Drives: 2016 subaru brz insta@black.xira
major issue
so i had a thread about a dash fuse 7.5 blowing up already and i though it was the airbag module then my fuse started blowing out weeks later and it was a 15 fuse not a 7.5 and it starting become an issue and it just cuts off my alternator and now my power steering! i just wanna know what options i can do find a solution or im just drive it up the dealership
.![]() my car : http://tinypic.com/r/2eok7l4/9 Last edited by dynomite619; 08-19-2018 at 06:42 PM. |
#2 | |
Need to find the root cause. Did you change anything at all before they started blowing?
#3 |
A.K.A. Starlord
Drives: 2015 Series.Blue
I'm confused. Did the same fuse blow up both times? Did you replace the 7.5A fuse with a 15A fuse? If you did, you need to step away from the vehicle before you make things any worse. Fuses are there for a reason, and they are a spec'd to their respective limits for a reason too...
As Tcoat said, a fuse blowing is a symptom. It is a last line of defense before you fry something on the car. You need to find out what is causing the fuses to blow. We may be able to help, but we at least need more specifics.
![]() Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos! You can also find me on Instagram, and on Facebook. |
#4 | |
#5 |
Drives: 88 Supra 1JZ, 16 FRS, 25 GR Corolla
These are all the systems that fuse is setup for. I would advise to see a dealer. Also, don't change the fuse Amperage from what it came with. It's set at that amperage for a reason.
7.5A GAUGE ABS Air Conditioning Charging Clock Combination Meter Cruise Control Electronically Controlled Transmission and A/T Indicator Engine Control Engine Immobiliser System EPS Headlight Illumination Key Reminder Light Reminder Seat Belt Warning Shift Lock SRS Taillight Tire Pressure Warning System TRAC Turn Signal and Hazard Warning Light VSC
NARFALICIOUS
Noob Poster 1988 | 2016 Last edited by NARFALICIOUS; 08-20-2018 at 07:07 PM. |
#6 | |
A.K.A. Starlord
You need to stop driving the car, and bring it somewhere to be serviced. If your car catches fire and burns, and your insurance company finds out you doubled a fuse, they could very easily deny your claim on the basis of negligence and intentional misuse.
![]() Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos! You can also find me on Instagram, and on Facebook. Last edited by Stang70Fastback; 08-20-2018 at 07:33 PM. |
#7 |
OP, listen to what these guys are telling you. Pull that 15A fuse now and quit driving it.
Have it towed to an expert.
#8 | ||
The "My car burned up and it is Subaru's fault" thread should come any day now. https://www.ft86club.com/forums/showthread.php?t=128611
#9 |
Drives: 2013 Firestorm FR-S
Reading OP's responses like...
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
#10 | |
#11 |
Drives: 14 Cayman S, 16 Camaro 2SS
All these guys are absolutely right. You probably have a short somewhere in your system and by replacing it with a higher fuse your potentially allowing other systems to have more power (which=heat) flow to them then they were designed for. Take it to the dealership and allow them to figure out whats going on with your car.
#12 | |
Better than I can say for ol @Ultramaroon 's - ![]() OP, I suggest you just give your car keys to someone else and ask them to arrange to have your car fixed. I'm afraid this situation is waaaay over your pay grade. humfrz |
#13 | |
https://www.ft86club.com/forums/show...38&postcount=6 https://www.ft86club.com/forums/show...59&postcount=9
#14 |
Where did you wire your amp to? which terminal shown on this pic?
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
| Major service | Fletchlives78 | AUSTRALIA | 18 | 03-08-2017 05:22 AM |
| Known Major Issues I should know about.... | Darkone | BRZ First-Gen (2012+) — General Topics | 41 | 01-04-2017 09:51 PM |
| Major Mods.. | Jaden | Scion FR-S / Toyota 86 GT86 General Forum | 72 | 08-28-2015 10:16 PM |
| Rattles are a major issue in this car | jflogerzi | Issues | Warranty | Recalls / TSB | 49 | 11-05-2012 10:59 AM |
| One fairly major and one minorish issue.... | Jedi1 | Tracking / Autocross / HPDE / Drifting | 3 | 07-31-2012 03:08 PM |
