Old 07-15-2014, 08:00 PM   #141
arthur93
Drives: Toyota 86 GTS
I just have a quick question in regards to the benefits of the aluminium and cf driveshafts. I understand how response improves as there is less rotating mass but would that translate into more power at the wheels due to less power and force bring lost due to the reduced rotating mass?
arthur93 is offline   Reply With Quote
Old 10-03-2014, 10:27 PM   #142
ProjectD
ProjectD's Avatar
Drives: '04 350Z/ 2013 LR BRZ (LM)
Bolt Length
I thought i read on one thread (cant find it now) that the stock bolts werent long enough due to the flanges on the alum DS being thicker --- and someone had to replace all 4 bolts with some special-type bolt for the differential end....? Did anyone here run into that issue with this DS?
Note - i have the Aluminum from DSS. Plan to install in 2 weeks.
ProjectD is offline   Reply With Quote
Old 06-02-2015, 03:05 AM   #143
Gopherboy6956
Gopherboy6956's Avatar
Drives: 13 BRZ Limited WRB
Just to dig this thread back up... I have a dss Alum with a stage 2 exedy 3 puck. There's a considerable amount of drive train noise anytime you are either decelerating or cruising, but goes away when you give it lower.
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925
Gopherboy6956 is offline   Reply With Quote
Old 11-18-2017, 04:35 AM   #144
rixter145
Sleep Chomper
rixter145's Avatar
Reviving this thread... any issues with kart boy short shifter for those who have this specific drive shaft?
rixter145 is offline   Reply With Quote
Old 11-19-2017, 05:25 PM   #145
Hawk77FT
Drives: GTS 86
Yes! It wont fit. it will hit the driveshaft.
Hawk77FT is offline   Reply With Quote
The Following 2 Users Say Thank You to Hawk77FT For This Useful Post:
norcalpb (09-26-2018), rixter145 (11-21-2017)
Old 11-21-2017, 06:40 PM   #146
rixter145
Sleep Chomper
rixter145's Avatar
Sigh guess i won't be able to get a one piece drive shaft without grinding down the shifter then...
Old 09-23-2018, 04:48 AM   #147
Decimus
BAE
Decimus's Avatar
Drives: Asphalt FRS
Anyone have issue with IRP shifter and this drive shaft?
Decimus is offline   Reply With Quote
Old 09-25-2018, 04:30 PM   #148
apelpapa
apelpapa's Avatar
Drives: 2013 SPD Black FR-S
I'm also curious about this, I just ordered an irp. How do you like it btw?
apelpapa is offline   Reply With Quote
Old 10-18-2018, 10:46 PM   #149
Stumpygt86
Drives: Toyota GT86. N/A for life
I have just fitted the 3 inch aluminium tailshaft and I have an IRP short shifter. So far there are no issues with anything touching. It is quite close in some areas, but has clearance.
I will be doing a track day over the weekend and can report back after that.
Stumpygt86 is offline   Reply With Quote
Old 01-23-2019, 02:41 AM   #150
Turbo
Drives: FR-S Turbo
Any update on this? Looking for a lightweight driveshaft myself now.
Turbo is offline   Reply With Quote
Old 01-23-2019, 08:16 AM   #151
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
I have the same thing and theres no rubbing
Dr. BRZ is offline   Reply With Quote
Old 01-23-2019, 11:40 AM   #152
Turbo
Drives: FR-S Turbo
Are you running the IRP shifter as well?
Old 08-07-2021, 08:39 PM   #153
Wraith
Drives: 2013
anyone have issues with IRP shifter and axle exchange driveshaft ???
Wraith is offline   Reply With Quote
DIY: Driveshaft Shop (DSS) Carbon Fibre Driveshaft F1point4 DIY (Do-It-Yourself) Guides 67 04-17-2021 06:21 PM
PST vs Driveshaft Shop CF Driveshaft? RehabJeff86 Engine, Exhaust, Transmission 4 08-26-2013 01:39 AM
DriveShaft's and Axle's Driveshaft Shop Engine, Exhaust, Transmission 34 08-21-2013 06:17 PM
Driveshaft Shop CF Driveshaft installed. Hawaiian Engine, Exhaust, Transmission 5 08-13-2013 03:04 PM
GFB 3-Piece lightweight aluminum pulley kit Touge Factory Engine, Exhaust, Transmission 60 06-03-2013 02:52 PM
