Old 10-26-2018, 11:33 AM   #1
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
valve spring issue?
Anyone knows about a valve spring issue? I was reading this today and it is mentioning about a possible massive recall of vehicles:
https://www.torquenews.com/1084/suba...many-us-models
The Following 2 Users Say Thank You to nikitopo For This Useful Post:
Chimera (10-26-2018), funwheeldrive (10-27-2018)
Old 10-26-2018, 11:35 AM   #2
TxDave89
Drives: 2013 FRS
Bump for future info.
Could be a good excuse to upgrade internals.
Sent from my Pixel 2 using Tapatalk
TxDave89 is offline   Reply With Quote
The Following 2 Users Say Thank You to TxDave89 For This Useful Post:
nikitopo (10-26-2018), Trap63 (10-28-2018)
Old 10-26-2018, 11:45 AM   #3
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
If it really is for a faulty valve spring, then it sounds like it could potentially "just" be a supplier issue, where the supplier used defective/poor metal, or manufactured it with some sort of defect. Especially since it sounds like it will apply to just about every engine, which would suggest it isn't a specific design issue. If that's the case, it may be widespread, but hopefully will be for 'relatively recent' vehicles, and not vehicles spanning back several years. We shall see, though! My latest 10,000 mile interval oil change results were so perfect I don't want ANYONE touching my engine!
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
The Following 2 Users Say Thank You to Stang70Fastback For This Useful Post:
nikitopo (10-26-2018), Tristor (10-26-2018)
Old 10-26-2018, 12:45 PM   #4
ZionsWrath
Thanks
ZionsWrath's Avatar
Are there any warning signs for this issue before a failure?
The Following User Says Thank You to ZionsWrath For This Useful Post:
ftc~brz (01-15-2019)
Old 10-26-2018, 12:50 PM   #5
TxDave89
Drives: 2013 FRS
Excessive valve noise, if a spring fails you should lose compression in the effected cylinder(s)
The Following User Says Thank You to TxDave89 For This Useful Post:
nikitopo (10-27-2018)
Old 10-26-2018, 01:14 PM   #6
Smokinbuffalo
BRZ Owner
Smokinbuffalo's Avatar
Drives: SWP Ltd MT BRZ, Scion xA
I found this...
http://www.asahi.com/sp/ajw/articles...810250056.html
Buy the ticket, take the ride
Smokinbuffalo is offline   Reply With Quote
Old 10-26-2018, 01:37 PM   #7
In addition, if it is just a weakened spring, that could cause a burnt valve and the compression would be reduced.
ermax (10-26-2018), ftc~brz (01-15-2019)
Old 10-26-2018, 02:29 PM   #8
ermax
ermax's Avatar
Also, if you float the valves enough you could end up with valve to piston contact.
The Following User Says Thank You to ermax For This Useful Post:
humfrz (10-26-2018)
Old 10-26-2018, 03:45 PM   #9
Tristor
Tristor's Avatar
I waited to get a 2017 specifically to get the updates and avoid some of the earlier issues. So far I'm 15k miles in and have had no issues, most of the reports I've seen where people believe they were affected by this saw it in the first 5-10k miles. I'm hoping this isn't a very broad recall, because like @Stang70Fastback, my UOAs and other indicators are so perfect right now I don't want anyone touching my engine internals.
Tristor is offline   Reply With Quote
The Following 2 Users Say Thank You to Tristor For This Useful Post:
strat61caster (10-26-2018), TofuJoe (10-27-2018)
Old 10-26-2018, 03:55 PM   #10
Then, if the keeper comes off the end of the valve and the valve drops -
Allrightee - who isn't paranoid now -
Old 10-26-2018, 04:00 PM   #11
Lantanafrs2
Drives: 2013 frs red
They'd better stock up on short blocks and heads. Seriously though, if the springs are bad it shouldn't take them long to fail so this is most likely a recent issue.
Lantanafrs2 is offline   Reply With Quote
Old 10-26-2018, 04:02 PM   #12
Auto_egr
Drives: 2017 CWP BRZ w/PP
You're not going to see a burnt valve on these cars. Most modern engines use sodium filled valves which make it borderline impossible.
Auto_egr is offline   Reply With Quote
The Following User Says Thank You to Auto_egr For This Useful Post:
Trap63 (10-28-2018)
Old 10-26-2018, 08:06 PM   #13
Veloist
Veloist's Avatar
Drives: ‘93 MR2, ‘22 GR86, ‘23 GR Corolla
Early 2018's were known to have valvetrain issues, so I wonder if this potential recall is related.
First notable issue I recall:
https://www.ft86club.com/forums/showthread.php?t=125672
Veloist is offline   Reply With Quote
The Following 2 Users Say Thank You to Veloist For This Useful Post:
nikitopo (10-27-2018), Tcoat (10-28-2018)
Old 10-27-2018, 01:41 AM   #14
ZionsWrath
Thanks
ZionsWrath's Avatar
Just asking because my car had engine knock when I sold it. Well, pretty sure it was knock. That's not specifically why I got rid of it just the last straw. Probably not related to this issue.
Broken Valve Spring sybrite Engine, Exhaust, Transmission 45 11-02-2018 05:20 AM
Valve spring swap rcmf5525 Engine, Exhaust, Transmission 6 05-19-2018 04:12 PM
Jrsc replacement diverter valve issue Brzxton Forced Induction 6 12-08-2017 10:39 AM
GSC FA20 Valve Spring Kits MAPerformance Engine, Exhaust, Transmission 41 07-20-2015 11:22 AM
Skunk2 Dual Valve Spring and Titanium Retainers limitedblkwrx Engine, Exhaust, Transmission 0 01-05-2015 12:12 AM
