Northwest AK, ID, OR, WA
Old 09-03-2018, 02:56 PM   #15
LeonardoDaVinny
NotVinnyy
Drives: 2013 White Pearl FRS
Originally Posted by SuperTom View Post
Lesson learned to always allow extra time and do more research before doing mods. Your in a rush and probably overlooking something easy. Pic you posted doesn't work for me. Good luck!
Yes, that is true. Though, I did go through almost every tutorial before I proceeded. :/
LeonardoDaVinny is offline   Reply With Quote
Old 09-03-2018, 03:03 PM   #16
n0thing
Drives: Subaru BRZ
I don't think it has much to do with the sway bar. Are the struts assembled correctly? The three nuts mounted on the top tower? The lowering spring should actually make the strut to sit shorter/higher. Get a long pry bar, perhaps with buddy, and push down on the LCA.
n0thing is offline   Reply With Quote
Old 09-03-2018, 03:37 PM   #17
LeonardoDaVinny
NotVinnyy
So apparently there was something stuck under the rotor so it did not go down all the way. I appreciate the help! Now to the rears..
Old 09-05-2018, 06:26 AM   #18
Chen
Regional Moderator
Chen's Avatar
Drives: 00-AP1 20-A90 06-Z33 07-FA5 93-NA1
I went over there to help with what I could. We got the struts out, but the install didn’t go as planned. We couldn’t get the lca back onto the car. Every time we tried to put it back. The last bolt didn’t line up. After 3 hours ish I had to leave have work in a few hours. Anybody able to give this guy any ideas?
Chen is offline   Reply With Quote
The Following 2 Users Say Thank You to Chen For This Useful Post:
Leonardo (09-05-2018), LeonardoDaVinny (09-09-2018)
Old 09-05-2018, 01:17 PM   #19
johan
Drives: '14 981CS, '99 NB1
Did you release the e-brake? If the e-brake is on, it can force the rear suspension to contort in weird ways.
johan is offline   Reply With Quote
The Following 2 Users Say Thank You to johan For This Useful Post:
LeonardoDaVinny (09-09-2018), Ultramaroon (09-05-2018)
Old 09-05-2018, 01:37 PM   #20
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
^that. My car stayed on jacks overnight when I learned this the hard way lol
Old 09-05-2018, 06:05 PM   #21
Chen
Regional Moderator
Chen's Avatar
that i didn't try. i didn't even think of that since the car was already in the air when i got there.
Old 09-05-2018, 06:29 PM   #22
You are THE MAN!
Old 09-05-2018, 06:32 PM   #23
Urgent help requested on exhaust install Vdub Engine, Exhaust, Transmission 8 05-20-2017 09:13 PM
new springs install help Bigedb Arizona 4 03-13-2015 08:08 PM
First time Springs Install... Help please VakaGT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 11-28-2014 08:58 PM
Install new springs? Intake Northern California 3 10-05-2013 01:55 PM
How much should it be to install springs? MiniGuy CANADA 28 05-07-2013 09:44 AM
