Old 09-04-2018, 01:59 PM   #85
evomike
Drives: frs
Originally Posted by Yoshoobaroo View Post
No, that's your OPINION.
Also, good enough means jack shit when for the same price you can get a set of coilovers that were actually engineered for the car by reputable companies (ST, Tein).
Most of those coilovers are made next to BC’s and all the other companies
evomike is offline   Reply With Quote
Old 09-04-2018, 02:38 PM   #86
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Suggestions on suspension upgrade over BC
I specifically pointed out ST because they aren't. They're made in Germany at KW facilities with KW parts in ST housings. Not sure about Tein, but their housing looks different from the housings typical for BC/FK/TC Kline/ whatever else they're sold as in different colors.
As soon as I see BC's trademark 32point-adjustment on any other coilover I say run away. If you need 32 levels of adjustment you haven't done anything to tailor the shock to the application.
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
Tokay444 (09-06-2018)
Old 09-06-2018, 09:42 AM   #87
Tokay444
BC coilovers are good enough for 99% of the people that is a fact, the car will drive fine not be bouncy at all and they will not fall apart in a few months. You can keep saying they are the problem here but they 100% are not the root of the problem, OP not getting an alignment and ruining the pre-load is the root of this issue. You can bash the product all you like but all you are doing is telling OP that its the product and not his lack of understanding that changing suspension components and adjusting ride height requires an alignment, it is information and advice like this that leads to people thinking this way. If OP was building a time attack or track car your advice would be well placed and i would agree that the BC's would not suffice but in this thread the issue is not the quality of the strut but OP's lack of understanding.
No.
Exhaust Upgrade Suggestions hosfordbrandon Engine, Exhaust, Transmission 6 03-27-2016 12:47 AM
Looking to upgrade rear sway bar, any suggestions? Str8Ghostin Tracking / Autocross / HPDE / Drifting 8 02-22-2015 10:40 AM
Suggestions for more horsepower! Turbocharger upgrade + more! forzajuve Forced Induction 14 04-10-2013 08:51 PM
Michelin/Enkei upgrade + more. Community suggestions welcome! forzajuve Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 03-29-2013 07:14 PM
