Old 02-13-2018, 03:50 PM   #127
spicyricecake
spicyricecake's Avatar
Drives: 2017 CWP BRZ Performance Package
has anyone tried fitting these on the 17 BRZ with the brembos?
spicyricecake is offline   Reply With Quote
Old 02-13-2018, 05:32 PM   #128
SG02WRX
SG02WRX's Avatar
Drives: SWP WRX HATCHBACK
Will not clear. Will need about ~ 10mm spacer
SG02WRX is offline   Reply With Quote
The Following 2 Users Say Thank You to SG02WRX For This Useful Post:
JonRZ (02-13-2018), spicyricecake (02-17-2018)
Old 02-17-2018, 11:32 PM   #129
spicyricecake
Thanks for the confirmation! I was hoping I could get away with 8mm. ;(
Old 02-19-2018, 11:46 AM   #130
SG02WRX
SG02WRX's Avatar
You can, but its a VERY tight fit. I seen it up close and it made me nervous.
Old 02-19-2018, 12:42 PM   #131
spicyricecake
gotcha. at 10mm, I probably will not get these. it'll essentially be 18x9.5 +30 with the spacer. that'll poke a lot
Old 02-26-2018, 01:50 PM   #132
DrifterD
Drives: 15' Halo
I really like these wheels, but makes me sad it cannot clear brembos without spacers
2015 Halo MT
@denneee
@haroseattle
DrifterD is offline   Reply With Quote
Old 03-04-2018, 07:14 PM   #133
Cup_Ah_Joee
Drives: 2016 Raven Black FR-S
Really happy with how the gold looks. Pictures don’t do it justice!
Wheels are wrapped in Ventus RS4’s 255 35
Cup_Ah_Joee is offline   Reply With Quote
Old 03-04-2018, 10:57 PM   #134
Aluma007
Drives: 2017 Brz
beautiful!
Aluma007 is offline   Reply With Quote
Old 03-05-2018, 11:31 AM   #135
JustSomeGuy
A Nobody
JustSomeGuy's Avatar
Drives: FRS
looking nice! whats your suspension setup?
JustSomeGuy is offline   Reply With Quote
Old 03-06-2018, 06:14 PM   #136
Cup_Ah_Joee
Thanks! Sitting on Ohlins R&T
Old 08-16-2018, 07:36 PM   #137
blkdmnd
Drives: Black 2015 Subaru BRZ, BlackDiamond
Originally Posted by PRORICAN View Post
Would you or anyone happen to know the color of the black wheels? The code or anything. I literally just got them on yesterday and already curbed them thanks to negative camber and my failure to remember that. Any help would be appreciated.
blkdmnd is offline   Reply With Quote
Old 01-15-2019, 01:24 AM   #138
Terran
Terran's Avatar
Drives: Raven FR-S 6MT
dropped on ST coilovers, 245/40/18
Terran is offline   Reply With Quote
Old 09-16-2019, 12:57 PM   #139
konespeed
konespeed's Avatar
Drives: 2019 Crystal Black Silica BRZ
Hey everyone, I'm just paranoid and trying to get the right info to get these wheels to fit.
I'm currently lowered on Swift springs and stock struts, and want to get these to fit safely and securely.
From my understanding, I will need to run a thinner tire up front or else it will rub on my stock struts. OR I can choose to run a 3mm spacer to get these to fit up front and be able to run a little meatier of a tire.
My plan was to run 245/35/18 squared even though optimally i would prefer 255/25/18 squared so my tires aren't stretched.. but that seems to be out of the question without coilovers correct?
So my questions is will 245/35/18 squared work on stock struts and swift springs?
OR will i need to get the spacer in there at all to fit? spacer in the rear as well to even it out?
Any tips and advice are greatly appreciated! I just want to be prepared when I throw these on. Thanks!
My BRZ's Insta: @BRZKONE
konespeed is offline   Reply With Quote
Old 05-16-2020, 12:11 AM   #140
mg92p
Drives: Subaru BRZ S 2013
How much do the 18x9.5 +40 (57xtremes for example) rims poke out from the wheel archs?
Can this be solved with some camber and an alignment?
mg92p is offline   Reply With Quote
Wheel Directory: Enkei RS05RR 18x9.5 +43 FT-86 SpeedFactory Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 129 09-22-2019 10:39 PM
Wheel Directory: Enkei Raijin 18x8.5 +45 / 18x9.5 +45 GuerillaRacing Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 221 08-01-2019 10:30 AM
Wheel Directory: Enkei RPF1 18x9.5 +38 FRS8SIX Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 297 02-15-2018 03:50 PM
Wheel Directory: Enkei Tenjin 18x8.5 +45/18x9.5 +45 Sciby Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 11-10-2014 12:53 AM
Wheel Directory: Work Meister S1 3-Pc 18x9.5 +29 / 18x9.5 +24 PradiG Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 48 12-12-2013 03:15 AM
