Old 12-01-2018, 04:56 PM   #631
spicyricecake
spicyricecake's Avatar
Drives: 2017 CWP BRZ Performance Package
Does this work with the 2017 OFT v4 tunes?
I skimmed through all pages and I dont think anyone was able to provide the values to make this work only on aggressive up shift/downshifts.
When I was running a cobb tune on the 13 STI, I would get decent one or two pops during aggressive pulls. That's ideally what I want.
Would anyone be able to point me in the right direction to get that done, or has this not been tested? I definitely don't want the excessive pop corn noises..
spicyricecake is offline   Reply With Quote
Old 12-01-2018, 07:01 PM   #632
steve99
Drives: FT86
If you have ecutek and manual trans you might be avle to achieve pops on shifting by adding some extra ignition retard whan clutch down. I dont think that table is defined in opensource unfortunatly
Old 12-02-2018, 01:17 AM   #633
spicyricecake
I see. so this would only be for the pop corn effect on decel or off throttle, just a matter of how much pop corn. Thanks for the heads up!
Old 12-02-2018, 01:23 AM   #634
tomm.brz
Drives: brz 2017 hksv2
it is defined that table even in romraider, it is called Ignition compensation Map delta(clutch depressed)
Old 12-02-2018, 11:17 AM   #635
steve99
Drives: FT86
would not pop on decal unless you pressed clutch. The table controls ignition retard on pressing clutch reliative to manifold pressure.
NA cars run about 25-30 degrees advance at mid to high rpm, so maybe try making the current values that are around 20 change to 30, but only at the higher manifold pressures like arround 1 bar ie atmospheric, if you change the lower ones used at idle car will likey stall at idle if clutch pressed. not played with this so be carefull
Old 12-02-2018, 03:24 PM   #636
tomm.brz
i played a bit with it and I tend to lower it overall, the first 4-5 rows i put "5", but i wasn t looking for spontaneous pops on gear change
lowering it will make the revs during blips with clutch depressed very reactive so yes be carefull if you try to lower the first rows
I will try to make the change too as steve suggested, higher value on higher map values to see if it pops during gear change
Old 12-05-2018, 06:59 PM   #637
Harry123
Drives: White brz
you will need to download my def then alter the internal calid to your calid in def, in two places.
this is assuming your using V4 tune for 2012-2016 car and using the appropiate auto or manual def
Would the 2 places to alter the Calid be where it says <xmlid>ZA1JA01G</xmlid> and the other <internalidstring>ZA1JA01G</internalidstring>
i have a Calid of F00C
Thanks
Harry123 is offline   Reply With Quote
Old 12-06-2018, 12:33 AM   #638
steve99
Drives: FT86
Thanks
Yes
Old 12-07-2018, 03:02 AM   #639
ohsanny
Drives: E85 Powered 17' BRZ
Hi All,
I was wondering if anyone has been able to achieve pops on neutral.
On my current setup I can get reliable gunshot backfire when down shifting to 4-5k rpm.
I can also pop when I'm in gear with clutch in reving while above speed. But I can't figure how to get it to work on neutral. Doesn't work with neutral clutch in or out rolling or not.
Also I am achieving flames with a stock FP, I've shot a few blue flames from the back.
Setup is --> 2017 BRZ Premium:
Tomei UEL Catless
Invidia N1
Is it also possible to have a launch control set at my 4-5k rpm and have those gunshot blasts continuous Like dem 2step supras woo! I don't think its possible as its on decel.
ohsanny is offline   Reply With Quote
Old 12-07-2018, 03:03 AM   #640
ohsanny
Oh and I'm running on E85 ^^
Old 12-20-2018, 01:08 PM   #641
Toyota John
Calle Atun
Drives: 13 FRS, 93 Mr2, 85 ae86
Doesn't look like some of those fuel over run table are defined in ECUTEK. Maybe in the pro version?
Toyota John is offline   Reply With Quote
Old 01-11-2019, 11:38 AM   #642
chromes
Drives: BRZ Ts
Just wondering, is it possible to get these ''exhaust pops'' on gearchange (upshift)?
chromes is offline   Reply With Quote
Old 02-19-2019, 08:56 AM   #643
tomm.brz
i d like to talk a bit about those pops are safe or not
the ecu puts a limit on the negative timing achievable, and that limit is -20 (you can change it but i dont think many tuner change this)
let s then see at a Euro restyling car cold start... almost 2k rpm and timing of -19, independently of the engine load, with an afr that tends to the lean side
Now the pops can be achieved already by putting the timing to -9 at just very load engine load
So why is -9 of timing to make pops dangerous and the cold start at -19 not? is it because of the temperature of the header that is colder on cold start and hotter during cruising/popping?
Old 02-26-2019, 08:49 AM   #644
alchemy
Drives: 86 GTS 2015
Has anyone gotten this to sound good with just catless headers (UEL) and rest of exhaust stock? Currently running Tomei UEL catless headers + stock catback and tried -15 in 0.15 and -6 in 0.20 and I could consistently get pops after driving around for an hour but it only sounded like light popcorn/my car breaking down. I would really appreciate it if someone knows how to get some nice sounding pops with this setup! Thanks
And yes I did read through all 46 pages!
alchemy is offline   Reply With Quote
rom tuning for pops and backfires andrew5826 Software Tuning 110 12-23-2016 04:39 AM
First romraider defs are up jamesm Software Tuning 95 01-13-2015 05:29 AM
Transient Ignition Retard Tables from RomRaider Ralph Spoilsport Issues | Warranty | Recalls / TSB 31 05-24-2014 07:48 AM
OFT-Help with Romraider/FFS and Launch Control-issues continuecrushing Software Tuning 9 04-17-2014 11:07 PM
Possible backfires Bg8780 Engine, Exhaust, Transmission 0 05-22-2013 02:12 PM
