Old 11-02-2018, 12:00 PM   #15
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Originally Posted by D_Thissen View Post
Mine falls into the production period (July '13) but looks like my VIN number is okay. #34515
Same for me.
N1rve
Old 11-02-2018, 12:44 PM   #16
vagthomas
Drives: Toyota GT86
I spent a while looking for actual failures on the models listed and found nothing. Looks like they identified the possible failure internally and not through actual reported issues. Not that it makes it a better situation for those affected but at least there is some comfort in knowing they are dealing with it.
Actually there is one case here, in the club
And its 2013 model
https://www.ft86club.com/forums/showthread.php?t=101784
vagthomas is offline   Reply With Quote
Old 11-02-2018, 12:52 PM   #17
And its 2013 model
Thanks! I was beginning to wonder why the hell there was no reference to an issue anyplace! The one article said there were 92 reported and I could not find any of them which just didn't make sense in the modern info age.
There were issues back in 2009 to 2011 with sprigs and there was piles of info on that.
Old 11-02-2018, 12:56 PM   #18
Ragin Gti
Drives: '15 Subaru BRZ
There is a recall number for the US but it's not on the Subaru website yet. So no solid info for which cars will be included.
Ragin Gti is offline   Reply With Quote
Old 11-02-2018, 01:09 PM   #19
Ragin Gti
Originally Posted by TytheToyotaGuy View Post
Ok so slightly off topic question but I've been searching everywhere and can't find the actual notice/TSB.
How about the revised rocker arms that they came out with for the MY2013 cars? I seem to remember them only replacing if the engine made the ticking/typewriter noise, not an actual recall. Does anyone have a link to this TSB?
If my car is affected by the spring issue and they're going to have the engine apart, should I ask the dealer to put in the revised rocker arms while they're at it?
Subaru TSB 02-151-14R. It's meant to reduce a tapping or sewing machine type noise when warm from the left cylinder head. It involves replacing the left side intake and exhaust camshafts, rockers, pivots and valves. Also slightly different valve clearance specifications. It seems to be just to repair a noise complaint, not actually fix a mechanical defect or problem.
Old 11-02-2018, 01:41 PM   #20
davesrave
davesrave's Avatar
Drives: 2014 Boxster S; 2015 Macan S
Originally Posted by oaroyale View Post
Dang... I guess I am out. I am 1121. Which means it's an earlier production than the recall cars. This is quite interesting....
Me too. VIN ...00367. Wonder what the difference is, better quality control because they were dotting on the early ones?
davesrave is offline   Reply With Quote
Old 11-02-2018, 01:44 PM   #21
More likely just chance. Remember the Twins are less than 20% of the vehicles affected so it had nothing to do with their actual release dates.
Old 01-09-2019, 08:35 AM   #22
Jamesallen45
Drives: 2013 FRS
I have a 2013 FRS that is part of the valve spring recall. The car has already been in a shop since October. It stalled and was found to have broken rocker arms and bent valves. The shop could not say exactly how it happened. It has around 50k miles. I will attempt to have Toyota reimburse me for the repairs. I am wondering if anyone has heard of catastrophic engine failure because of this issue. We definitely had a failure of some kind in the heads. I was told it is very difficult to know exactly what caused the failure because so many things broke as a result. Hard to determine what failed first.
List of broken components:
bent valves
cracked valve guides
cracked springs
possible cracked heads (still being evaluated)
broken tooth on crank gear
crank gear cracked through
pistons dented or gouged
Jamesallen45 is offline   Reply With Quote
Old 01-09-2019, 11:36 AM   #23
ka-t_240
bent valves
cracked springs
If it is not at a subaru/toyota dealer, I would suggest getting lots of pictures, a current work order and going to your local dealer to discuss the failure. They may ask for the car and or engine to be brought in so a regional rep can review whats going on and make the call on possible replacement/repair coverage.
ka-t_240 is offline   Reply With Quote
Old 01-13-2019, 03:47 PM   #24
Faulkner
Well looks like I could be one of the unlucky few. 30425. Contacted the dealer today so we’ll see what happens. At least it packed away for that winter now
Faulkner is offline   Reply With Quote
Old 01-13-2019, 04:30 PM   #25
oaroyale
Drives: Black BRZ
I was one of the earlier production, vin 1121. I thought my car was not in the recall list, but I just got the recall notice yesterday in the mail. I will contact the dealer Monday and see what they say.
oaroyale is offline   Reply With Quote
Old 01-14-2019, 12:14 PM   #26
Foobar
SLO NO MO
Foobar's Avatar
Hey all, been a while since I've been actively posting. Just got my recall notice over the weekend. I'm gonna hold off and wait until the Spring before I do anything as the BRZ's tucked away for the winter, and I want to see how others are treated that have extensive mods (Supercharger).
For reference, VIN is 2143
Old 01-14-2019, 02:40 PM   #27
oaroyale
Drives: Black BRZ
I just talked to the dealer. They said they don't have the tools to perform the fix right now.
Old 01-14-2019, 03:07 PM   #28
That's scary ….
valve spring issue? nikitopo Issues | Warranty | Recalls / TSB 1037 05-01-2019 10:55 PM
Broken Valve Spring sybrite Engine, Exhaust, Transmission 45 11-02-2018 04:20 AM
Valve spring swap rcmf5525 Engine, Exhaust, Transmission 6 05-19-2018 03:12 PM
GSC FA20 Valve Spring Kits MAPerformance Engine, Exhaust, Transmission 41 07-20-2015 10:22 AM
Skunk2 Dual Valve Spring and Titanium Retainers limitedblkwrx Engine, Exhaust, Transmission 0 01-04-2015 11:12 PM
