Old 07-11-2018, 12:05 PM   #43
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
Originally Posted by Bonburner View Post
This is coming from a MS in chemotherapeutic drug design and synthesis with a BS in chemistry and currently working on his PharmD. Yes different fields, but similar enough basic utilization of chemistry knowledge to understand the stark differences between the products.
Off topic here, but what do you plan on doing after you get the PharmD? Work as a pharmacist, researcher or something like an MSL for a pharma company?
My wife has her PhD in biochemistry and specialized in cancer research, but moved away from academia into industry for the past 20 years. she knows nothing about motor oil, though, lol.
shiumai is offline   Reply With Quote
Old 07-11-2018, 11:11 PM   #44
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
Only comparable numbers I was able to find from Mobil indicate Mobil 1 is actually better. Lower density, higher viscosity, higher flashpoint, nothing else I saw that was directly comparable unless I'm missing something. I don't have time to look closer, but figured I'd leave my interpretation of the data.
Depends on how you drive your car.
I personally anticipate a lot of short distance driving, so I want an oil with a tighter viscocity range (which TGMO and Idemistu Zepro seems to be the best in 0W20).
I don't think flash point is much of a concern unless you're doing some heavy track endurance stuff. Which you should have an oil cooler by then anyways.
And then what Bluesubie said. (edit: I did not personally check the additives, so I'm just going with what he said - heh).
I'm leaning towards managed care / pharmacoeconomics research / outcomes research / pharmaceutical industry .. possibly MSL.
The Following User Says Thank You to Bonburner For This Useful Post:
shiumai (07-12-2018)
Old 08-09-2018, 11:41 AM   #45
Yigal.K
Drives: 2012 Toyota GT86
I used mobil1 0W20, the engine didn't even last to the annual service interval. No it wasn't missing oil, no it didn't overheat, no I haven't been driving it that hard (even an ecobox should have survived). At 101k KM and just 12k KM since the last service, the engine gave out (rod knock). I was told by the Subaru mechanic they don't use 0W20, but 5W30 and that the engine probably died due to the oil.
So while I'll never know for sure what was the cause, unless you live in a colder environment I would stay away from 0W20, mobil1 or not.
Yigal.K is offline   Reply With Quote
Old 08-09-2018, 12:02 PM   #46
Vital
Drives: 2015 BRZ
Not really sure if your mechanic knows what hes talking about. The manual specifically states to use 0w-20 oil. Not sure what happened to your engine, but in summer people generally run 5w-30 and in winter they run 0w-20. If you track your car and live in hot climate or just drive your car hard then sure you can use 5w-30, but there are no issues in using either oils...
Old 08-09-2018, 12:23 PM   #47
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
How often did you change the oil? You said that the last service was just 12k km before?
Old 08-09-2018, 01:15 PM   #48
Leonardo
Country Boy 4 Life
Leonardo's Avatar
This is the factory suggested interval for oil changes. 7500 miles or 12000 Kilometers. I change mine every 7500 miles at the dealership. (mostly because I bought the Lifetime synthetic oil package)
I LIKE TIRES!
Old 08-09-2018, 01:19 PM   #49
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Yes I know. I was just wondering because his car has a high mileage and seemed that he was changing the oil in bigger intervals.
Old 08-09-2018, 01:36 PM   #50
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Meh. My car has 60,000 miles, and I do 10,000 mile oil change intervals. Sometimes I go an entire season of autocross on one oil change. There are a lot of things that dictate how often you should change your oil.
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
Old 08-09-2018, 02:29 PM   #51
mrg666
pessimistic skeptic
mrg666's Avatar
I would change the mechanic, Mobil 1 is totally fine.
The Following User Says Thank You to mrg666 For This Useful Post:
Vital (08-10-2018)
Old 08-09-2018, 02:45 PM   #52
MCTeeJ
MCTeeJ's Avatar
Drives: 2014 Scion FR-S
I did the 3 complimentary oil changes and I always was a little short on oil by the time the next interval came up.
Started changing the oil myself with Mobil1 0w20 at around a 5-6k interval, and threw a magnetic drain plug in the car the first time I went to change it. Did probably 2-3 changes on the M1 and every time I saw metal shavings on the plug; nothing to be alarmed about just normal wear and tear. Oil was always a half qt. low when I went to change it.
Have since switched to Motul 5w30 and done 3 changes with that oil. Oil is full when I go to change it, and there are far fewer shavings on the plug.
I'm no oil expert, not even close, just providing data.
MCTeeJ is offline   Reply With Quote
Old 09-17-2018, 02:49 PM   #53
Yigal.K
Since my annual mileage is usually lower than the maintenance interval I usually have it done once a year. btw, the EU manual says every 15k Km / 12mo. Either way I didn't even get around to that. Bought the car with 88k KM. Had it serviced within a month of buying it (replaced all filters and oils, trans and diff included, minus fuel filter) and the engine started knocking at 101k KM, less than a year since its last service.
Mobil 1 0w-30 lab results max20s14 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 17 04-03-2018 07:08 PM
Mobil 1 0W-20 Brahsbrah Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 109 07-01-2014 10:29 PM
Mobil 1 Oil on Sale White64Goat Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 03-12-2014 12:21 PM
Why do the FRS/BRZ engines sound different from other Subaru's russv Scion FR-S / Toyota 86 GT86 General Forum 6 03-28-2013 06:30 PM
Subaru engines' weights Allch Chcar Other Vehicles & General Automotive Discussions 19 04-30-2011 01:10 AM
