Old 08-20-2018, 08:37 PM   #1
Freerider
Drives: 2015 f150 crew cab 4x4 '13 FRSraven
The whiteline Perrin positive shift kit
Somehow it fixed my problem with 6-5 downshift above 70mph.
But I got it BC I wanted to get rid of the low speed bucking, and it did that also.
Btw, I mean fixed the grind. I can't make it happen.
Freerider is offline   Reply With Quote
Old 08-20-2018, 09:41 PM   #2
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Yes.
What's going on here again? It sounds like the shift kit did stuff. Was it not supposed to do stuff?
EndlessAzure is online now   Reply With Quote
Old 08-20-2018, 10:04 PM   #3
norcalpb
norcalpb's Avatar
I liked my tranmission insert but I hated how much it hurts the car if you accidently lug engine.
After getting rid of mine I used more clutch finesse to compensate for the bucking.
Old 08-20-2018, 10:46 PM   #4
RJasonKlein
RJasonKlein's Avatar
Can you go into a little more detail on how you feel it hurts the car if you accidentally lug the engine? I have the kit and I’m wondering if I’ve just gotten used to or tuned out what you’re talking about.
RJasonKlein is offline   Reply With Quote
Old 08-21-2018, 01:39 AM   #5
mistople
mistople's Avatar
Drives: 2017 BRZ (Sold), 2023 GR86
Interested in this too. Haven't any problems yet.
mistople is offline   Reply With Quote
Old 08-21-2018, 12:20 PM   #6
norcalpb
norcalpb's Avatar
Well I noticed in can be easy to lug this engine if you apply a bit too much clutch on take off, which shakes the whole transmission and by extension the whole drivetrain. When the transmission is more directly connected to the chassis, all the vibrations get transferred to the driver which may be where I “feel” damage is being done, but the noise was always much louder and I would feel horrible for my car.
I do miss giving the car gas and not having it rock back and forth, but I felt like the various inserts prevented too much necessary drivetrain slack. (Maybe it would feel better with engine mounts and diff inserts).
Old 08-21-2018, 12:24 PM   #7
Freerider
Originally Posted by EndlessAzure View Post
Yes.
I didn't know it'd fix the mini grind. But, it worked elsewhere like it was supposed to. Some mods really don't do shit, not this one.
Sent from my XT1585 using Tapatalk
Old 08-21-2018, 12:29 PM   #8
Freerider
Also, you come off as an asshole.
Old 08-21-2018, 01:00 PM   #9
Ultramaroon
not playing cards
Ultramaroon's Avatar
Old 08-21-2018, 01:35 PM   #10
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
Wait what is going on here? you quoted yourself and called yourself an asshole
SuperTom is offline   Reply With Quote
Old 08-22-2018, 09:43 AM   #11
SkyeHack
SkyeHack's Avatar
Drives: 2018 BRZ tS
He is not wrong is he?
SkyeHack is offline   Reply With Quote
Old 08-22-2018, 11:03 AM   #12
gtengr
Drives: 2017 BRZ
Part of the reason I went sti on the engine and trans mounts. It's a factory-engineered middle ground between the soft stock parts and poly.
gtengr is offline   Reply With Quote
Old 08-22-2018, 01:25 PM   #13
radroach
Drives: car
Parts installed today, impressions are great! I haven't taken it out to a back road to wring it out fully yet.
Whiteline Transmission Insert: Pretty much fixed a huge problem I was having with drivetrain slack. Before, when accelerating I'd have to wait for the mount to crush before I could feel acceleration, and it would often come with a bit of a thunk as it all settled. NOW, its so damn smooth. Shifts amazing now that the transmission doesn't buck around. Only issue is the NVH, which is really just more noise from the engine being directly transferred into the car.. its loud.
Perrin Shift Stop: I didn't realize I needed this. This gets rid of the weird feeling when you're upshifting but not sure if you put it all the way into gear.. this makes it much more comfy. Shifts go in with a bit of a clunk which is satisfying. I hope this part wears well and that I won't have to regrease it often.
Old 08-22-2018, 04:19 PM   #14
gpvecchi
gpvecchi's Avatar
Does the Perrin Shift Stop fit the STi support? Is it good or not?
gpvecchi is offline   Reply With Quote
Perrin Transmission Support & Whiteline Gearbox Positive Shift Kit jehu Suspension | Chassis | Brakes -- Sponsored by 949 Racing 66 12-14-2017 03:12 PM
Perrin Transmission Mount+Shift Bushing, Whiteline Positive Shift Kit zohaib Transmission and Driveline 5 03-08-2017 11:51 PM
FS: Whiteline Positive Shift & Perrin Rear Shifter Bushing + Whiteline Front Diff Bus neilvosko Brakes, Suspension, Chassis 1 11-21-2016 02:44 PM
Whiteline positive shift kit and perrin shifter bushing review Raven604 Engine, Exhaust, Transmission 7 04-30-2015 04:10 PM
FS: Whiteline bushings KDT926 (Positive shift kit) & KDT922 (Positive traction kit) Tim_Asphalt_FRS Transmission and Driveline 3 09-26-2014 11:41 AM
