Old 06-06-2015, 12:54 AM   #1
qqzj
Drives: MDX, Camry
Good aftermarket oil filter and crush washer replacement?
I know the OEM filter is highly recommended. But I have some Amazon GC burning a hole in my pocket. If anyone has experimented with aftermarket filters, it will be great to hear your stories. Also I hate to replacement the crush washer every time. Is there a replacement washer available? I changed oil for my Toyota's and Honda's for many years, never replaced a single gasket/washer. Thanks for the help.
qqzj is offline   Reply With Quote
Old 06-06-2015, 02:04 AM   #2
aegisdrgn
aegisdrgn's Avatar
Drives: Scion FR-S 10 Series #2263
You could get this - never have to worry about a crush washer again!
[ame="http://www.amazon.com/Fumoto-F-108-Engine-Drain-Valve/dp/B003VCCUJI"]Amazon.com: Fumoto F-108 Engine Oil Drain Valve: Automotive[/ame]
Or get this, you can attach a hose/tube to the short nipple to direct the oil:
[ame="http://www.amazon.com/F108S-16mm-1-5-Fumoto-Drain-Nipple/dp/B004FFHH0M"]Amazon.com: F108S (16mm-1.5): Fumoto Oil Drain Valve with Short Nipple Joint: Automotive[/ame]
aegisdrgn is offline   Reply With Quote
Old 06-06-2015, 02:49 AM   #3
Lelantas
Lelantas's Avatar
Drives: '15 BRZ ISM
If you're interested in getting the tried-and-true Subaru OEM oil filters, you can also find them on Amazon for only a bit more than the lowest eBay prices:
[ame="http://www.amazon.com/SUBARU-FORESTER-FILTER-NON-TURBO-15208AA130/dp/B00C1IM0PC/"]Amazon.com: SUBARU FORESTER OIL FILTER 3PACK 2011 2.5 NON-TURBO W/CRUSH WASHER 15208AA130: Automotive[/ame]
Lelantas is offline   Reply With Quote
Old 06-06-2015, 11:37 PM   #4
qqzj
Drives: MDX, Camry
Thanks. Good idea!
Old 06-09-2015, 11:27 PM   #5
JohnJuan
JohnJuan's Avatar
Drives: 2013 FR-S, Hot Lava; 2012 Z1000 CBO
So far, the Purolator PSL14459 seems to be serving me well as a filter. $10.50 a pop. The Fram XG9688 should also be quite good, and costs only $6.75 each.
JohnJuan is offline   Reply With Quote
Old 06-10-2015, 08:30 AM   #6
2016 Camaro SS
2016 Camaro SS's Avatar
Drives: Fast
I got the second one for my FR-S. I just reach my hand under, flip the switch, and it drains through the tube into my can. Easiest oil changes ever. I won't go without one now. No jacking up the car, no mess, and no, it never hits on anything and I'm lowered 1.4". If it hits something, you're off-roading.
2016 Camaro SS is offline   Reply With Quote
Old 06-10-2015, 12:12 PM   #7
qqzj
Drives: MDX, Camry
thanks. you mean you can reach the fumoto without using a ramp? do you have a very long arm?
Old 06-10-2015, 12:31 PM   #8
2016 Camaro SS
Drives: Fast
I'm 6'6" and yes, lol.
Old 06-11-2015, 08:59 PM   #9
immortal_suby
Drives: 2015 BRZ Limited 6MT
That's strange-- 14459 is the purolator for the SVX.
2015 BRZ , 1992 SVX LSL, 2019 ASCENT
immortal_suby is offline   Reply With Quote
Old 06-11-2015, 09:48 PM   #10
JohnJuan
JohnJuan's Avatar
Purolator Application Guide - 2013 Scion FR-S
I suspect that they just like the same thread pitch and gasket diameter?
For those who don't like clicking:
Old 06-11-2015, 10:03 PM   #11
Myv
Myv's Avatar
Drives: SWP BRZ Limited MT
Fumoto valve, you won't regret it. Get the safety clip too just in case.
Myv is offline   Reply With Quote
Old 06-13-2015, 08:05 PM   #12
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
Let me get this straight. Your gonna spend $25-30 for oil, $4-5 for a filter, but you don't want to replace a 75 cent (OEM) crushwasher?
My local Toyo dealer did my first oul change and didn't replace the washer...it leaked. Not sure why this car seems to need the washer replaced, but it seems that it does.
Yeah, I'm sure a generic washer will work, but it requires a 16mm. I checked all my local parts/accessory stores and could not find anything larger than a 14mm.
billwot is offline   Reply With Quote
Old 06-15-2015, 10:15 PM   #13
immortal_suby
Cool! I'm not sure how I missed that one. 14459 is burned into my memory from the countless oil changes on my svx with over 304,000 miles on it. I guess since I've used mostly OEM subaru filters on my BRZ I just never bought a purolator for it yet.
DIY: Drop-in Air Filter Replacement Rabble DIY (Do-It-Yourself) Guides 68 09-01-2022 07:12 PM
Crush Washer Sizes Eric1855 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 55 08-30-2021 02:21 AM
Crush Washer for AT BRZ888 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 07-27-2014 10:06 PM
Air Filter Replacement Shaisters Northwest 6 05-13-2014 06:39 PM
Is there an aftermarket replacement for this panel? JordanWho Cosmetic Modification (Interior/Exterior/Lighting) 27 03-07-2013 03:57 PM
