Old 11-21-2018, 11:04 PM   #85
It's the same. The pedal dance is offered as an alternative to techstream.
Old 11-22-2018, 12:28 AM   #86
Legend@wheels
nenber
What is this world coming to?
o
to a real bad place Untill...
Legend@wheels is offline   Reply With Quote
Old 11-22-2018, 09:45 PM   #87
nico_rsx
Drives: BRZ 2017 Pure Red, MT
Originally Posted by danielmailrs View Post
Off topic-Yesterday i fully turned off the trc/esp.
And had a u turn on a wet surface and this light came on
how come?
As i know atm theres 3 options -vsc sport ,trc off with "abit of esp off" ,fully off on long press @the esp button.
So if it is completely turned off it wont turn that light on -or else this light isnt what im thinking it is .
Sent from my SM-G960F using Tapatalk
I was able to replicate this consistently earlier today (on snow/ice).
With the long 5 sec button press, I was doing 180 and donuts in a parking. The slip indicator light was never coming on no matter the amount of slip angle or wheel spin or complete 180 spin UNLESS I touched the brake. Every time I touched the brake the slip light flashed and the ABS kicked in. The reason for the ABS was probably because I was on snow/ice, but the light was not flashing if I was engaging ABS in straight line, only if I was drifting/sliding AND braking.
I didn't seem to noticed any nannies except the ABS, but the brake pedal was higher/harder than normal ABS, so maybe that was ice mode (especially since it was icy...).
nico_rsx is offline   Reply With Quote
Old 11-23-2018, 03:18 AM   #88
Legend@wheels
nenber
Kewl
And when the slip light showed up ,did you feel it intervening ?
Old 11-23-2018, 08:41 AM   #89
Tokay444
It also happens when a drive wheel leaves the ground.
The Following User Says Thank You to Tokay444 For This Useful Post:
Legend@wheels (11-26-2018)
Old 11-23-2018, 12:51 PM   #90
nico_rsx
Originally Posted by Legend@wheels View Post
Kewl
It's hard to say, as I was not going really fast and the ABS was kicking in because of the slippery surface. It seems there was no intervention except the ABS. But the brake pedal seemed firmer and higher than normal, so maybe ice mode.
The Following User Says Thank You to nico_rsx For This Useful Post:
Legend@wheels (11-24-2018)
Old 11-28-2018, 10:57 AM   #91
Tokay444
Hey Op, you pull the fuse yet?
