#141 |
Drives: Toyota 86 GTS
I just have a quick question in regards to the benefits of the aluminium and cf driveshafts. I understand how response improves as there is less rotating mass but would that translate into more power at the wheels due to less power and force bring lost due to the reduced rotating mass?
#142 |
Drives: '04 350Z/ 2013 LR BRZ (LM)
Bolt Length
I thought i read on one thread (cant find it now) that the stock bolts werent long enough due to the flanges on the alum DS being thicker --- and someone had to replace all 4 bolts with some special-type bolt for the differential end....? Did anyone here run into that issue with this DS?
Note - i have the Aluminum from DSS. Plan to install in 2 weeks. |
#143 |
Drives: 13 BRZ Limited WRB
Just to dig this thread back up... I have a dss Alum with a stage 2 exedy 3 puck. There's a considerable amount of drive train noise anytime you are either decelerating or cruising, but goes away when you give it lower.
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925 |
#144 |
Sleep Chomper
Reviving this thread... any issues with kart boy short shifter for those who have this specific drive shaft?
#145 |
Drives: GTS 86
#146 |
Sleep Chomper
Sigh guess i won't be able to get a one piece drive shaft without grinding down the shifter then...
#147 |
BAE
Drives: Asphalt FRS
Anyone have issue with IRP shifter and this drive shaft?
#148 |
Drives: 2013 SPD Black FR-S
#149 |
Drives: Toyota GT86. N/A for life
I have just fitted the 3 inch aluminium tailshaft and I have an IRP short shifter. So far there are no issues with anything touching. It is quite close in some areas, but has clearance.
I will be doing a track day over the weekend and can report back after that. |
#150 | |
Drives: FR-S Turbo
#151 |
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
#152 |
Drives: FR-S Turbo
#153 |
Drives: 2013
| DIY: Driveshaft Shop (DSS) Carbon Fibre Driveshaft | F1point4 | DIY (Do-It-Yourself) Guides | 67 | 04-17-2021 05:21 PM |
| PST vs Driveshaft Shop CF Driveshaft? | RehabJeff86 | Engine, Exhaust, Transmission | 4 | 08-26-2013 12:39 AM |
| DriveShaft's and Axle's | Driveshaft Shop | Engine, Exhaust, Transmission | 34 | 08-21-2013 05:17 PM |
| Driveshaft Shop CF Driveshaft installed. | Hawaiian | Engine, Exhaust, Transmission | 5 | 08-13-2013 02:04 PM |
| GFB 3-Piece lightweight aluminum pulley kit | Touge Factory | Engine, Exhaust, Transmission | 60 | 06-03-2013 01:52 PM |
