Old 03-18-2018, 04:14 PM   #1
ThatAsianBradah
ThatAsianBradah's Avatar
Drives: Toyota 86 2017 TRD Modded
Grinding Noise When Turning Left
Hi guys, recently I installed a JDL EL Header and JDL Overpipe and when I make left turns (Not hard /hard) I hear a rubbing/grinding sound.
It never happened before the installation. I tried looking underneath on leveled ground; specifically at the brakes and axle joints, but I don't see anything that warrants any worry.
I'll plan on bringing my car to my friends shop where he has a lift and see what's up, but if anyone knows what's going on then that'll be nice. Thank you
Sent from my SM-G950U using Tapatalk
Life is like a car, you press the gas to go, steer around all the things blocking your way through Life, and park it when you reach your destination
ThatAsianBradah is offline   Reply With Quote
Old 03-18-2018, 04:58 PM   #2
ThatAsianBradah
It's good to note that at the same time I changed out my Edelbrock SC pulley to 3.00" and also did bigger fuel injectors with a new Delicious Tune.
The grinding/rubbing noise only occurs on left turns when I'm moving. When I'm stationary or less than 5mph it's not rubbing at all.
Old 03-19-2018, 12:21 PM   #3
jtenks13
Drives: 2015 Subaru BRZ
I have the same issue. I only have a Borla catback exhaust, everything else is stock.
The sound has gotten worse over time and is especially bad when I turn at a higher rate of speed. It is only when I turn left though.
I looked at the CV joints and brakes but didn't find anything either.
I would love to find out what this is, it drives me crazy.
jtenks13 is offline   Reply With Quote
The Following User Says Thank You to jtenks13 For This Useful Post:
ThatAsianBradah (03-19-2018)
Old 03-20-2018, 12:09 AM   #4
I'll guess that it's a bad front wheel bearing ......
Old 03-20-2018, 05:57 AM   #5
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
I wonder if maybe one of the bottom skid plates isn't hitting something. They have to be removed to do the header and OP. When you turn, the caster of the wheel will slightly change your ride height on one side and change the camber too. All that geometry change may be enough to make contact somewhere. Cut the wheel hard and get under the car and poke around
guybo is offline   Reply With Quote
Old 09-06-2018, 01:31 AM   #6
Nissota
Nissota's Avatar
Drives: Subaru BRZ, Nissan 240sx
Have you found a solution to this issue? Im having the same thing after a kiss with a curb... only happens when turning left and after 40mph... vibrate the whole car. Thnx
Nissota
2013 Subaru BRZ DD
1997 Toyota Supra MKIV
1990 Nissan 240sx
www.revvolution.com
Nissota is offline   Reply With Quote
Old 09-15-2018, 10:13 PM   #7
J1Avs
Drives: 2018 BRZ tS
Another Bump. Experienced a similar issue during an intro HPDE Event while turning left
J1Avs is offline   Reply With Quote
Old 03-20-2023, 11:55 AM   #8
scottybeamsmeup
Drives: 2013 subaru brz
how did you fix your issue i just kissed a curb two weeks ago and replaced the steering rack and having the same issue
scottybeamsmeup is offline   Reply With Quote
Clicking/cloncking from left front when turning wheels cawith Issues | Warranty | Recalls / TSB 14 02-08-2019 05:14 AM
AUTO FRS, GRINDING/VIBRATION FROM UNDERNEATH WHEN TURNING?? Charleswinky Issues | Warranty | Recalls / TSB 11 04-04-2015 02:21 PM
Heavy steering when turning left... Venator Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 03-10-2015 03:07 PM
Grinding noise? frs10 Issues | Warranty | Recalls / TSB 7 09-20-2013 10:57 AM
metalic screeching turning left raptor87 Issues | Warranty | Recalls / TSB 2 01-18-2013 01:41 PM
