Old 12-23-2015, 12:08 PM   #29
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
Originally Posted by drambo136 View Post
I disconnected the ccs the other day to see if it would idle but no luck. I put the injectors in with the turbo so I can't comment on whether or not its that. My tuner said it wouldn't be that tho. I guess he can see that they r working.
If u haven't noticed I'm pretty new to tuning and fi
Ok im annoyed. I replaced the bov spring with a yellow one today and at first it swwmed fine, but then it started to stall again and I got the same code again.....fml
The screenshots below from the datalog you posted are your problem. You have well over 30% short term fuel trims at the start of the log at idle. Your tune is off. I recommend getting another tuner if your tuner thinks this is OK or is "unable to see a problem" in your logs. This is a very clear issue, so your tuner's troubleshooting thought process concerns me.
Later long term trims correct up to 27%. To give you an idea, this is the amount of correction you'd see from trying to run e85 on a pump gas tune.
Stop driving your car in boost until you get your tune fixed.
Edit- This is under the assumption that you've checked every vac line for leaks and have adjusted your BOV properly.
'13 WRB BRZ ~470whp // Instagram // YouTube
BRZoomTX is offline   Reply With Quote
Old 12-23-2015, 12:25 PM   #30
FRS Justin
Drives: 2013 Asphalt FRS
Couldn't the STFT being at 35% be from a vacuum leak. It should stay at + or - 5 no greater than 8 or 9% but a vacuum leak resulting in a AFR of 19 would send the STFT off the chart trying to bring it back to 14.7 afr at 0% throttle opening.
Make sure both hoses under the intake are attached, one under the throttle body one under drivers side intake runner.
If you run a 19 AFR under bossted conditions YOU WILL melt a piston
EDIT:
The STFT will start to climb immediately to reflect the computer adding fuel. While the computer is adding fuel it still watches the o2 sensors until the o2 sensors are indicating that the lean condition no longer exists and proper air:fuel ratio is met. The computer will maintain this heightened addition of fuel until the leak is corrected. The scan tool will show STFT readings that are in the positive double digits, indicating that the computer has been adding too much fuel for normal operation. After a while the LTFT will also reflect this relative addition in fuel. Now if the vacuum leak is bad enough, the computer will not be capable of adding enough fuel to achieve proper air:fuel ratio. It will add fuel until the STFT reaches it's max calibration, usually 25%. Then a code is set in the computer indicating that the engine is running lean (P0171 or P0174) and the STFTs have maxed out
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
The Following User Says Thank You to FRS Justin For This Useful Post:
Kris86 (08-30-2016)
Old 12-23-2015, 12:50 PM   #31
FRS Justin
I'd rather not say who the tuner is, he has helped me out a lot. There is only so much you can do remotely.
I have the bov on the intake pipe.
It has the 8 psi spring in it. I've been reading that most ppl go with a 11 or 12 psi spring.
Thanks for the help
Why is your o2 sensor unplugged???!!!
710whp
Old 12-23-2015, 01:27 PM   #32
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
@FRS Justin
Everything you said regarding STFT I agree with. However the car shouldn't be undergoing tuning or hitting boost with this significant of a fueling correction immediately at startup. This is something the tuner should have had OP fix day 1 before tuning the car.
Black is rear O2. If long term fuel trim correction is not disabled in the tune then that could definitely be the problem. However if LTFT correction is disabled in EcuTek (set min/max to 0), then the rear O2 being unplugged should be fine. OP will need to verify regarding that.
Really strange stuff happening in OP's closed loop to open loop transition.
The Following User Says Thank You to BRZoomTX For This Useful Post:
FRS Justin (12-23-2015)
Old 12-23-2015, 01:47 PM   #33
FRS Justin
@FRS Justin
FTST 0% AFR 20.79 Unfreaking real, I would love to have this car in front of me, This is just crazy unpredictability
We need a data log as the car was after the tuning. It almost looks like its a N/A tune.
Drambo disconnect the intake pipe before the MAF and see if the car will idle without the turbo in the loop. Please take a data log of idle setup like this. Just want to rule a few things out. You might want to check the file you loaded to the ecm and make sure you accidently didn't load the wrong one.
710whp
Old 12-23-2015, 02:16 PM   #34
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
Yeah, a +7.8% fueling correction jumping to +35% within 150 RPM is a very, very drastic change. :/
I thought it was off throttle and a tip-in issue at first, but the 20.7 AFR is with throttle, so that is really bad.
Old 12-24-2015, 11:03 AM   #35
FRS Justin
Any updates???
710whp
Old 12-27-2015, 04:56 AM   #36
bprayogo
Drives: toyota 86
Compression leak. check your compression . make sure all cylinder all a ok. might be a valve seat gone bad
bprayogo is offline   Reply With Quote
Old 11-11-2018, 07:05 PM   #37
thinkV
Drives: BRZ Turbo
I am actually having a very similar issue after my Radium Catch can install.. I got the p0170 and p1171 code whilst driving. Pulled over to check the codes, and when I tried to start it struggled. It's been driving okay since but unsure what is causing it.
Mechanic was unable to find any leaks, and the tuner said the tune shouldn't change (only happened about a month after tune and lots of driving).
Here is a log I got of a very bad start shortly after the code:
https://datazap.me/u/thinkv/ecutek-b...=7&hg=10-11-24
Sorry for bumping an old thread, but thought it would keep any research in the same place.
thinkV is offline   Reply With Quote
Radium Engineering Catch Cans FRS2000 Engine, Exhaust, Transmission 111 03-02-2016 12:49 AM
FS: Radium Universal Catch Can - BRZ/FR-S Setup F1point4 Engine, Exhaust, Bolt-Ons 8 04-09-2015 01:08 PM
Radium Catch Can - $150 - SOLD TemeCal Engine, Exhaust, Bolt-Ons 2 02-04-2015 09:59 PM
Parting out car - Radium Catch Can, XM Receiver and more TemeCal Engine, Exhaust, Bolt-Ons 59 01-28-2015 04:49 PM
Kraftwerks / Jackson Racing SC kits with Radium Dual Catch cans setup? OICU812 Forced Induction 7 10-14-2014 12:36 AM
