Old 08-31-2018, 01:53 AM   #1
Aphaux
Aphaux's Avatar
Drives: Silver 2013 BRZ
Crank pulley spacer removal; help.
I am rebuilding the front of this brz, replacing the crank pulley SPACER is proving difficult. The pin broke off inside the spacer, ive been trying to pull the spacer out but with all my might to no avail.
Any help much appreciated. Thank you.
Aphaux is offline   Reply With Quote
Old 08-31-2018, 02:39 AM   #2
I don't know what you mean by the crank pulley "spacer".
This reference may help...
https://www.ft86club.com/forums/showthread.php?t=12583
Old 08-31-2018, 09:19 AM   #3
chipmunk
Drives: _
Might these help...?
chipmunk is offline   Reply With Quote
Old 08-31-2018, 02:45 PM   #4
If the clocking pin sheared during the impact there may be other internal damage. I can sympathize with wanting to dig as little as possible but I suggest making peace with the idea that further disassembly may be unavoidable.
Old 08-31-2018, 02:59 PM   #5
THIS ^
The spacer should pretty much just slide out. If it was hammered in hard enough to break the pin it is pretty safe to say there is going to be a mess in there. That spacer has several functions.
http://www.ft86club.com/forums/showthread.php?t=26386
Old 08-31-2018, 03:23 PM   #6
Aphaux
Aphaux's Avatar
i was ready to accept digging deeper, was really hoping i didnt have to and delay the build further but i think its for the best, especially since the spacer doesnt just slide out.
thanks
Old 08-31-2018, 03:25 PM   #7
thanks
I hope it's just a little shit on the crankshaft but...
Good luck! Have a great weekend and keep us posted.
Old 09-01-2018, 02:26 AM   #8
thanks
You might try heating up the area around the spacer with a torch. Maybe the heat will loosen up the spacer and the heated (expanded) area around it will allow the spacer to slide out -
Old 09-01-2018, 02:38 PM   #9
xwd
Having tried to actually remove the pin and drill it out at one time, I can't imagine how hard of an impact hit it was to actually break it. And yes usually people have problems with that spacer coming out _too_ easily. What happened with it?
Old 02-10-2019, 05:59 PM   #10
Aphaux
Aphaux's Avatar
Crash. Rebuild is now in progress, took a while...
[GA] FS: NEW Grimmspeed Lightweight Crank Pulley (NIB) + OEM Crank Pulley Bolt reeves Engine, Exhaust, Bolt-Ons 0 08-22-2018 07:01 PM
FS: OEM CRANK PULLEY SET gt86ser Engine, Exhaust, Bolt-Ons 0 07-10-2018 01:45 PM
e-brake removal, spacer to remove backplate puma Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 03-31-2014 06:48 PM
Perrin crank pulley / Beatrush alternator pulley Krimlin Engine, Exhaust, Bolt-Ons 7 08-26-2013 10:12 AM
NEOPLOT Crank pulley Alternator pulley& Waterpump pulley ANREX Engine, Exhaust, Transmission 10 10-25-2012 07:45 PM
