Ambient temperature reading
Hi Folks,
This is the first thing on my 2013 FR-S, with 22,000 miles, that doesn't seem to be quite right. I know, I should consider myself lucky - ![]() The ambient air temperature reading seems to not want to go over 76 degrees F, regardless of the outside air temperature. Yes, it's been up to 95 degrees F in these parts here lately. Even after driving several miles (city driving) it seems to be stuck on 76 degrees. I know, this is a first world problem - ![]() My question is that how is your air temperature gauge read? Hi, low, right on? If it's off, by about how much? Thanks, humfrz |
#2 |
Drives: 2016 Cosworth 2.2 BRZ
Mine did read about 3 degrees high until I relocated the sensor. It sits right next to the radiator and picks up heat. Bad design. I moved it forward from its current spot and now it's mostly accurate. You have to be moving though. When the car sits in traffic it reads high again.
| The Following User Says Thank You to sly For This Useful Post: | humfrz (08-13-2018) |
#3 |
Drives: BRZ DGM Limited
Mine is only accurate when the car is moving, otherwise it reads high.
| The Following User Says Thank You to BRZnut For This Useful Post: | humfrz (08-13-2018) |
#4 | ||
Drives: 2013 WRB BRZ
As for the OP, to me, I'd start troubleshooting with the sensor. EDIT: Wait. for some reason I was thinking we were discussing the engine air intake temp sensor... not the reading on the gauge cluster... In that case, recently mine has read at most 110degF (90-95 actual) when I get out to my car after work.and start it up. It cools down after starting to drive.
#5 |
The highest mine has gone is 40. Has been as low as -25 though.
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | humfrz (08-13-2018), new2subaru (08-13-2018) |
#6 | |
It's pretty accurate on mine especially once moving and not standing still, I think it is able to be adjusted it in techstream however as I could've sworn there was a ambient air temp offset value in there somewhere
| The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post: | humfrz (08-13-2018) |
#7 |
Famous Potatoes
Drives: '15 ultramarine
Mine is always about 10 degrees F high.
| The Following User Says Thank You to Sapphireho For This Useful Post: | humfrz (08-13-2018) |
#8 |
Yes. If you relocate the temp sensor forward and away from the radiator, put a piece of foil between it and the radiator to act as a heat shield, you can recalibrate it in techstream to make it 100% accurate. I haven't recalibrated mine yet.
#9 | |
| Where is the ambient temperature sensor located? | solidONE | Software Tuning | 10 | 09-17-2023 02:21 PM |
| Ceramic Coated Ptuning Headers Ambient Temperature Testing | s30series | Engine, Exhaust, Transmission | 32 | 03-17-2016 02:58 PM |
| Car/Ambient temperature to log data | gdrider77 | Software Tuning | 6 | 01-19-2014 08:49 AM |
| Ambient temperature's influence on horsepower | BuBlake | Engine, Exhaust, Transmission | 40 | 04-10-2013 12:17 AM |
| Temperature not reading below 0 | BrewCity-FR-S | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 01-22-2013 10:05 AM |
