Old 08-13-2018, 04:40 PM   #1
BladeRunner
BladeRunner's Avatar
Drives: 2015 Subaru BRZ Limited
Best aftermarket Air Filter?
I've been thinking about getting a new, aftermarket air filter to replace the stock one.
Wondered which brand is best and if it's worth it in terms of better breathing efficiency & some nominal horsepower increase.
Cosworth or K&N?
BladeRunner is offline   Reply With Quote
Old 08-13-2018, 04:47 PM   #2
mrg666
pessimistic skeptic
mrg666's Avatar
I used K&N when I was NA. There was absolutely no difference in power. Don't waste your money. I would keep using the OEM filter.
The Following User Says Thank You to mrg666 For This Useful Post:
SkyeHack (08-13-2018)
Old 08-13-2018, 04:48 PM   #3
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
It's really the same product. Just depends on how much you want to pay or what ever is on sale.
Old 08-13-2018, 05:03 PM   #4
HachiRokuX
Drives: 2017 Toyota 86
There’s a thread on here that says it can lead to about a 5whp and 5wtq increase for NA cars.
HachiRokuX is offline   Reply With Quote
Old 08-13-2018, 05:14 PM   #5
JeremyR
JeremyR's Avatar
Drives: 2015 BRZ Limited
HKS filter gains you 5 HP and 1 TQ base on their dyno numbers.
Although most filters will net you similar results so go with a brand you trust.
REALMS BRZ Build Thread
HKS|Parts Shop MAX|Battle Version|ADVAN|Beatrush
JeremyR is offline   Reply With Quote
The Following User Says Thank You to JeremyR For This Useful Post:
HachiRokuX (08-13-2018)
Old 08-13-2018, 05:21 PM   #6
That is a very, very optimistic number.
You will get a cooler intake sound that will indeed make you feel like you have more HP but that is about it.
Old 08-13-2018, 05:24 PM   #7
mrg666
pessimistic skeptic
mrg666's Avatar
Yeah, I believed that and wasted my money. There is no difference, none that I can tell.
Old 08-13-2018, 05:30 PM   #8
BladeRunner
That dyno reference sounds good! But, other members are saying there's no appreciable difference.
I'm still confused though whether or not to upgrade the air filter over the OEM one.
The Following User Says Thank You to BladeRunner For This Useful Post:
JeremyR (08-13-2018)
Old 08-13-2018, 05:43 PM   #9
MJones_RB
MJones_RB's Avatar
I went with the TRD unit since it was the only one to get rid of the intake bend and direct air straight into the throttle body. Not that it makes a HUGE difference I'm sure, but at the time it made sense.
MJones_RB is offline   Reply With Quote
Old 08-13-2018, 05:56 PM   #10
Sasquachulator
Pavement Grey
You wont feel any difference.
The induction sound may be more pronounced though, which would make the more expensive filter worth it
Old 08-13-2018, 06:04 PM   #11
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
I went K&N, for cost savings more than anything else.
As long as you maintain it with a recharge kit, it will pretty much last forever.
I kept the new paper filter to swap in when I need to clean it.
The Following User Says Thank You to RToyo86 For This Useful Post:
Busybee (04-22-2023)
Old 08-13-2018, 06:15 PM   #12
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
I've been buying wix air filters because they have that platic rim that makes a more easy install. They also seem slightly higher quality than oem. These are not reusable, but just a better product than the oem filters. No hp gain just a slightly more expensive filter made to a slightly higher quality standard.
Main takeaway is the plastic lining for a more secure fit.
DandoX is offline   Reply With Quote
Old 08-13-2018, 06:48 PM   #13
JeremyR
JeremyR's Avatar
If you don't need a new air filter then I wouldn't bother.
But if you're coming up on a maintenance interval then an "upgraded" filter couldn't hurt.
Chances are you won't feel any performance gains though.
http://www.ft86club.com/forums/showt...ght=air+filter
Old 08-13-2018, 07:13 PM   #14
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
From personal experience I went with the K&N. Just because it was on sale from Walmart for $45.
I only used it for a year because my mpg dropped from 30 to 27. My butt dyno measured a 5 hp gain. Since I was just daily driving I switched back to oem filters and got back my 30 mpg back.
TRD Intake Filter Air Filter Cleaner Element FRS BRZ 86 Toyota Racing Development hirollaz Engine, Exhaust, Bolt-Ons 0 03-15-2017 02:46 AM
Good aftermarket oil filter and crush washer replacement? qqzj Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 12 06-15-2015 10:15 PM
Aftermarket air filter oiled Area51 Engine, Exhaust, Bolt-Ons 3 04-26-2013 11:38 AM
Drop In filter test! Stock, Apexi, No filter RallySport Direct Engine, Exhaust, Transmission 14 06-25-2012 02:40 PM
