go_a_way1, MisterSheep
Old 10-12-2018, 12:13 PM   #19727
KDad2
KDad2's Avatar
Drives: 2013 Raven
Originally Posted by qcbaker View Post
Well, in that case if I do end up needing the whole thing it should only cost me like 200 bucks. Not too bad, I guess.
Also, if the crack is less than 12", then your insurance should fix for free without it impacting your policy. GEICO uses SafeLite as an example.
KDad2 is offline   Reply With Quote
Old 10-12-2018, 12:13 PM   #19728
carsebuco
How do I shift?
carsebuco's Avatar
Drives: '13 GBS BRZ
Had mine replaced the 1st week I got to AZ due to a huge rock being kicked back off a truck on my way here. Already had a couple of spots filled on this second one, but I may be moving on to #3 real soon. I'm quite surprised #2 has lasted this long. AZ is a terrible, terrible place for cars.
carsebuco is offline   Reply With Quote
Old 10-12-2018, 12:20 PM   #19729
I feel you, it sucks! I'm on my 7th windsheild for my truck.
My fr-s has a chip in the windsheild too.
Seven is impressive. My record was four on my 58 Chev. It had the old wrap around windshield that was a bitch to change. One time it had a huge crack so I called and they sent the mobile unit to my house to change it. I told them that it was probably better done in the shop but they said that the guy was an expert at the old cars and it wouldn't be an issue. It was early spring and the guy showed up about 8am when it was still cold out. He swapped it in about an hour and left. I was impressed. About 2 that afternoon when it had warmed up considerably, I am in the back yard and hear BOOM. Walk around the house and there is the windshield spread across the whole driveway. Apparently he had twisted it when he installed it and as soon as it warmed up...
Dadhawk (10-12-2018), humfrz (10-14-2018), Leonardo (10-12-2018)
Old 10-12-2018, 04:35 PM   #19730
StraightOuttaCanadaEh
Wes
Installed the Legstyle duckbill and the Whiteline rear subframe bushings.
More in the thread: http://www.ft86club.com/forums/showt...=116871&page=4
Instagram: @gt86ws
The Following 6 Users Say Thank You to StraightOuttaCanadaEh For This Useful Post:
BirdTRD (10-13-2018), Leonardo (10-12-2018), MJones_RB (10-15-2018), new2subaru (10-12-2018), SuperTom (10-13-2018), zeal86 (10-14-2018)
Old 10-13-2018, 10:33 AM   #19731
KFTH86
Drives: 2017 Toyota 86 Halo
Had the defective head unit replaced at the dealership yesterday. It's still annoying but at least it works better, until I can replace with an aftermarket unit. Then took a nice long drive to upstate NY, heading to Toronto today.
KFTH86 is offline   Reply With Quote
Old 10-13-2018, 05:28 PM   #19732
mrg666
pessimistic skeptic
mrg666's Avatar
Changed oil and installed the Scion (sliding) armrest. Armrest height is just right for me and I can slide it back when cup holder is needed. So useful!
Old 10-14-2018, 01:02 AM   #19733
Carsnguitars
Drives: 2014 FR-S
Did you find the bushings raise your ride height? I've been thinking of putting these in, but not if they raise the car, even if only a little.
Carsnguitars is offline   Reply With Quote
Old 10-14-2018, 01:48 AM   #19734
Wes
Good question, I haven't even checked. Looking at the before and after pictures, it appears so
Before:
After:
Although keep in mind the after pic is taken from a higher angle and the lighting is different.
Instagram: @gt86ws
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post:
mrg666 (10-14-2018)
Old 10-14-2018, 02:07 AM   #19735
jflogerzi
jflogerzi's Avatar
where did you buy yours?
2013 Series 10 FRS #553
Old 10-14-2018, 02:09 AM   #19736
jflogerzi
jflogerzi's Avatar
Before:
After:
looks much better. Just flows much better with the cars lines
The Following 2 Users Say Thank You to jflogerzi For This Useful Post:
MJones_RB (10-15-2018), StraightOuttaCanadaEh (10-14-2018)
Old 10-14-2018, 07:36 AM   #19737
mrg666
pessimistic skeptic
mrg666's Avatar
Amazon
Old 10-14-2018, 08:07 AM   #19738
mrg666
pessimistic skeptic
mrg666's Avatar
Before:
After:
Tail lights look great red on red!
The Following User Says Thank You to mrg666 For This Useful Post:
Old 10-14-2018, 02:04 PM   #19739
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
How difficult was it to install? I've had one in the box in my garage for 3 years now.
Old 10-14-2018, 02:52 PM   #19740
mrg666
pessimistic skeptic
mrg666's Avatar
It is easy. Somebody posted the instructions before me.
https://www.ft86club.com/forums/showthread.php?t=82059
You will need
- riveting tool
- T20 socket bit
- 5mm and 8mm drill bit
I hope you didn't lose the templates included in the package. There were no instructions included, but information in the above thread was enough. Once you mark the two initial holes with the templates, you can align the rails and mark and drill the rest of the holes using the holes on the rails. It took 30 mins tops.
Sapphireho (10-14-2018)
