Old 10-28-2018, 08:59 AM   #29
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
This explains why my car has a weird torque dip in the rpm band. Definitely going to the GM to request a whole new long lock assembly, and a steam cleaning for the inconveniences pushed upon me. I also want some Twizzlers
The Following 3 Users Say Thank You to DarkPira7e For This Useful Post:
funwheeldrive (10-30-2018), Pat (10-30-2018), sato (10-28-2018)
Old 10-28-2018, 10:20 AM   #30
ermax
ermax's Avatar
Originally Posted by BRZnut View Post
But real question...there have been reports on here over the years of the rocker arms self destructing. Is that what this potential recall could be about?
I was actually thinking about the same thing. Maybe the spring fails and takes the rocker with it and then it’s assumed the rocker was at fault. It will be interesting to see more details on this potential recall.
Old 10-28-2018, 10:46 AM   #31
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Originally Posted by Auto_egr View Post
You're not going to see a burnt valve on these cars. Most modern engines use sodium filled valves which make it borderline impossible.
If by most you mean not that many then yes, you are completely right.
Old 10-28-2018, 11:08 AM   #32
coryandy
coryandy's Avatar
Drives: '14 SSM BRZ Premium
Originally Posted by Summerwolf View Post
How many people you think will get that!?!?!?
42
"To be without silver is better than to be without honour." - Norse Proverb
coryandy is offline   Reply With Quote
Old 10-28-2018, 12:14 PM   #33
Ricepuddin
Get a Bowl
Ricepuddin's Avatar
Drives: 2017 BRZ PP
Did you bring your towel ?
Originally Posted by coryandy View Post
42
Sent from my Pixel 3 XL using Tapatalk
Ricepuddin is offline   Reply With Quote
Old 10-28-2018, 12:29 PM   #34
Not impossible but very improbable.
I have been down this road before on another car. The FA20 is an interference engine so any valve that is not where it belongs when it belongs there can hit either the cylinder or another valve. The best case scenario is the spring breaks or gets too weak and you get a serious misfire. The worst case is the valve actually jams and the cylinder smacks it making a real mess. Not sure what sequence of event would have to go down fast enough to throw a rod without noticing the very obvious broken/weak spring symptoms first. You break a spring and the car should start throwing codes like mad before any risk to a rod exists.
Originally Posted by Veloist View Post
Early 2018's were known to have valvetrain issues, so I wonder if this potential recall is related.
First notable issue I recall:
https://www.ft86club.com/forums/showthread.php?t=125672
Although a different cause is given in that thread the symptoms are the same. The "valves are too tight, it will need a valve adjustment" most certainty could mean a weak spring and not sticky valves.
Time will tell. I have a vested interest in this because we have TWO cars that could be impacted if it applies to all years.
Veloist (10-29-2018)
Old 10-28-2018, 12:30 PM   #35
42
Thanks for all the fish.
Old 10-28-2018, 06:10 PM   #36
radroach
Drives: car
I believe this story is more about the rocker arm failure, from those posts where motors went pop, even stock tuned cars driving normally.
Old 10-28-2018, 07:21 PM   #37
TheRealBFKR
Drives: '18 WRB BRZ Limited w/ PP
Mine was built in April 2018, would that make it a somewhat late 2018?
TheRealBFKR is offline   Reply With Quote
Old 10-29-2018, 01:48 PM   #38
chipmunk
Drives: _
Learned about this today. Emailed my dealer. He said they haven't heard anything yet.
Fingers crossed! Hopefully this is the last issue I'll ever have with this car.
(I'm slowly beginning to regret buying the manual BRZ....)
chipmunk is offline   Reply With Quote
Old 10-30-2018, 07:12 AM   #39
BRZnut
Drives: BRZ DGM Limited
It this is all true I can not see Subaru taking all these engines in to replace the springs. I known I do not want them touching my engine if it is working fine. I would hope that they just extend the warrantee on the motor. I'd accept 15 years 150K miles!
The Following User Says Thank You to BRZnut For This Useful Post:
Old 10-30-2018, 01:11 PM   #40
NCtoBRZ
Drives: 2017 Subaru BRZ PP WRB
A recall is issued when a manufacturer or NHTSA determines that a vehicle, equipment, car seat, or tire creates an unreasonable safety risk or fails to meet minimum safety standards.
If this recall actually happens, for liability reasons Subaru won't be negotiating deals where you get to choose to have the work done OR some incentive like an extended warranty. You may be able to have Subaru give you an extended warranty in addition to replacing the valve springs.
NCtoBRZ is offline   Reply With Quote
The Following User Says Thank You to NCtoBRZ For This Useful Post:
Tcoat (10-30-2018)
Old 10-30-2018, 01:17 PM   #41
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Originally Posted by 86MLR View Post
DONT PANIC
I remind my self everyday.
It is also my hazard button...
I LIKE TIRES!
HachiRokuX (10-31-2018)
Old 10-31-2018, 05:29 AM   #42
RZNT4R
The plot thickens
https://carbuzz.com/news/subaru-set-...all-in-america
Broken Valve Spring sybrite Engine, Exhaust, Transmission 45 11-02-2018 04:20 AM
Valve spring swap rcmf5525 Engine, Exhaust, Transmission 6 05-19-2018 03:12 PM
Jrsc replacement diverter valve issue Brzxton Forced Induction 6 12-08-2017 09:39 AM
GSC FA20 Valve Spring Kits MAPerformance Engine, Exhaust, Transmission 41 07-20-2015 10:22 AM
Skunk2 Dual Valve Spring and Titanium Retainers limitedblkwrx Engine, Exhaust, Transmission 0 01-04-2015 11:12 PM
