Old 05-31-2015, 06:01 PM   #1
drambo136
drambo136's Avatar
Drives: 2013 Hot Lava
Radium Catch Can Setup? Turbo idle problem
Can anyone confirm the proper configuration for the dual catch cans on a turbo setup, specifically JDL turbo.
Little background, I'm having trouble with my car at idle. It's very rough and stalls A LOT! I also keep getting codes p0171 and p1171. My tuner has confirmed that the tune is fine, but said the cams have not learned yet. I hose clamped all the evap hoses under the intake. Then disconnected the catch cans to make sure that wasn't it and nothing changed. So, I just want to make sure I do have it right.
Any other Ideas?
Thanks in advance
drambo136 is offline   Reply With Quote
Old 05-31-2015, 06:53 PM   #2
steve99
Any other Ideas?
Thanks in advance
Sounds like you have got an intake air leak or unmetered air in getting into intake via catch cans or some other means.
It could also be exhaust leak effecting o2 sensor readings.
Both are lean codes.
Could also be problem with maf/map/o2 sensors, but most likely a leak.
"My tuner has confirmed that the tune is fine, but said the cams have not learned yet" that statement sounds like crap, the only time cams are effected is directly after a flash or ecu reset, you just need car to idle for about a minute before vvt system will operate. cam sit a zero offset at idle anyway. It not going to cause those lean codes.
Old 05-31-2015, 07:08 PM   #3
drambo136
drambo136's Avatar
Ok so I have a tial q bov that stays open at idle but its before the maf. That tuner says its fine. And what vvt parameter should I check
Old 05-31-2015, 07:53 PM   #4
Any other Ideas?
Thanks in advance
It sounds like you have a vaccuum leak somewhere.
Check ALL your hoses, including the non-catch-can hoses.
Old 05-31-2015, 08:08 PM   #5
steve99
you should be able to log
vvt cam angles for intake and exhaust cams at idle they will be zero but off idle they should both move away from zero.
agree with csg_mike its most likely a intake leak somewhere or possibly a check valve if fitted
Old 06-01-2015, 10:21 AM   #6
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Who is your tuner? How close is the BOV to the MAF? Turbulent air will piss off a MAF sensor.
Old 06-01-2015, 01:43 PM   #7
xxscaxx
Drives: 2013 SWP BRZ
JDL places the BOV on the IC, so pretty damn far from the MAF. The MAF is located on the cold side piping off the TB. The older JDL kits placed the BOV on the passenger side of the IC, so that would put it somewhat near it but still pretty far. The newer revised setup puts the BOV on the hotside of the IC.
EDIT: Actually I forgot the first revision of their kit had the BOV on the MAF coldside piping. Can have OP confirm where the BOV is placed.
The cc's should be ran the same regardless of the kit, except on the driver side. If you have a fitting off the intake piping (which you should), you need to run the outlet to the intake (bottom port). The Inlet goes to the CCV that sits under and behind the AC Compressor (this is the line that plugs into the stock intake tube on a stock setup).
The passenger side should have the PCV going to the inlet (top of can), and the outlet going to the intake manifold where the PCV originally connected to.
What size BOV spring are you running?
xxscaxx is offline   Reply With Quote
Old 06-01-2015, 05:19 PM   #8
drambo136
drambo136's Avatar
I'd rather not say who the tuner is, he has helped me out a lot. There is only so much you can do remotely.
I have the bov on the intake pipe.
It has the 8 psi spring in it. I've been reading that most ppl go with a 11 or 12 psi spring.
Thanks for the help
Old 06-01-2015, 07:56 PM   #9
drambo136
drambo136's Avatar
Well I double checked all the hoses and they all seem to be fine. All my evap hoses are hose clamped, the cc hoses are in the right spot, and my vacuum manifold is tight and not leaking. not sure where to look next. I might make myself a smoker
Old 06-01-2015, 09:43 PM   #10
myioz86
Drives: gt-86 2013
I had the same problem when i put my catch cans on it turned out to be the hoses were to small restriction in them drilled out all the fittings and put 1/2id hoses on and no problems.one catchcans for each side they work seperatly.
myioz86 is offline   Reply With Quote
Old 06-01-2015, 11:28 PM   #11
drambo136
drambo136's Avatar
Mine have 1/2 hoses and fittings...just adapters to the stock hoses.
Also what type of check valve r u guys using
Old 06-02-2015, 01:14 AM   #12
myioz86
Drives: gt-86 2013
1/2" chech valve plastic , just make shore it dosent have two strong a spring in it. you should be able to blow and suck very easly.if its two heavy it wont open and vent when it needs to.
Old 06-02-2015, 07:27 AM   #13
King Tut
NASA SpecE30 Racer
King Tut's Avatar
It is definitely your BOV. Get an 11 psi spring and some washers or a 12 psi spring till it stays closed at idle.
Old 06-02-2015, 07:31 AM   #14
drambo136
drambo136's Avatar
Ok thx I just ordered the yellow spring
Radium Engineering Catch Cans FRS2000 Engine, Exhaust, Transmission 111 03-02-2016 12:49 AM
FS: Radium Universal Catch Can - BRZ/FR-S Setup F1point4 Engine, Exhaust, Bolt-Ons 8 04-09-2015 01:08 PM
Radium Catch Can - $150 - SOLD TemeCal Engine, Exhaust, Bolt-Ons 2 02-04-2015 09:59 PM
Parting out car - Radium Catch Can, XM Receiver and more TemeCal Engine, Exhaust, Bolt-Ons 59 01-28-2015 04:49 PM
Kraftwerks / Jackson Racing SC kits with Radium Dual Catch cans setup? OICU812 Forced Induction 7 10-14-2014 12:36 AM
