#127 |
Drives: 2017 CWP BRZ Performance Package
has anyone tried fitting these on the 17 BRZ with the brembos?
#128 |
Drives: SWP WRX HATCHBACK
Will not clear. Will need about ~ 10mm spacer
| The Following 2 Users Say Thank You to SG02WRX For This Useful Post: | JonRZ (02-13-2018), spicyricecake (02-17-2018) |
#129 |
#130 |
#131 |
#132 |
Drives: 15' Halo
I really like these wheels, but makes me sad it cannot clear brembos without spacers
2015 Halo MT
@denneee @haroseattle |
#133 |
Drives: 2016 Raven Black FR-S
Really happy with how the gold looks. Pictures don’t do it justice!
Wheels are wrapped in Ventus RS4’s 255 35 |
#134 |
Drives: 2017 Brz
beautiful!
#135 |
A Nobody
Drives: FRS
#136 |
#137 |
Drives: Black 2015 Subaru BRZ, BlackDiamond
#138 |
Drives: Raven FR-S 6MT
dropped on ST coilovers, 245/40/18
#139 |
Drives: 2019 Crystal Black Silica BRZ
Hey everyone, I'm just paranoid and trying to get the right info to get these wheels to fit.
I'm currently lowered on Swift springs and stock struts, and want to get these to fit safely and securely. From my understanding, I will need to run a thinner tire up front or else it will rub on my stock struts. OR I can choose to run a 3mm spacer to get these to fit up front and be able to run a little meatier of a tire. My plan was to run 245/35/18 squared even though optimally i would prefer 255/25/18 squared so my tires aren't stretched.. but that seems to be out of the question without coilovers correct? So my questions is will 245/35/18 squared work on stock struts and swift springs? OR will i need to get the spacer in there at all to fit? spacer in the rear as well to even it out? Any tips and advice are greatly appreciated! I just want to be prepared when I throw these on. Thanks!
My BRZ's Insta: @BRZKONE |
#140 |
Drives: Subaru BRZ S 2013
How much do the 18x9.5 +40 (57xtremes for example) rims poke out from the wheel archs?
Can this be solved with some camber and an alignment? |
| Wheel Directory: Enkei RS05RR 18x9.5 +43 | FT-86 SpeedFactory | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 129 | 09-22-2019 10:39 PM |
| Wheel Directory: Enkei Raijin 18x8.5 +45 / 18x9.5 +45 | GuerillaRacing | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 221 | 08-01-2019 10:30 AM |
| Wheel Directory: Enkei RPF1 18x9.5 +38 | FRS8SIX | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 297 | 02-15-2018 03:50 PM |
| Wheel Directory: Enkei Tenjin 18x8.5 +45/18x9.5 +45 | Sciby | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 11-10-2014 12:53 AM |
| Wheel Directory: Work Meister S1 3-Pc 18x9.5 +29 / 18x9.5 +24 | PradiG | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 48 | 12-12-2013 03:15 AM |
