Old 09-02-2018, 04:37 AM   #15
JD001
JD001's Avatar
Drives: Subaru BRZ
Originally Posted by wild03 View Post
Ah, BTW if one interprets "current" as in "the present time" the image gets confusing to understand. Had to read it like three times then I realize they mean electrical current.
And if one transposed the 'e' with an 'a' you'll be blowing raspberries..
The Following User Says Thank You to JD001 For This Useful Post:
Ultramaroon (09-02-2018)
Old 10-08-2018, 11:29 AM   #16
Stephen W.
Stephen W.'s Avatar
Drives: 1993 Caterham HPC Evo
OK, I noticed the same voltage rise and fall when I first bought my car. Read this thread and was happy for the info. However, now it's a constant 14+ and never drops. I've been on some half hour long joints down the Highway of Heroes expecting it to drop but it doesn't. So, does my car have a problem or must I go on a three hour cruise? (Remember what happened to the SS Minnow)
Old 10-08-2018, 12:09 PM   #17
NCtoBRZ
Drives: 2017 Subaru BRZ PP WRB
What kind of electrical load was there on this drive (headlights, AC, etc. turned on)? If the headlights are turned on, it will stay at a constant 14+ volts.
NCtoBRZ is offline   Reply With Quote
Old 10-08-2018, 10:19 PM   #18
Stephen W.
Stephen W.'s Avatar
Headlights are set to Auto with the audio muted, (there is no off) during regular daytime running.
Old 10-15-2018, 08:59 AM   #19
BellaItalia
BellaItalia's Avatar
Drives: 2017 860 Solar-stick
i noticed this, too, and checked the water in the battery, sucka almost dry to the bone !! ... added water, but still acted that way, so figured it was normal, thread explains that now, THX, but check your water !
BellaItalia is offline   Reply With Quote
Old 10-22-2018, 05:07 PM   #20
nico_rsx
Drives: BRZ 2017 Pure Red, MT
Your car doesn't have a problem, the problem is we live in Canada
Below a certain temperature (seems to be around 7-8C), the alternator will keep a constant 14.4V. I'm guessing to make sure the battery is at 100% as much as possible, to prepare for the next cold start.
It will also keep a constant 14V if your headlights or the rear defrost is on (and maybe other things I haven't noticed, like heating seats, etc).
nico_rsx is offline   Reply With Quote
O2S2 Voltage Always Zero bhaugen2 Engine, Exhaust, Transmission 22 09-14-2022 06:35 AM
help - voltage oscillates Last Lemming Alive BRZ First-Gen (2012+) — General Topics 29 04-10-2022 09:37 PM
Consensus on changing whole transmission versus changing solenoids dem00n Engine, Exhaust, Transmission 7 07-20-2016 04:50 AM
Voltage Fluctuation Andrew666 Electronics | Audio | NAV | Infotainment 5 04-21-2013 09:15 PM
Voltage fluctuations Andrew666 AUSTRALIA 7 03-19-2013 10:44 AM
