Old 10-25-2018, 12:23 AM   #1
yablonskiy11
Drives: 2013 Subaru BRZ
Car cranks but wont start
I recently bought a BRZ from Copart. There was engine damage whatsoever, the engine is just dirty and a little coroded from oil I'm guessing. When it was time for me to turn her over, it started right away and then it just died on its own. Turned it over again the second time and stayed on. So later on during the week, I decided to take it for a spin and drove around in it with no issues popping up besides a little coolant leak which I fixed after. A few days later I tried starting it up again and it wouldn't start. It cranks and all but it just won't turn over. I've checked the fuel pump/injector fuses all look in good shape. Has anybody had the same issue and has solved it? Or any solutions to the problem?! PLease HELP
yablonskiy11 is offline   Reply With Quote
Old 10-25-2018, 12:48 AM   #2
RichardJ
RichardJ's Avatar
Drives: 15' FRS
Weak battery?
RichardJ is offline   Reply With Quote
Old 10-25-2018, 01:10 AM   #3
Impureclient
Drives: 2015 FR-S
bad/no/low fuel
camshaft position sensor
crankshaft position sensor
MAF sensor
failing starter
throttle position sensor
clogged fuel filter
no spark
failing fuel pump
bad battery connection
Did you do a thorough search in here under the "Issues | Warranty | Recalls / TSB" and "Mechanical Maintenance" subforums?
Old 10-25-2018, 01:29 AM   #4
Without an OBDII reader you're just pissing in the wind. Look for the fault codes. Link to the service manuals are in my sig line.
Old 10-25-2018, 02:07 AM   #5
spike021
spike021's Avatar
To be honest that sounds like when my battery died. Does it seem like yours is the original? If so I'd hazard a guess that it needs to be replaced.
Instagram: @spike.grc
spike021 is offline   Reply With Quote
Old 10-25-2018, 08:19 AM   #6
MCTeeJ
MCTeeJ's Avatar
Drives: 2014 Scion FR-S
Everyone's info has been helpful but I'm just gonna throw in the ground bolt on the DI module for good measure.
MCTeeJ is offline   Reply With Quote
Old 10-25-2018, 08:35 AM   #7
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Check the "STOP" fuse too. Could be part of the issue.
I LIKE TIRES!
Old 11-01-2018, 12:36 AM   #8
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
The link to service manuals have helped me so much. Thank you!!!
Old 11-01-2018, 12:48 AM   #9
I wish I could remember the forum member that set them up in the first place. He's the real hero.
Old 11-01-2018, 06:08 AM   #10
steve99
Drives: FT86
Check the map sensor reads 1 bar or 14psi with ignition on but engine off, if its way differnt map senspr may be faulty this will stop car starting
Old 11-01-2018, 11:45 PM   #11
yablonskiy11
I GOT HER STARTED!!! I first checked all the fuses to see if they were good and they were, so as I explained before that the cranked normally but wouldn't turn over. I changed my plugs and that wasn't it either. So a few flying wrenches and headbanging minutes later I just thought for some reason. Like, reset the car. I unplugged the negative terminal to the battery and reconnected it back, and the thing turned over!! I am no professional at cars and don't get why it started from that, but I have never come across something like that.
Thank you guys for all of your inputs!
Old 11-02-2018, 12:21 AM   #12
Thanks for the update.
At least, you now have new spark plugs -
Reminds me of me back-in-the-day with my first computer … the damn thing would get all goofed up, so I would just unplug it - then when I plugged it back in - it was OK. I never understood that either -
Old 01-02-2019, 01:02 AM   #13
Donizzz
Drives: 2015 Scion FR-S
Have a question bro! I have a code which is P000B, says timing slow bank 1. Thought it might be cam pos sensor! Do any of y'all know where its located?
Donizzz is offline   Reply With Quote
Old 01-02-2019, 08:30 AM   #14
Welcome to our new year forum ..
Although this is over my paygrade, I do believe the FA20 engine has four of them. They are located at the front of the engine at the ends of the camshafts.
They kinda of look like this.
Someone else will be along soon to tell you which ones are which for the intake and exhaust and left or right bank.
BRZ wont start in hot weather! Coop Issues | Warranty | Recalls / TSB 3 06-28-2018 05:24 PM
Edelbrock Supercharger Install - Will not start, Cranks forever. I'm out of ideas. WinterWolf Issues | Warranty | Recalls / TSB 12 05-26-2018 07:12 AM
Edelbrock Supercharger Install - Will not start, Cranks forever. I'm out of ideas. WinterWolf Forced Induction 2 05-16-2018 04:38 PM
Car wont start? Anyone else? ScionFrsFan Issues | Warranty | Recalls / TSB 150 06-09-2017 09:35 PM
Car Wont Start Up HELP !!*** ScionFR-S Issues | Warranty | Recalls / TSB 20 11-28-2013 01:01 AM
