Old 11-11-2018, 02:19 PM   #1
Jamestl
Drives: None
Brake Bleeding - How to Cycle ABS Valves?
Any anyone here figured out to cycle the ABS valves on our cars without a diagnostic tool? I know I can get a harder brake pedal feel but after boiling some fluids at the last track day and activating ABS a couple of times, I feel like air may have gotten into the ABS modules that I can't seem to get rid off after two bleeds (where no air came out on the last one). Brakes still work fine but not as firm as usual after a flush.
I've looked around and it seems like older Subaru models can self cycle per this thread: https://www.iwsti.com/forums/gd-gene...-problems.html
I'm wondering if such a self diagnostic mode exist for our cars. Otherwise I need to buy an OBD tool that will do that for me, and who wants to spend extra money on a tool when you can do it for free! Thanks.
Jamestl is offline   Reply With Quote
Old 11-11-2018, 08:03 PM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Sounds like brake pads are toast. Not abs.
Old 11-11-2018, 08:35 PM   #3
Jamestl
Drives: None
Yeah that’s not the issue. On the second flush I went to winter pads. Same issue.
Old 11-11-2018, 10:57 PM   #4
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
That's an odd ball. Well, might want to spend some money on obd tool. Might want see what on sale on Black Friday.
Old 11-11-2018, 11:01 PM   #5
cueball89
Drives: 15 Impreza
Are there any dirt or gravel roads near you? Engage the abs a few times when it's safe to do so.
cueball89 is offline   Reply With Quote
What brake fluid do you use when bleeding/flushing the clutch? MINOCIN Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 7 08-24-2020 12:07 PM
brake bleeding, air in abs? Grip Ronin Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 11-22-2018 07:34 PM
Brake Bleeding - How to Cycle ABS Valves? Jamestl Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 0 11-09-2018 11:09 AM
Bleeding brakes-cycle ABS system? fasteddy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 07-11-2015 02:57 PM
Brake bleeding order? ubersoph Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 08-10-2012 07:13 AM
