#15 | |
Drives: _
#16 | |
Drives: _
#17 |
Drives: 13 BRZ, 97 e36 M3 Rides: '07 600RR
More or less. NA, just a tune and full exhaust, nothing to really pushing the limits. Clutch was changed to an exedy oem during the TOB replacement. I didn't feel the need to go stage 1 or 2.
As for clutch wear, I've brought it to the track maybe a half dozen events (typically 2 days) and autox'd for about 5 yrs on the original clutch in addition to daily driving. Launches for autox were typically done ~3.25k rpm with a moderately quick clutch release to minimize wear. IMO the performance driving did not wear the clutch excessively to go out at 70k if that's what you are asking.
#18 |
Drives: _
... Just curious whether the bearing was designed to last even with OEM powertrain.
Surprised that there isn't a lawsuit against Subaru/Toyota about it yet! |
#19 |
Drives: 2016 Oceanic, "base" model
So, I just got my 2016 FRS back from the dealer after having the TOB replaced. I can confirm that the original TOB does not look like either picture. I looked at the invoice and it had the upgraded TOB part number. So, thanks to the members here I am happy to know I got the right bearing. The weird thing is, when I first talked to the service concierge (?) (the first guy who points you to the actual service writer) he said he had never heard of a TOB going out so early, although he admitted he didn't see many FRSs. OTOH, the service writer called the parts desk and told them to "be sure it was the upgraded part they had in stock" so he must be quite aware of the problem.
When I picked up my car, both of them told me the bearing was REALLY messed up. But it doesn't look really messed up; just messed up. I was expecting it to be wobbly or bent or something. But it "just" spins freely. It's a little loose but it sounds dry as hell. I didn't have them change anything else because I eventually want to install a lightweight flywheel. Didn't see point in spending another $350 for new clutch, pressure plate, and machined stock flywheel. In the end, it cost $820. |
#20 |
Lawsuit for what? They recognized the design issue and corrected it. If it fails within warranty they replace it free. If it fails out of warranty it is like any other wear part in any car. People really feel a need to sue over a $100 repair? No wonder cars cost so much. Foolish.
#21 | |
Why did it cost you anything? Are you out of warranty?
#23 | |
Because compromise ®
Drives: Red Herring
*shrug*
#24 | |
Drives: _
Yes it is a bearing, a wear item. But it still shouldn't fail within 11k miles on a stock clutch. Or at least, should be considered under 5yr/60k |
#25 |
Drives: 2014 GT86
chipmunk: but if one failed for eg. you, but worked fine for 60K+ miles for 200 other owners, is lawsuit really THAT justified? That sue everybody for anything attitude is reason why in US everybody now can have only lukewarm coffee at McD & starbucks. So we now need overengineered cars too at double cost to incorporate into price much higher then necessary strength, by extra order reduced failure rate and for potential lawsuits costs against manufacturers, right.
| The Following User Says Thank You to churchx For This Useful Post: | Tcoat (09-03-2018) |
#26 | |
Drives: White 86
#27 |
Drives: 2014 GT86
Twins MT transmission is adequate for cars in stock form. Very similar aisin AZ6 trannies are also in other cars in somewhat similar class cars like RX7, S15, MX5, S2000. So you turbo car way out of power & torque it was engineered for and complain about weak tranny? Please provide statistics about enormous failure rate for twins tranny prior calling it weak. Eg. by data from these dealerships, every 10th has their tranny failed and such after unreasonably short mileage. And that from those, that had failed transmission, majority just daily driven, with insignificantly small number abusing it via forced induction/track use and such. Then i'd be convinced that indeed, twins tranny is too weak and sucks too much and it's snafu of toyobaru.
Even FA20 engine main difference from predecessors like EJ20 was risen efficiency .. by removing extra excess material from multiple engine parts to lessen losses and lower weight. Should we fault toyobaru too that we cannot get 500hp from it if it never was sold non-NA? Should we fault it for oiling & fueling problems on slicks on track with high side-Gs, if it was never sold as race car? From text after claim of "weak tranny" it seems that you are about not weakness, but rather about something like hard to shift into second or alike, or hard to shift in general due some clutch drag? Yes, it would be nice without such common for twins ill-trait as hard 2nd when cold, but as it's mostly about cold engages during first drive and goes away after short drive, imho it's severity is overblown. Or you are talking about some specific problem that you had but others didn't or specific bad dealership problem you had, but you still generalize and write off car model as bad in general everybody else should stay clear of and avoid at any cost? Is this car faultless? Hell no. Is it good overall package in it's class for it's price if i weight out pros & cons? It is (at least in my subjective view). I just don't think that some of suggested "ways to fix" such as mass action lawsuit to toyobaru, or design changes that will feature as byproduct steep price increase, will rob some of it's pros, would be smartest choice by toyobaru to make. I wouldn't consider this car if had weighted 200kg more. I wouldn't consider this car if it had costed at 1.5-2x cost. And i wouldn't blame toyobaru as manufacturer if my gt86 fails due me putting much more abuse willingly (such as overboosting w/o accompanied mods to eng.internals/tranny/clutch and so on, or tracking w/o oil cooler & better brakes and so on). Twins are NOT racecar. They weren't designed/engineered/manufactured as such. I'd call them rather "good enough", "good price/performancy", "good value" car that provides me unexpectedly lot of fun for money they cost. Your experience was different, bad luck. But is generalization warranted that they all are bad and every owner goes through many hardships like you did? Last edited by churchx; 09-03-2018 at 01:45 PM. |
| The Following 2 Users Say Thank You to churchx For This Useful Post: | cjd (09-04-2018), Ultramaroon (09-03-2018) |
#28 |
Drives: 2013 frs red
They don't call em throw out bearings for nothing
| The Following User Says Thank You to Lantanafrs2 For This Useful Post: | gravitylover (09-03-2018) |
| Throw out bearing comparison old vs new | Trueweltall | Engine, Exhaust, Transmission | 59 | 07-21-2022 11:36 PM |
| Melted Throw Out Bearing | danthedirt | Issues | Warranty | Recalls / TSB | 59 | 01-25-2018 05:32 PM |
| Throw out bearing | Hyp | Northern California | 26 | 03-13-2017 11:42 PM |
| Throw-out bearing | mhigham | Issues | Warranty | Recalls / TSB | 71 | 08-18-2016 10:21 AM |
| Noisy throw out bearing | jp_r6 | Issues | Warranty | Recalls / TSB | 23 | 08-18-2016 04:45 AM |
