Old 09-14-2018, 04:45 PM   #1
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
tire pressure for 255/40r17
im picking these up tomorrow and want to know what pressure i should be running them at. according to this chart https://www.toyotires.com/media/2125...s_20170203.pdf it says <26psi which seems way fucking low. if my math is right and it has the same contact patch size but just 40 mm wider i should be running somewhere around 29.5 psi
Old 09-14-2018, 05:10 PM   #2
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
That's just for equivalent loading. You can run the same pressure as OE (35 psi) and be confident that the car can handle the same load with extra margin.
Also, if you run TMPS, the car is going to throw you a low tire pressure code anytime you're under 30 psi anyway.
The concept matches up whether you use P-Metric or ISO-Metric measurements
EndlessAzure is offline   Reply With Quote
Old 09-14-2018, 07:34 PM   #3
Breadman
Breadman's Avatar
wouldnt that mean it has the same size contact patch as 215s?
Old 09-14-2018, 07:56 PM   #4
Leonardo
Country Boy 4 Life
Leonardo's Avatar
No.
I LIKE TIRES!
Old 09-14-2018, 08:16 PM   #5
stevesnj
stevesnj's Avatar
I always use the pressure what's on the door sticker. Regardless of different tire size or brand. I never had any abnormal wear or any other issues.
My 2016 Build thread
The Following 2 Users Say Thank You to stevesnj For This Useful Post:
humfrz (09-14-2018), Leonardo (09-14-2018)
Tire Pressure. Tal Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 04-24-2015 12:10 PM
best tire pressure gauge (tire pressure question) steveholt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 03-21-2015 10:27 PM
Hankook Ventus Evo V12 K110 - 245/40R17 and 255/40R17 $40 rebate, wholesale Gruppe-s Wheels and Tires 7 10-21-2014 02:11 PM
what is your tire pressure? abling2 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 06-03-2013 10:49 AM
What Hot Tire Pressure? gbgracer Tracking / Autocross / HPDE / Drifting 24 05-14-2013 05:47 AM
