Old 10-10-2018, 05:03 PM   #407
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Originally Posted by SuperTom View Post
17x9 +45 sounds great for the front, Ive seen +35 and its borderline too much poke for me.
I might do 17x9 +45 front
17x9 +35 rear with 245/40/17 all around
It would be a square tire setup but I guess you could call it stagger offset
17/9/+45 with no spacer and a 245-40-17 tire will rub the fender liner at full lock. I've got a 5mm spacer on my set at all corners, nbd because I had already switched to extended studs before getting the wheels. 3mm spacer might be enough per @Leonardo not sure
The car already has a wider track in the rear, one of the things on my to-do list is to swap spacers around and see if it noticeably affects handling, I'm certainly happy I can rotate front to rear to help even out the wear. But hey if it's just for looks then you do you.
ineedyourdiddly
Old 10-10-2018, 05:36 PM   #408
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
Ok so your saying the 17x9 +45 sits too close inside I don't want to rub. Wanted to go with staggered offsets so I wouldn't need spacers in the rear to be flush since there seems to be about a 5-10mm difference in flushness front to rear.
Semi doing for looks but more a trackable DD setup that is grippier than my current 17x8 +40 konig hypergrams that sits a bit more flush without spacers.
Maybe now considering 17x9 +40 Konig Dekagrams. A little heavier at 17.3lbs but still not too bad. And slap some 5mm spacers on the rear
SuperTom is offline   Reply With Quote
Old 10-11-2018, 12:01 PM   #409
strat61caster
I haven't tried it yet but changing wheel offsets does change handling, you may be trading performance for looks.
ineedyourdiddly
SuperTom (10-11-2018)
Old 10-11-2018, 04:35 PM   #410
SuperTom
SuperTom's Avatar
Yah im probably overthinking the whole poke on the front thing.
Here you go TWS Motorsport T66-F 17x9" +40 5x100
Should have less poke up front, Then throw on a 5mm spacer on the rear or just keep it how it is
https://www.fastwrx.com/products/tws...-17x9-40-5x100
Old 04-22-2019, 10:25 PM   #411
Protege13
Drives: Mazda Protege 2003
I bit the bullet and gambled on white RPF1's from Oakos. Wasn't sure how it'd turn out, but I think they look quite nice. 17x9 , 35 offset. Wrapped in Hankook V12 Evo2's ... 245/40
Now I just want to lower her a bit.
Protege13 is offline   Reply With Quote
Old 04-23-2019, 12:44 AM   #412
Will BRZ
Damn that's crazy...
Drives: 2015 BRZ
That’s stock suspension then? I have a white BRZ and I really want some Enkei wheels. I was going for the Raijins as they’re more in my price range but I really want 17s. I like the more meaty tire and I’d like to keep the 17 inch wheel feel on the car. You’ve made me really consider my decision lol car looks great by the way
Will BRZ is offline   Reply With Quote
Old 04-23-2019, 01:07 AM   #413
Protege13
Yup this is completely stock suspension. I'd like to go lower, but that's gonna have to wait $$
Old 06-15-2019, 02:39 PM   #414
Caboose
Drives: WRB BRZ Premium
Caboose is offline   Reply With Quote
Old 06-18-2019, 10:31 AM   #415
wparsons
wparsons's Avatar
Originally Posted by wparsons View Post
17x8 +45
Powdercoated, "Metallic bead blast bronze"
225/45/17 Dunlop ZII's
Stock height
Got bored of the bronze, they're now candy red over chrome... car is also on KW V3's now.
flickr
Old 06-28-2019, 05:59 AM   #416
Dara321aaa
Drives: 2016 Halo Scion FRS
Originally Posted by Caboose View Post
This looks great!! Whats your specs on wheels and tires?
Dara321aaa is offline   Reply With Quote
Old 06-28-2019, 02:00 PM   #417
Decep
Drives: 2013 FR-S Series 10
Anyone know where to get gunmetal touch up paint? I have a few chips from pebbles n shit in the road.
Old 06-30-2019, 10:46 PM   #418
Caboose
Thanks a lot! 17x9 +35 and 245/40/17. To me the +35 offset is perfect. I was a little worried about too much poke based on some comments, but very happy I stuck with the +35 over +45.
Old 07-02-2019, 07:42 PM   #419
icybrzzz
Drives: 2015 Scion frz
Didn't think I would like silver on silver so much!
L1090849 by Daniel Cocar, on Flickr
icybrzzz is offline   Reply With Quote
Old 07-02-2019, 07:49 PM   #420
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
If you know anyone selling the discontinued size of 7x17 w48 offset in gun metal, give me a heads up. I've been wanting an RPF1 in the oem size badly. I don't want to be stuck with the 17x7.5 size if I can't find the oem size around.
DandoX is offline   Reply With Quote
Wheel Directory: Enkei RPF1 17x9.0 +35 D1cker Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 801 06-18-2024 06:31 AM
Wheel Directory: Enkei RPF1 18x9.5 +38 FRS8SIX Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 297 02-15-2018 03:50 PM
Enkei RPF1 18x9.5 5x100 38mm Offset Black Wheel - Exclusive Tony Angelo Edition Wheel Infamous Performance Wheels and Tires 122 02-13-2014 11:34 AM
Enkei RPF1 17x7.5 +48 5x100 SBC and wheel/tyre question Victor Draken Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 12-19-2013 01:28 PM
Track wheel Enkei RPF1 in 16" ?? stockysnail Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 42 08-07-2013 09:13 AM
