Old 09-05-2018, 02:35 PM   #29
kch
Senior Misanthrope
kch's Avatar
Originally Posted by Somerandom18 View Post
Pick up a used 2017+ header. They weren't UEL buy will still pass emissions and I bet they'll help performance wise considering the changes.
Sent from my Pixel XL using Tapatalk
OP already has a 2018.
Old 09-05-2018, 02:48 PM   #30
Lantanafrs2
Drives: 2013 frs red
You'll only be bothered by ca emissions. Swapping header and tune to stock isn't that much work and you won't have to do it often. In your case id recommend oft for tuning.
Lantanafrs2 is offline   Reply With Quote
The Following User Says Thank You to Lantanafrs2 For This Useful Post:
FRSBRZGT86FAN (09-05-2018)
Old 09-05-2018, 03:29 PM   #31
teetsdownlow
Drives: 2015 FRS
Ask them if they can source a HJS converter. One of if not the best on the market. Will be pretty expensive though. If you want to lower noise for less than a new catback then check out dynatech auger muffler.
With an aftermarket manifold you won't pass visual.
I went catless due to the price and less than ideal cat converters used in the catted versions. Haven't had a problem driving past CHP or local police. UEL, stock over/front pipe, and N1 catback.
If you're willing to compromise on some things then we can find a good set up for you
teetsdownlow is offline   Reply With Quote
Old 09-05-2018, 07:34 PM   #32
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by Scala View Post
As far as CARB and the CA DMV issue goes, there are certain Zip Codes within six CA counties that require the STAR smog inspection ONLY for change of ownership registration.
Since you're trying to do this legally, just be aware that if you take an (originally) out of state vehicle and attempt to register it in CA for the first time, you will need to smog the vehicle.
Just because you're in an area exempt from renewal smog doesn't mean you are exempt from first time registration smog.
-alex
The Following 2 Users Say Thank You to mav1178 For This Useful Post:
FRSBRZGT86FAN (09-05-2018), Scala (09-05-2018)
Old 09-05-2018, 08:27 PM   #33
jflogerzi
jflogerzi's Avatar
You should really listen to people here. There is zero chance your car will pass emissions testing in CA legally. Inspection might be different but if you are forced to register it here then you will be forced to smog and fail. I would recommend getting a catless header and keeping the rest of the exhaust stock so you can keep secondary cat and get a oft and sadly swap back and forth. Swapping a header is easy with hand tools jack and stands
2013 Series 10 FRS #553
The Following 2 Users Say Thank You to jflogerzi For This Useful Post:
FRSBRZGT86FAN (09-05-2018), TofuJoe (09-06-2018)
Old 09-05-2018, 08:46 PM   #34
ShansBRZ
Drives: 2017 brz
I have the ft86 speed factory catted header with the stage 2 oft tune and it’s great.
ShansBRZ is offline   Reply With Quote
Old 09-05-2018, 09:48 PM   #35
Lantanafrs2
20 horsepower and a normal torque curve make a big difference with these cars. Even better if that header is blowing into a snail.
Scala (09-05-2018)
Old 09-05-2018, 11:12 PM   #36
Scala
Drives: 2018 BRZ tS
What is a snail?
Following the advice of many ^^^ I took a good look this afternoon at what is involved in changing headers on these cars and I have to agree that the degree of difficulty is relatively low. My jackstand days are long behind me but solutions can be found.
Important questions remain as to the oxygen sensors, the CELs, the noise level, the sound quality, the fit to the OE exhaust. I've heard such cars and their infernal noise is not something I'd be willing to live with, power be damned.
This is OK at idle but too loud during acceleration:
[ame]https://m.youtube.com/watch?v=ebSeY0PZxyQ[/ame]
As for the OFT this is what is beyond my capabilities:
[ame]https://m.youtube.com/watch?v=2447SCe7s40[/ame]
Scala is offline   Reply With Quote
Old 09-06-2018, 12:55 AM   #37
ShansBRZ
Drives: 2017 brz
I have the stock exhaust with mine and it’s not really any louder than having the stock header.
I believe the snail in reference is a turbo.
The oxygen sensors were taken from the OE header and went into the speed factory header with no issues.
No check engine lights in the two months that the header has been installed.
No issues fitting up to the stock exhaust parts.
The Following User Says Thank You to ShansBRZ For This Useful Post:
Scala (09-06-2018)
Old 09-06-2018, 07:27 AM   #38
Scala
Drives: 2018 BRZ tS
Really helpful and I thank you.
Old 09-06-2018, 07:57 AM   #39
Lantanafrs2
Snail is a turbo
Scala (09-06-2018)
Old 09-06-2018, 07:58 AM   #40
Lantanafrs2
If intake is stock you shouldn't have to rescale. Dont put the cart before the horse lol.
Scala (09-06-2018)
Old 09-06-2018, 08:01 AM   #41
Lantanafrs2
My header is catless. Rest of exhaust is stock. Very little sound difference if any at all.
Scala (09-06-2018)
Old 09-06-2018, 11:44 AM   #42
Scala
Drives: 2018 BRZ tS
Good to know. Even under hard acceleration?
catted header or catted front pipe? gabeg86 Engine, Exhaust, Transmission 28 10-13-2015 12:32 PM
JDL Catted UEL header VS ft86speedfactory catted UEL Teclis Engine, Exhaust, Transmission 4 05-28-2015 02:19 PM
Catted header or catted front pipe? wilfredwong Engine, Exhaust, Transmission 5 02-09-2015 06:11 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 05:42 PM
Recommend me a catted front pipe? TwinturboCamry Engine, Exhaust, Transmission 20 11-22-2013 11:22 AM
