#15 |
Drives: frs
ohh that common knowledge with no actual testing or data to back anything up except you read on a forum somewhere they are terrible.
#16 |
#17 |
Drives: '13 FRS - STX
How much lower than stock are you trying to be? I don't know what '1" wheel gap' means and you will have to sacrifice comfort for looks regardless due to the suspension travel if you're talking about being 2" lower than stock. Hell a picture means more to me than "1 inch gap"
Bilstein B14/B16 KW V1 Ohlins R&T I believe all of the above suggestions (not just mine) will be uncomfortable at 2"+ lower than stock because you're relying on the bumpstops to keep the car from bottoming out and you should be looking at suspensions designed specifically for going low. |
#18 |
Drives: frs
you do know most of the $1000 coilovers are made in the same factories with the same parts as the more expensive counterparts, they just change out the paint color on most of these things. by your logic my car should have fallen apart by now or flew off the road because i dont have a quality suspension. the truth is the BC coilover is better than factory and i have used mine year round for years and have zero issues, and they ride good because i set them up properly.
#19 | |
Which model line of BC's? Their base models are significantly cheaper than their higher end offerings. If no to those, then how are they actually better than stock? I think you'll find most people will say the same for almost all the cheaper coilovers, regardless of color or label.
#20 |
Drives: 2013 WRB BRZ 6MT
Was literally just in another thread complaining about bouncy ride on BC BR coils and I'll re-iterate here, same as that thread, that it is likely incorrectly set preload. Watch the video on post #5 of the following thead for details on setting preload.
http://www.ft86club.com/forums/showthread.php?t=107004 |
#21 | |
Drives: 2017 Halo 86
Attachment 169602
Build Thread / Daily Driver
OFT Stage 2+, GrimmSpeed CAI, JDL Ultra Quiet FP, Perrin 2.5" Resonated CBE, Enkei 18x8.5 +45, 245/35 Continental ExtremeContact Last edited by Lakitu; 03-30-2019 at 07:55 PM. |
#22 | |
I'll give this a shot, would prefer to work with what I already have if it will fix the issue, otherwise I don't mind looking for other options.
OFT Stage 2+, GrimmSpeed CAI, JDL Ultra Quiet FP, Perrin 2.5" Resonated CBE, Enkei 18x8.5 +45, 245/35 Continental ExtremeContact |
| The Following User Says Thank You to Lakitu For This Useful Post: | Lynxis (08-20-2018) |
#23 | |
#24 |
Try raising the ride height, get an alignment, and then see how you like that as a temporary solution. The increased height will take away most of that jarring feeling.
#25 | |
| The Following User Says Thank You to Tokay444 For This Useful Post: | Tristor (08-31-2018) |
#27 | |
TRACKBREAD
I've told people to buy literally anything else. It's amazing they get so much business compared to genuinely good offerings like TEIN and ST which cost the same. |
#28 |
I think I've found the issue... there's a 1" gap between each spring coil on the driver rear coilover, but every other coilover has about 2" between each spring coil.
I feel like this could be throwing the car's dynamic and balance out of whack. This spring is super preloaded. I don't know if I did this while installing it, or it came this way from BC. I have a feeling this is the issue, unless its meant to be this way? Seems odd to have just 1 coilover preloaded. I tried to adjust the preload but the damn rings will not budge. I think I'm going to have to take it off to adjust it. So frustrating.
| Exhaust Upgrade Suggestions | hosfordbrandon | Engine, Exhaust, Transmission | 6 | 03-27-2016 12:47 AM |
| Looking to upgrade rear sway bar, any suggestions? | Str8Ghostin | Tracking / Autocross / HPDE / Drifting | 8 | 02-22-2015 10:40 AM |
| Suggestions for more horsepower! Turbocharger upgrade + more! | forzajuve | Forced Induction | 14 | 04-10-2013 08:51 PM |
| Michelin/Enkei upgrade + more. Community suggestions welcome! | forzajuve | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 14 | 03-29-2013 07:14 PM |
