#43 |
Drives: 2018 BRZ tS
New here, hello.
With the advent of FI and MAF there is now much more to the engineering of air filters and CAI. Without going to great detail it is possible that a low restriction filter, or even the complete absence of one, may have a negative result and against expectations even lower the performance of the engine. The results vary between engines due to calibrations and so it is possible that filter brand X brings positive results on engine A while it yields negative or no results on engine B. The one group of cars in constant search of power are without doubt the Spec Miatas that are strictly regulated and where even the most minute gains end up being a considerable advantage. The filter most commonly used here is the one made by Green Filter https://greenfilter.com BTW one can not trust the filter brand decals on the cars as you will often see brand X advertised due to racing premiums paid while the filter driven is the Green Filter. If you buy it make sure that it is the genuine article as there are many imitators which perform poorly. My own BRZ tS is less than one week old and it will remain stock as it will run SCCA Solo in the Street Stock class. |
| The Following User Says Thank You to Scala For This Useful Post: | RJasonKlein (08-23-2018) |
#44 | |
Drives: 2014 Subaru BRZ Ltd.
This link has some data and analysis from an ISO 5011 test comparing an OEM-style filter to various performance filters. http://nicoclub.com/archives/kn-vs-oem-filter.html
*question everything*learn something*answer nothing*
| The Following User Says Thank You to lamawithonel For This Useful Post: | Captain Snooze (08-21-2018) |
#45 |
Drives: 2017 Brz
Is the HKS hybrid filter a one time use thing or can it be serviced ? What's the time/mile interval for service?
#46 |
Drives: 2017 toyota 86
Anyone know where to find a 2.75" inlet diameter inverted conical filter between 10-14" long? I am thinking about replacing my perrin CAI oiled filter with a dry one, but cant find any inverted conical filters over 8" long though. I can find 12" dry conical filters which i've been debating getting, but id prefer something either larger or inverted for maximum air flow.
| TRD Intake Filter Air Filter Cleaner Element FRS BRZ 86 Toyota Racing Development | hirollaz | Engine, Exhaust, Bolt-Ons | 0 | 03-15-2017 02:46 AM |
| Good aftermarket oil filter and crush washer replacement? | qqzj | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 12 | 06-15-2015 10:15 PM |
| Aftermarket air filter oiled | Area51 | Engine, Exhaust, Bolt-Ons | 3 | 04-26-2013 11:38 AM |
| Drop In filter test! Stock, Apexi, No filter | RallySport Direct | Engine, Exhaust, Transmission | 14 | 06-25-2012 02:40 PM |
