="https://www.youtube.com/watch?v=yPW2UxP0pt4"]A052 VS RE71-R - YouTube[/ame]
Left is the RE71R and right is the A052.
A052 2018 1/20 2'07"97
RE71R 2017 2/18 2'08"36
Old 03-12-2018, 10:21 AM   #20
ajc209
Drives: GT86 Cosworth
Ive been running AD08Rs for the last couple years.
Ive done around 8km road and 6 or so trackdays.
They have around 3.5-4mm tread left and the last trackday it was wet and they were terrible. i couldnt get any heat and they just slid about. A friend on PS4s had alot more grip. id say 20seconds in a lap.
Is it possible my AD08R have be heat cycled out? They are about 3 year old (been on my car 2 years) and have been used in two winter and recently in sub zero. One day it was -6C and snowing.
I love them i nthe dry and these A052 caught my eye as they have an A rating for wet grip.
ajc209 is offline   Reply With Quote
Old 03-12-2018, 10:35 AM   #21
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I have the same issue like you and I would like to have a bit better wet grip. It is also my 3rd year with the AD08R tires.
It is true about the wet grip rating of the A052, but on the other side the Yokohama global site(*) provides the rain symbol only on the AD08R's. So, I am not sure who is correct and who is wrong. Someone that maintains the Yokohama site or the European testing agency? In general the A052 tires are quite expensive and still don't have many reviews. I was tempted to test them, but it is a lot of wasted money if their wet grip is not better.
(*) https://www.yokohamatire.com/advan-tires
Old 11-30-2018, 04:17 AM   #22
vgarcin
Swiss Alps Driver
vgarcin's Avatar
Drives: Toyota gt86
small bump on this old thread.
I have purchased a set of A052 for my car, for track purpose only. So far, i've tested them only on the wet.
They're very good on the wet. Best tyre i've purchased being honest under those conditions. I was way faster than a lotus A380 cup with PS cup2 at this time.
vgarcin is offline   Reply With Quote
The Following User Says Thank You to vgarcin For This Useful Post:
nikitopo (12-02-2018)
Old 11-30-2018, 09:35 AM   #23
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
What have your previous track tires been?
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
Old 11-30-2018, 09:44 AM   #24
venturaII
venturaII's Avatar
My Japanese is lousy, to say the least. Still, entertaining to watch...and a direct comparison of RE-71 and A052 on the 86 platform, though in larger 245/255 size, from what I could see. He was trying as hard as he could to keep up with that FD RX7..lol. The results at the end clearly show the A052 as a direct competitor to the RE-71R on track, though I don't know what the test conditions were...cold tire? Warmed up and then a single hero lap? What are they like after 20+ minutes? I see mention of 3 and 6 lap measurements, but I don't know what the ratings were.
[ame]https://www.youtube.com/watch?v=oAc0ew8vFKA[/ame]
Old 11-30-2018, 04:36 PM   #25
CSG Mike
CSG Mike's Avatar
The A052 is superior to the RE71R for raw grip and heat capacity, but cost significantly more.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
Icecreamtruk (11-30-2018), JeremyR (11-30-2018), nikitopo (12-02-2018)
Old 12-04-2018, 05:10 AM   #26
vgarcin
Swiss Alps Driver
vgarcin's Avatar
Drives: Toyota gt86
I have tested a lot of different compounds:
Federal 595 RSR
Toyo R888R
Yokohama AD08R
Michelin Pilot Sport Cup 2
On the dry, i'm running michelin slicks S8C
I have not tested the A052 on the dry yet, but knowing Yokohama, they should be quite good.
The Following 2 Users Say Thank You to vgarcin For This Useful Post:
nikitopo (12-04-2018), venturaII (12-04-2018)
Old 12-04-2018, 09:26 AM   #27
venturaII
venturaII's Avatar
If the extra grip and heat tolerance mean the A052 ends up being a more durable track tire than the RE-71, then a good portion of that cost increase is removed. Now, if I could only get my current set of tires to wear out faster..lol.
The Following User Says Thank You to venturaII For This Useful Post:
CSG Mike (12-04-2018)
Old 12-04-2018, 10:35 AM   #28
churchx
churchx's Avatar
Drives: 2014 GT86
Simple. Instead of HPDE try drifting
FS: Yokohama ADVAN AD08R 245/40/18 fungus Canada Classifieds 3 06-04-2017 07:07 PM
Yokohama Advan V105 Cope52 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 08-20-2015 12:10 PM
Yokohama Advan RSII Peeling jcat5150 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 24 04-18-2014 08:38 AM
Yokohama S-Drive? Advan Neova? OnionTou Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 07-10-2013 01:51 AM
