Old 08-28-2018, 05:43 PM   #1
localhost
Drives: Edelbrock SC 2015 FR-S 6MT
High negative LTFT OFT Stg1 tune
Hello folks,
Some more weird issues with my car (I had an IAM issue a few weeks ago as well). I was driving along a few days ago and I hear my OFT trigger the alarm for high LTFT. I haven't had the chance to datalog yet, but it was going below -10% (my alarm trigger point) at low throttle low-RPM scenarios. Backing off the throttle at that point seemed to make the alarm stop, but it kept happening a few times.
This was in 3rd gear about 15-20% throttle at around 3000RPM. I believe it also happened again in 4th gear, but I'm not sure. This was yesterday, and I've been having the same issue during my morning commute today as well. I'm running the OFT Stage 1 tune with 94 octane.
I will attach datalogs in a few hours after I go home. Any idea what is causing this? I don't think its an exhaust issue since my LTFT is negative and seemingly gets worse with more throttle, and not the other way around. Plus my exhaust is completely stock. Only modification on the car is the tune and a K&N drop in filter. Car has about 36k KM on it so I can't imagine very many things are worn/degraded yet.
Thanks for any help
EDIT: Datalog: https://datazap.me/u/rb28dett/ltft-1?log=0&data=1-2-9
It happened twice on my commute back and both it happened almost immediately after I backed off about 50% throttle.
localhost is offline   Reply With Quote
Old 08-28-2018, 05:54 PM   #2
tomm.brz
Drives: brz 2017 hksv2
scale the maf with the tool
Old 08-28-2018, 08:36 PM   #3
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
The STFT were compensating and your total trims were on point. I think it was just the heat. Increase your trigger point
You don't even have to monitor any of this, you're just panicking yourself over nothing. You haven't done any hardware mods, turn it all off and just drive.
guybo is offline   Reply With Quote
The Following User Says Thank You to guybo For This Useful Post:
localhost (08-29-2018)
Old 08-29-2018, 02:22 PM   #4
localhost
I completely forgot to check the total fuel trims... That makes perfect sense now.
You're absolutely right though - I need to leave the OFT at home and just drive...
high ltftf, ltft, oft, tune
High negative STFT and LTFT 86TOYO2k17 Issues | Warranty | Recalls / TSB 22 09-30-2025 03:10 PM
LTFT high/low? Sel_brz17 Software Tuning 3 05-08-2018 06:48 PM
Super High LTFT +36.77% at idle? (E85 with OFT tune) D4FD Software Tuning 11 09-05-2017 02:24 PM
High Negative LTFT on N/A BRZ causing idling issues paintdude258 Software Tuning 57 03-26-2017 08:14 AM
LTFT High, Stock Tune and Stage 1 93 Bushhy Software Tuning 0 03-11-2017 01:34 PM
