Old 08-24-2018, 07:00 PM   #15
Kodename47
Kodename47's Avatar
Drives: UK GT86
The TPS isn't changing but for some reason the ECU outputs for throttle angle does hange. Not ever worked out the correlation but it's down to the ECU and not the throttle.
.: Stealth 86 :.
Kodename 47 DJ:
Old 08-24-2018, 10:55 PM   #16
Tristor
Tristor's Avatar
It seems to be improving in throttle response, but it feels odd in other ways. I may just need to readjust, so I'll give it a little more time, but if I'm not enjoying it by the middle of next week I'll flash back to stock and sell the OFT.
Tristor is offline   Reply With Quote
Old 08-24-2018, 11:35 PM   #17
ermax
ermax's Avatar
Anytime I reset or flash it take my car about 200miles to settle in. My throttle response will be really inconsistent. Especially when blipping for a downshift. Sometimes you blip and it’s like the car totally ignores you and doesn’t rev at all. My idle also dips and oscillates real bad while learning.
Hang in there, it gets better.
Old 08-25-2018, 06:17 AM   #18
steve99
Drives: FT86
As other said after flashing or resetting ecu the first part of throttle response is a bit "dead" feeling.
a few drive cycles usually fixes it.
also try cycling ignition a few times at 15 second intervals
If you don't like the throttle feel with the oft tune then copy back the standard drive by wire throttle tables from a stock rom. The oft tune does modify throttle feel due to these table changes. But those throttle tables are safe to put back to standard.
It also changes fuelling timing cam timing
Old 08-25-2018, 06:52 PM   #19
Kodename47
Kodename47's Avatar
Drives: UK GT86
1. Do pedal reset/calibration procedure
if that doesn't fix it
2. Copy the stock pedal settings over to the tune and then do the pedal reset/calibration procedure.
Job done, no need to sell your beloved OFT.
.: Stealth 86 :.
Kodename 47 DJ:
Old 08-28-2018, 02:00 PM   #20
mizzta21
mizzta21's Avatar
Drives: 2014 whiteout, scion fr-s
I went back to v2 tunes, better throttle response especially in the lower rpm range imo and it seems to pull better. ive been on the v4 tune ever since they came out...the only thing I will miss from the v4 tune is the quiet cold starts.
mizzta21 is offline   Reply With Quote
Old 08-28-2018, 03:54 PM   #21
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Do you not know how to use romraider? Simply add in the quiet cold start and other little features....
Old 08-28-2018, 04:15 PM   #22
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
If you flash the ECU back to stock, the same thing will happen again. Every time you flash or reset the ECU, it happens. Believe me, I flashed my ECU many times when I had my OFT. It happened every single time no matter what tune I was flashing to or from. Last night, I went to start my car for the first time in 3 weeks, the battery was dead, so I jumped it, and it's now it is doing the same thing since the ECU reset. It's not a big deal.
BigTuna is offline   Reply With Quote
Old 08-29-2018, 04:17 PM   #23
mizzta21
mizzta21's Avatar
I tried, I copied what was done in the v4 tune to the v2 but it made my car run rough after the ecu learned, maybe I did something wrong not sure. ill come back again to see what changes I can and cannot make.
Old 08-29-2018, 04:31 PM   #24
FRSBRZGT86FAN
Yea you definitely did something wrong
Make sure your using the v2 tune and right definitions and copy what the quiet cold start does from the forum not from the v4 tunes. Also I reccomend having it using DI at idle if possible.
Old 08-29-2018, 07:38 PM   #25
Tristor
Tristor's Avatar
Just to come round on this, I kept the tune on the car. It eventually seemed to behave better and what quirks remain I've just gotten used to.
Old 08-30-2018, 01:58 AM   #26
gt86yasss
Drives: White 86
I noticed it when I first loaded the v4.0.3 tune on the car two months ago, and it didn't go away.
gt86yasss is offline   Reply With Quote
Old 08-30-2018, 02:37 AM   #27
Spawn_Of_Creation
Human
Drives: 2015 BRZ Black
Use this thread for help.
http://www.ft86club.com/forums/showthread.php?t=74754
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
Spawn_Of_Creation is offline   Reply With Quote
Old 09-19-2019, 09:54 AM   #28
FR_STEEZ
Drives: 2017 toyota 86
Same. It bothers me
FR_STEEZ is offline   Reply With Quote
Improve throttle response ChrisD BRZ First-Gen (2012+) — General Topics 80 10-05-2020 07:50 PM
OFT throttle response MyGT86Yas Software Tuning 6 02-26-2018 05:44 AM
Throttle Response CamryDS Northern California 27 03-31-2015 03:35 AM
poor throttle response Djen Engine, Exhaust, Transmission 21 06-14-2014 01:22 AM
How's the throttle response? SFTiofoso Scion FR-S / Toyota 86 GT86 General Forum 9 08-14-2012 11:50 AM
