go_a_way1
Old 11-23-2018, 12:02 AM   #3935
deku
Drives: 2017 subaru brz red, 93 FD RX7
Anyone run Michelin X-ice 3 215/60/r17's? wondering if theyll fit with the performance package wheels.
deku is offline   Reply With Quote
The Following User Says Thank You to deku For This Useful Post:
Leonardo (12-18-2018)
Old 11-23-2018, 09:33 PM   #3936
Leonardo
Country Boy 4 Life
Leonardo's Avatar
24.6" is stock diameter. A 27.2" 215/60/17 is WAY to big.
Stock size is what I'd suggest. If you want taller, a 205/50/17 or 225/45/17 would work too.
I LIKE TIRES!
deku (11-24-2018)
Old 11-24-2018, 06:58 AM   #3937
churchx
churchx's Avatar
Drives: 2014 GT86
Also, as x-ice3 was mentioned and it's apparently winter tire, i suggest for winter choosing narrower tire, of eg. 205 or 195 width.
deku (11-24-2018), Leonardo (11-24-2018)
Old 11-24-2018, 01:01 PM   #3938
Leonardo
Country Boy 4 Life
Leonardo's Avatar
There are no 195/50/17 or 195/55/17, so unless OP goes to a 16, a 195 is not going to happen.
I LIKE TIRES!
deku (11-24-2018)
Old 11-24-2018, 01:59 PM   #3939
deku
hmm ill have to return them then. i found some blizzak ws80s today, 215,45r17. thanks for the help guys
Old 12-14-2018, 12:34 PM   #3940
MHecko
Drives: C7P Gt86
Hi, can i fit on stock gt86 18x9J et40 (225/40r18)in front without modifications? In future I want lowering spring 1inch drop, thanks
MHecko is offline   Reply With Quote
Old 12-14-2018, 01:05 PM   #3941
Vital
Drives: 2015 BRZ
Yes on stock there will be no issues maybe some poke in the front though. I dont think there should be any issues after lowering 1" either.
Old 12-14-2018, 01:17 PM   #3942
MHecko
Drives: C7P Gt86
Thank you so much i thinked especially inward side from suspension, after lowering to rims not inferere to spring.
Old 12-15-2018, 01:41 PM   #3943
oec88
Drives: Toyota 86
A little help and advice needed
I just got Federal 595 RS-RR tires from my friend, the sizing is 245/40/R18.
So I am also looking for 18x8.5 +35 wheels, my ride has TEIN Street Flex with approximately 1 inch height drop. Currently running with TE37 +48 with 25mm wheel adapter, 215/45R17 tire size.
I wonder if my new setup will have any problems?
oec88 is offline   Reply With Quote
Old 12-16-2018, 02:21 PM   #3944
Vital
Drives: 2015 BRZ
Yes you will be fine also since you are using a 225/40 tire on a 9 inch wheel- just know that the tire will stretch
Old 12-16-2018, 02:27 PM   #3945
Vital
Drives: 2015 BRZ
You might have to be careful in the front im not sure if it could rub on the fender as a 245/40/18 is tall. If you can get a 245/35/18 size tire that would work better.
Old 12-16-2018, 03:17 PM   #3946
Rican_D
Rican_D's Avatar
Drives: Asphalt FR-S
Currently running 17x8 +45 wheels with 235/40. Kind of debating going 245/40. Right now the sidewall is flush with the rim. FYI stock ride height and enkei TSP6 wheels
Sent from my Pixel 2 XL using Tapatalk
Rican_D is offline   Reply With Quote
Old 12-18-2018, 08:52 PM   #3947
Killerbee
Killerbee's Avatar
Drives: GR86 / Supra MK5 MT / MR-S / Z4
EDIT -> Nevermind my post, I was talking about 18" not 17", my bad, sorry
Killerbee is offline   Reply With Quote
Old 12-18-2018, 09:07 PM   #3948
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Originally Posted by Killerbee View Post
I'd suggest to go 245/35/17 as this diameter fits better the factory diameter, thus your speedo will be more exact than with 245/40/17
However, you can do either.
Hey, whats up? This is totally wrong. 245/40/17 is the same diameter as the stock 215/45/17. Additionally, 245/35/17s do not exist.
I LIKE TIRES!
Killerbee (12-18-2018)
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
