Old 08-22-2018, 09:06 PM   #15
Freerider
Drives: 2015 f150 crew cab 4x4 '13 FRSraven
Originally Posted by SuperTom View Post
Wait what is going on here? you quoted yourself and called yourself an asshole
I hit quote on the wrong post. Probably a good thing. I'm not very forum savvy. And I called no one an asshole, just said come off as. Maybe he wasn't being a smartass, but I doubt it.
Freerider is offline   Reply With Quote
Old 08-22-2018, 10:49 PM   #16
RJasonKlein
RJasonKlein's Avatar
Drives: 2013 Scion FR-S 10 Series
Originally Posted by radroach View Post
Perrin Shift Stop: I didn't realize I needed this. This gets rid of the weird feeling when you're upshifting but not sure if you put it all the way into gear.. this makes it much more comfy. Shifts go in with a bit of a clunk which is satisfying. I hope this part wears well and that I won't have to regrease it often.
I searched the Perrin website and it looks like the Shifter Stop fits the WRX, but not our cars - how did you get it to work?
RJasonKlein is offline   Reply With Quote
Old 08-22-2018, 11:19 PM   #17
churchx
churchx's Avatar
Drives: 2014 GT86
For twins from Perrin there was transmission mount & bushing, not "shifter stop". Those together create imho similar feel (at cost of some NVH increase reduce play/slop, enhance shifting feel)
Old 08-23-2018, 06:53 AM   #18
radroach
Drives: car
@gpvecchi I think the shift-stop will work with an STi mount. They're two separate parts bolting to different things. I'm planning to switch to an STi mount in a coming upgrade.
The Following User Says Thank You to radroach For This Useful Post:
gpvecchi (08-23-2018)
Old 08-23-2018, 09:18 AM   #19
radroach
Drives: car
2nd day of driving with the whiteline mount, I'm becoming iffy on whether or not it's right for me. When its cold it really is noticeably harsher, but upshifts and 1st gear starts are so much better.
I am hoping the STi mount will be a bit more compliant, I'm going to try that next.
The Following 2 Users Say Thank You to radroach For This Useful Post:
kevaughan (10-11-2022), norcalpb (08-23-2018)
Old 08-23-2018, 04:26 PM   #20
gpvecchi
gpvecchi's Avatar
Just to understand, the Perrin tranny things just limits left/right/front/back movement as the insert is more precise in rubber hole, at the cost of whining in low gears, right?
It's the Whiteline insert that limits up/down movement.
So the STi mount, using more and harder rubber should make the same thing of both, but without being so extreme...
Old 08-23-2018, 06:03 PM   #21
radroach
Drives: car
@gpvecchi I am not having much of a problem with whining gears. It's more engine vibration being transferred into the cabin.
The whiteline insert is a bit too stiff for me. I placed an order for an STi mount, but then found out it would be stiffer than the whiteline solution, so cancelled that order; now have ordered a new OEM transmission mount to swap in. I think having a new stock mount should be as compliant and sporty as I need right now.
The Perrin rear stop shift is great, I am enjoying it.
The Following 3 Users Say Thank You to radroach For This Useful Post:
gpvecchi (08-24-2018), kevaughan (10-11-2022), norcalpb (08-23-2018)
Old 08-24-2018, 12:20 PM   #22
radroach
Drives: car
Anybody know where I might put some dynamat down to cancel out some of this extra vibration?
Old 08-24-2018, 12:53 PM   #23
gtengr
Drives: 2017 BRZ
What is the basis for that conclusion?
gtengr is offline   Reply With Quote
Old 08-24-2018, 01:06 PM   #24
radroach
Drives: car
@gtengr
Subispeed.com customer service told me the JDM STi transmission mount would be stiffer than the whiteline bushing + OEM transmission mount.
gtengr (08-24-2018)
Old 08-24-2018, 02:49 PM   #25
norcalpb
norcalpb's Avatar
@gtengr
Yeah, I’ve read that STi bushings are very stiff. I always thought it was like adding ///M parts to a 3 series, but STi rubber is even stiffer than that.
Old 08-24-2018, 03:55 PM   #26
gtengr
Drives: 2017 BRZ
@gtengr
Interesting. I was tempted to try the whiteline insert before going sti but I have a general dislike for poly and wanted to avoid buying/doing the work twice. I'll have to give an insert for the trans bushing more consideration next time.
Old 08-24-2018, 05:14 PM   #27
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
I’m actually a fan of the increased vibration and noise. It isn’t loud and is like a super mild dog gear box sound, plus, I love the extra vibration and feedback.
The Following 2 Users Say Thank You to Irace86.2.0 For This Useful Post:
guybo (08-28-2018), RJasonKlein (08-24-2018)
Old 08-24-2018, 07:02 PM   #28
RJasonKlein
This basically echoes my thoughts, although I freely admit most wont share my opinion. My car is a no-compromise warm weather toy and the direct feeling I get from spherical joints, engine and transmission mounts. and bushings throughout the car really makes the car feel unlike any other sports car I’ve ever owned. This car is telepathic in ways my old Porsches and BMW M cars never were, and some of them were pretty heavily modified. For what I do with the car, I absolutely love it.
The Following User Says Thank You to RJasonKlein For This Useful Post:
Irace86.2.0 (08-24-2018)
Perrin Transmission Support & Whiteline Gearbox Positive Shift Kit jehu Suspension | Chassis | Brakes -- Sponsored by 949 Racing 66 12-14-2017 03:12 PM
Perrin Transmission Mount+Shift Bushing, Whiteline Positive Shift Kit zohaib Transmission and Driveline 5 03-08-2017 11:51 PM
FS: Whiteline Positive Shift & Perrin Rear Shifter Bushing + Whiteline Front Diff Bus neilvosko Brakes, Suspension, Chassis 1 11-21-2016 02:44 PM
Whiteline positive shift kit and perrin shifter bushing review Raven604 Engine, Exhaust, Transmission 7 04-30-2015 04:10 PM
FS: Whiteline bushings KDT926 (Positive shift kit) & KDT922 (Positive traction kit) Tim_Asphalt_FRS Transmission and Driveline 3 09-26-2014 11:41 AM
