#29 |
Rust bucket enthusiast
This explains why my car has a weird torque dip in the rpm band. Definitely going to the GM to request a whole new long lock assembly, and a steam cleaning for the inconveniences pushed upon me. I also want some Twizzlers
| The Following 3 Users Say Thank You to DarkPira7e For This Useful Post: |
#30 | |
I was actually thinking about the same thing. Maybe the spring fails and takes the rocker with it and then it’s assumed the rocker was at fault. It will be interesting to see more details on this potential recall. |
#31 |
Professional Mechanic
Drives: 2017 86 6MT Oceanic
#32 |
Drives: '14 SSM BRZ Premium
"To be without silver is better than to be without honour." - Norse Proverb
#33 |
Get a Bowl
Drives: 2017 BRZ PP
#34 | ||
I have been down this road before on another car. The FA20 is an interference engine so any valve that is not where it belongs when it belongs there can hit either the cylinder or another valve. The best case scenario is the spring breaks or gets too weak and you get a serious misfire. The worst case is the valve actually jams and the cylinder smacks it making a real mess. Not sure what sequence of event would have to go down fast enough to throw a rod without noticing the very obvious broken/weak spring symptoms first. You break a spring and the car should start throwing codes like mad before any risk to a rod exists. Quote:
Time will tell. I have a vested interest in this because we have TWO cars that could be impacted if it applies to all years.
| The Following User Says Thank You to Tcoat For This Useful Post: | Veloist (10-29-2018) |
#35 |
#36 |
Drives: car
I believe this story is more about the rocker arm failure, from those posts where motors went pop, even stock tuned cars driving normally.
#37 | |
Drives: '18 WRB BRZ Limited w/ PP
#38 |
Drives: _
Learned about this today. Emailed my dealer. He said they haven't heard anything yet.
Fingers crossed! Hopefully this is the last issue I'll ever have with this car. (I'm slowly beginning to regret buying the manual BRZ....) |
#39 |
Drives: BRZ DGM Limited
It this is all true I can not see Subaru taking all these engines in to replace the springs. I known I do not want them touching my engine if it is working fine. I would hope that they just extend the warrantee on the motor. I'd accept 15 years 150K miles!
| The Following User Says Thank You to BRZnut For This Useful Post: | funwheeldrive (10-30-2018) |
#40 | |
Drives: 2017 Subaru BRZ PP WRB
If this recall actually happens, for liability reasons Subaru won't be negotiating deals where you get to choose to have the work done OR some incentive like an extended warranty. You may be able to have Subaru give you an extended warranty in addition to replacing the valve springs. |
| The Following User Says Thank You to NCtoBRZ For This Useful Post: | Tcoat (10-30-2018) |
#41 |
Country Boy 4 Life
I remind my self everyday.
It is also my hazard button...
I LIKE TIRES! |
| The Following User Says Thank You to Leonardo For This Useful Post: | HachiRokuX (10-31-2018) |
#42 |
| Broken Valve Spring | sybrite | Engine, Exhaust, Transmission | 45 | 11-02-2018 04:20 AM |
| Valve spring swap | rcmf5525 | Engine, Exhaust, Transmission | 6 | 05-19-2018 03:12 PM |
| Jrsc replacement diverter valve issue | Brzxton | Forced Induction | 6 | 12-08-2017 09:39 AM |
| GSC FA20 Valve Spring Kits | MAPerformance | Engine, Exhaust, Transmission | 41 | 07-20-2015 10:22 AM |
| Skunk2 Dual Valve Spring and Titanium Retainers | limitedblkwrx | Engine, Exhaust, Transmission | 0 | 01-04-2015 11:12 PM |
