Old 11-13-2018, 09:58 AM   #323
WNDSRFR
Drives: FR-S,GTI
The Official Notice is out today in the NTSC bulletin. There are some interesting documents in the bulletin, including this one listing that 25,000 FRS are impacted by the recall, and that if you are "uncomfortable" driving your car until it is repaired you can get a rental car for $35 per day.
It also says it covers vehicles from Late 02/2012 to Early 07/2013.
That matches the Subaru dates in this document.
What does it mean that you can get a rental car for $35.00 a day? Does that mean that Toyota will give you $35 a day to rent a car? Or is Toyota willing to take $35 a day from you to rent a car from them?
Old 11-13-2018, 10:16 AM   #324
ermax
ermax's Avatar
You pay them $35/day. That is a good price for a rental car though.
Old 11-13-2018, 10:33 AM   #325
ermax
ermax's Avatar
This doc is interesting:
https://static.nhtsa.gov/odi/rcl/201...8V772-0340.pdf
"From the investigation of the collected engine, it was estimated that the valve spring broke, fell off and the valve made contact with the piston, causing a rough idling and an abnormal noise."
"As a result, it was found that due to the improper design of the valve train, stress generated exceeded the design condition."
The choice of the words "valve train" as opposed to "spring" is interesting. They made the wire diameter thicker (increased the minimum thickness tolerance to be spesific) in May 2013 but in later years they also made the valves longer, changed the rockers and rocker pivots. I wonder if these later changes were an attempt to reduce stress on the springs more so than to fix the rocker ejection problems we've read about on the forums.
The Following 2 Users Say Thank You to ermax For This Useful Post:
Dadhawk (11-13-2018), Ultramaroon (11-13-2018)
Old 11-13-2018, 11:18 AM   #326
Rampage
Senior Member/Old Fanboi
Rampage's Avatar
Drives: 2000 2ZZ-GE MR2 Spyder HT
They are saying this is a voluntary recall. I wonder if a person does not bring their car in for the repairs when the parts become available then later suffers a spring failure that causes catastrophic damage like a bent valve, damaged piston, damaged valve seat or broken rocker arm then will Subaru pay for the repair of all the damage?
So many modders have more cents than sense!
Rampage is offline   Reply With Quote
The Following User Says Thank You to Rampage For This Useful Post:
humfrz (11-13-2018)
Old 11-13-2018, 11:45 AM   #327
Gunman
Drives: 2019 Mazda Miata RF
if it is outside of the normal warranty, I would not expect them to cover it.
Old 11-13-2018, 12:57 PM   #328
NCtoBRZ
Drives: 2017 Subaru BRZ PP WRB
When I brought a Honda in for the Takata airbag recall, they provided me a loaner (Accord Sport) free of charge for the nearly 2 months that it took for them to get the parts and perform the work... it's unfortunate that Subaru would expect owners to pay for a rental for this recall.
NCtoBRZ is offline   Reply With Quote
The Following User Says Thank You to NCtoBRZ For This Useful Post:
Rampage (11-13-2018)
Old 11-13-2018, 01:08 PM   #329
@ermax nailed it, or at least the way I read it. I didn't notice if Subaru was doing similar, but I didn't read theirs that closely. Obviously this is being handled by them separately even though Subaru may be reimbursing Toyota for the trouble.
Old 11-13-2018, 01:17 PM   #330
They are saying this is a voluntary recall?
Voluntary recall usually refers to it being manufacturer initiated rather than NTSC mandated I believe.
All recalls are 'voluntary' from the consumer prospective. You can't be forced to bring the car (or other product) in.
In terms of long-term impact, Subaru/Toyota would have a hard time proving that the owner 1) knew about the recall and 2) chose not to bring it in for repair before the failure. I'm guessing if it can be shown that that spring failed, and the car was in the group, they would most likely cover it.
ermax (11-13-2018)
Old 11-13-2018, 01:18 PM   #331
That was a much more "severe" impact and probability of incidence/liability so I'm not surprised there was a difference in response.
Old 11-13-2018, 01:44 PM   #332
Rampage
Rampage's Avatar
Pretty much ALL the affected cars are outside the warranty period already as the power train warranty is 5 Years. Being that it is an admitted design and material defect. I am inclined to think that they would have to fix it and anything else that broke in the engine because of it but I also know if they could fight it, they would.
Yeah, that makes sense.
Old 11-13-2018, 02:32 PM   #333
NCtoBRZ
Regardless of the "severity of impact", I don't find it to be reasonable to expect owners to pay for a rental for an untold amount of time while the dealership has their car for a recall. It would be different if it was a quick in/out type of recall like reflashing an ECU that can be completed in a matter of minutes. In any case, if an owner were to push back I wouldn't be surprised if Subaru might waive the rental fee.
Old 11-13-2018, 03:07 PM   #334
ermax
ermax's Avatar
The blurb about the $35 rental was for those that are nervous about driving the car BEFORE the repair. During the repair they may actually provide one for free.
The Following User Says Thank You to ermax For This Useful Post:
Old 11-13-2018, 03:10 PM   #335
@NCtoBRZ that is the way I was reading it as well.
Old 11-13-2018, 03:38 PM   #336
The "Blurb" is a part of instructions to the DEALER on how to deal with the recall. It is NOT a consumer document.
Need to read the whole thing in that context.
Loaner Vehicle Reimbursement Procedure
For customers who have experienced the condition or are uncomfortable driving their vehicle while Toyota prepares the remedy, a loaner vehicle or alternative transportation through Toyota Rent-A-Car can be claimed for $35 per day. Toyota is currently preparing the rental vehicle op codes. The Dealer Letter will be updated when these op codes are available, please hold claim filing until that time.
NOTE: Rental invoice MUST be attached to all rental claims. These claims may be subject to debit if rental invoice is not attached.
These are instructions on how the DEALER get's reimbursed from Toyota for any vehicles they loan or rent at no charge to customers not how much customers will be charged.
Remember that the dealers are not part of Toyota as a corporation they are simply their customers that buy and then resell the product.
I will go away again now.
The Following 8 Users Say Thank You to Tcoat For This Useful Post:
Dadhawk (11-14-2018), ermax (11-13-2018), humfrz (11-13-2018), NCtoBRZ (11-13-2018), spike021 (11-13-2018), Trap63 (11-13-2018), Ultramaroon (11-13-2018), wolffbite (11-14-2018)
Broken Valve Spring sybrite Engine, Exhaust, Transmission 45 11-02-2018 04:20 AM
Valve spring swap rcmf5525 Engine, Exhaust, Transmission 6 05-19-2018 03:12 PM
Jrsc replacement diverter valve issue Brzxton Forced Induction 6 12-08-2017 09:39 AM
GSC FA20 Valve Spring Kits MAPerformance Engine, Exhaust, Transmission 41 07-20-2015 10:22 AM
Skunk2 Dual Valve Spring and Titanium Retainers limitedblkwrx Engine, Exhaust, Transmission 0 01-04-2015 11:12 PM
