#351 |
Drives: 2014 Boxster S; 2015 Macan S
Does a spring replacement require the engine to go through a new break in period?
#352 |
#353 |
No
#355 |
Under 88
#356 |
Drives: Whiteout FR-S MT
It seems like my car is affected by this stupid recall. My car has headers and a tune, any idea if the recall will require a new tune or if they will hassle me due to the mods?
#357 |
No tune should be needed. Whether they hassle you about mods is going to be very dealer specific. I doubt they will have much concern over headers but you never know. The car is out of warranty by now anyway so it isn't like they can deny warranty work based on the tune at some later date.
| The Following User Says Thank You to Tcoat For This Useful Post: | AsianStyle (11-22-2018) |
#358 |
The Dictater
Drives: '13 Red Scion FRS
I would just make sure they know you have a tune when you bring it in. It's possible (though not necessarily probable) for them to try and flash it to something newer, which you don't want.
| The Following 2 Users Say Thank You to Spuds For This Useful Post: | AsianStyle (11-22-2018), Tcoat (11-20-2018) |
#359 |
Very good point. Since there is no issue with being refused future warranty work due to mods the best option is probably to be very upfront with the dealer.
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | AsianStyle (11-22-2018), Spuds (11-20-2018) |
#360 |
Drives: Nevermorange FRS
https://techinfo.toyota.com/techInfo...p/j12tofaq.pdf
So looks like the notices will come out late December. Has anyone ever had one fail though? I can't find threads about a dropped valve, nor do I remember any.
PRO86 | WTCC | STL
| The Following User Says Thank You to rice_classic For This Useful Post: | humfrz (11-21-2018) |
#361 | ||||
Drives: FT86
Was talking to a guy conbected with subaru in Australia. Aparantly because its safety recall they cannot refuse to do work on modified cars. However they could charge if the mods increase labour time or parts, or require you to possibly remove big mods like turbo before work is done. On any modded car they will aparantly require you to sign some form of waiver that any work they do on or arround mods is not covered. Aparantly they will not remove heads, just valve covers and spark plugs and then turn engine to TDC on each cylinder then pressurize cylinder with compressed air via spark plug hole to keep valves in place when replaceing springs. |
| The Following 7 Users Say Thank You to steve99 For This Useful Post: | AsianStyle (11-22-2018), Dadhawk (11-21-2018), humfrz (11-21-2018), notout86 (11-22-2018), Spuds (11-22-2018), strat61caster (11-21-2018), Ultramaroon (11-21-2018) |
#362 |
That's how I would do it.
PRO86 | WTCC | STL
#363 | |
Did he say if they'll be pulling the engine out of the car or are they going to struggle through it while it's in the car?
#364 |
valve spring issue?
Only problem is you can’t access the springs by simply removing the valve covers. The covers will expose the bolts for the cam subassemblies but they can’t be removed without removing the timing cover and chains. The subassemblies are also sealed to the heads with FIPG which needs to be cleaned off and reapplied. Avoiding the removal of the heads is like saving 1 hour on a 14 hour job. One of the documents said they expect to take 12 hours for the job. I’d be amazed if they can do it that fast.
You have to do steps 1 to 43 in this document to access the springs: https://demos.starbase7.net/t3Portal...056U900CX.html It would be cool if you could remove the valve cover and then go directly to removing the cam caps but the manual specifically says NOT to remove the caps first or risk warping the heads. Instead you remove the cam subassembly as one unit and then remove the caps. For this job you don’t need to remove the cam from the subassembly so you stop at step 43. With the subassembly off you can then remove the rockers to access the springs. Even if you could go directly to the caps without warping the head you still have to remove the timing cover and chains which in itself is a pain in the ass (thanks to the FIPG). Last edited by ermax; 11-21-2018 at 10:41 PM. |
| The Following User Says Thank You to ermax For This Useful Post: | humfrz (11-22-2018) |
| Broken Valve Spring | sybrite | Engine, Exhaust, Transmission | 45 | 11-02-2018 04:20 AM |
| Valve spring swap | rcmf5525 | Engine, Exhaust, Transmission | 6 | 05-19-2018 03:12 PM |
| Jrsc replacement diverter valve issue | Brzxton | Forced Induction | 6 | 12-08-2017 09:39 AM |
| GSC FA20 Valve Spring Kits | MAPerformance | Engine, Exhaust, Transmission | 41 | 07-20-2015 10:22 AM |
| Skunk2 Dual Valve Spring and Titanium Retainers | limitedblkwrx | Engine, Exhaust, Transmission | 0 | 01-04-2015 11:12 PM |
