Old 11-14-2018, 09:10 PM   #15
Originally Posted by danielmailrs View Post
ohh now it make sense lol
and naa not Illinois,israel it is.
Okaaaa.
I had you placed smack dab in the middle of farm country, in Illinois...
danielmailrs (11-15-2018)
Old 11-15-2018, 01:22 AM   #16
danielmailrs
Asphalt grinder
Drives: brz
Originally Posted by highway7 View Post
TOB as stated by others
Disappearing coolant
srs?and no leaks at all?lol how come
danielmailrs is offline   Reply With Quote
Old 11-15-2018, 01:28 AM   #17
danielmailrs
Asphalt grinder
Drives: brz
Okaaaa.
miss U.s so much especially CA T_T
Old 11-15-2018, 05:02 AM   #18
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
I personally found the overflow tank has too much slack in the rubber hose that enters from above. I wrapped the black rubber hose with electrical tape and pushed the hose back into the overflow tank.
Doing this minimized my evaporation - this is not an air tight sealed system and nor should it be. The coolant fill cap still has a hole so pressure won't build up, just minimized evaporation.
I used to top off every 3k miles, now I don't remember topping off for +10k miles.
The Following User Says Thank You to Bonburner For This Useful Post:
Old 11-15-2018, 05:40 AM   #19
danielmailrs
Asphalt grinder
Drives: brz
Thx mate
Sent from my SM-G960F using Tapatalk
Old 11-15-2018, 12:03 PM   #20
LOLOLOLOLOLOL
Come to a forum and ask "what are the common faults"? This is a minefield. There are guys here that are convinced that every little thing that happened to them is a "common" problem and that all of the cars no matter what year are spontaneously going to explode at any moment in time.
If you want to know the true "common" problems just review the list of TSBs and the year ranges that they impact. If not there then the shopping list of various complaints may indeed be an occasional or isolated problem but not a "common" one.
Old 11-15-2018, 01:48 PM   #21
radroach
Drives: car
Windows freezing stuck in the winter. There is a process for resetting the window switches after they get stuck. You'll know there's a fault if you press the window switch, and they blink back at you.
Wheel stud quality on my '13 was something to find fault with. Stripped 3 of them in one day last year, upgraded to ARP chromoly studs after that because i don't want to strip a stud on a track day etc.
Condensation in the tail light. Everybody has this on older models, I think some people have found a fix.
Rust forming on the window pillars. Newer models seemed to have fixed it with foam inserts but it might be good to check the corners around windows, perhaps fill gaps with grease.
Bumper sag. After removing / reinstalling the bumper you might find the bumper sags a bit. There are some fixes for it but its probably not to everyone's taste.
Transmission grinding when cold. I feel like this is pretty common. Usually have to work around it with double clutching, extra revving in neutral, etc. Works for me to do a few neutral revs in the morning after cold-start, then give it a jog around the block to make sure its all in good order before hitting the main road.
Clutch throw out bearing. More of an issue on older cars, bearings were packed with improper high-temperature / high load grease, burns itself up. Not sure if '15's have the issue or not.
Exhaust bolts seizing. If you're going to get any work done where your installer needs to remove the exhaust pieces, be sure to have a few extra exhaust studs on hand because the mechanic might need to cut through some bolts to get it out.
The Following User Says Thank You to radroach For This Useful Post:
Bonburner (11-15-2018)
How common are 86/frs/brz where you live? Thet Scion FR-S / Toyota 86 GT86 General Forum 107 04-09-2015 12:57 PM
Article: Toyota to recall nearly 6.5 million vehicles for steering, other faults Taro Issues | Warranty | Recalls / TSB 1 04-09-2014 12:56 PM
Common Misconceptions Pegasus Scion FR-S / Toyota 86 GT86 General Forum 31 01-16-2014 12:29 AM
86 factory faults Ryan86 AFRICA 64 03-17-2013 08:47 PM
electrical faults... tibsy92 AUSTRALIA 22 08-19-2012 11:25 PM
