Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AUSTRALIA
AUSTRALIA Australia and New Zealand
Old 08-17-2012, 08:39 AM   #1
tibsy92
tibsy92's Avatar
Drives: Toyota 86 GT Thunder Silver MT
Unhappy electrical faults...
So I finished work and realised my radio, interior light, clock, parker lights and rear tail lights don't work :/ I haven't played with the electricals, main low beam still works, no fuses blowen... any ideas..? I have to wait till Monday to take it to Toyota
Toyota 86 GT Thunder Silver MT - 22.06.12 ♥
tibsy92 is offline   Reply With Quote
Old 08-17-2012, 09:01 AM   #2
MarkMash
MarkMash's Avatar
Drives: Toyota 86
any fuses loose?
MarkMash is offline   Reply With Quote
Old 08-17-2012, 09:17 AM   #3
70NYD
70NYD's Avatar
Drives: RX8 S1
Recheck your Parker fuse. Sometimes they crack rather than blow
70NYD is offline   Reply With Quote
Old 08-17-2012, 09:41 AM   #4
st162celica
Drives: 86 GTS Manual - Tornado Grey
^^^^^. Like he said
Cracked fuses. Dont look blown. . . Got stung by that b4.
Im sure all those wouldnt be affected by 1 blown fuse. Whats the chance of multiple fuses blown.
Pull the battery terminal off for a period of time. Computer glitch ? <<< IT guy here, reboot fixes everything, well nearly everything.
Reason i say period of time. To reset my celica ecu i pull the ecu fuse or disconnect battery, if engine warm need to be disconnected for longer (20-30min). If motor fully cold then 2 min. Thats what the workshop manual says.
st162celica is offline   Reply With Quote
Old 08-17-2012, 11:00 AM   #5
davey90
Akina Speed Stars
davey90's Avatar
Drives: White 86 GTS Auto [CID- ***]
Send a message via Yahoo to davey90
Wink
So that's how you do a hard reboot on a car! I was holding on and off button for 10+secs , lol.jokes =P
davey90 is offline   Reply With Quote
Old 08-17-2012, 11:14 AM   #6
st162celica
Yeah hold the button for 10 seconds. If all else fails pull the battery out.
LoL
I say this to people at work at least once a day. b
They still ask y ? I say, Microsoft, keeps me in the job.
Old 08-17-2012, 11:26 AM   #7
tibsy92
tibsy92's Avatar
Thanks guys.. I'll check it out tomorrow morning. Try a reset of ecu. Check all fuses. I'll replace them as well to see if reset no work.
For the radio, manual says there's an internal panel in the cabin, I searched but couldn't find it, anyone know where the other fuse panel is?
Old 08-17-2012, 11:28 AM   #8
HunterGreene
Hail Magnet
HunterGreene's Avatar
Its also possible you have a bad wiring harness somewhere, but thats something that you won't be able to find out personally. Good luck!
Old 08-17-2012, 12:22 PM   #9
tibsy92
tibsy92's Avatar
Considering the amount of electricals that went out It is possible..
Old 08-17-2012, 06:23 PM   #10
TheDemons
Drives: Sonic Blue GTS
Might seem weird, but, put your high beams on (while car is running) for a while and see if any warning lights come on the dash. I'm thinking it may be a faulty component for the alternator (voltage regulator maybe) or faulty battery. Similar thing happened to me a while back. Hope that helps.
TheDemons is offline   Reply With Quote
Old 08-17-2012, 09:08 PM   #11
70NYD
70NYD's Avatar
Drives: RX8 S1
wait a minute
what i understood is that the lights on the dash, the backlights on the radio, the light on the clock and the rear/front parkers arent working
this is what i understood and said to check the one fuse that does all low lighting in most cars (when you switch the stalk to parkers)
however if the entire radio isnt working, than thats completely different man and unlikely to blow that many fuses. i hope its not the loom
Old 08-18-2012, 11:39 AM   #12
tibsy92
tibsy92's Avatar
Originally Posted by 70NYD View Post
wait a minute
Well the radio wasnt responding at all.. I tried a volt test with those little light pin things.. and like you said it wasn't blown it was cracked.. Google images helped show me the vcracked fuse.. appeared fine at first and tested well first time I did it.. turns out as I eventually found the interior fuse box in some small white box.. I replaced 3 different fuses.. the tail light fuse controls also parker lights and it was in interior box, interior light controlled the rest.. and for the radio.. also in the interior fuse box.. thanks for the help guys. :happy0180:
Old 08-18-2012, 07:00 PM   #13
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
So all fixed now? Take the fueses back for replacing
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 08-18-2012, 07:31 PM   #14
70NYD
70NYD's Avatar
Drives: RX8 S1
Awesome
So glad it wasn't the look or the stalk, but so confused as to how 3 cracked at the same time?
Was it a cold day when it stopped working? Cracking usually happens from thermal/physical shock rather than a electrical fault
Just happy it's all sorted now
FR-S electrical issues... EPIKsung Electronics | Audio | NAV | Infotainment 2 07-23-2012 10:15 PM
