Old 08-08-2018, 11:34 AM   #1
leevanf
leevanf's Avatar
Drives: 2014 BRZ Limited A/T
Increasing height of stock AT shifter?
Do you guys know of any shifter extender that increases the height of the OEM A/T shifter?
I want it a bit higher since im usually on manual mode, and prefer the shifter over the paddles.
I noticed Raceng has an extender with the AT's dimensions but for some reason, the M10x1.25mm does not list the frs in the list of compatible cars.
https://www.raceseng.com/extender-100
Thank you!
leevanf is offline   Reply With Quote
Old 08-08-2018, 12:21 PM   #2
jordan7831
Drives: 2016 Halo FRS
The product you linked is very expensive for what it is. Just a piece of bar stock with a threaded section and tapped hole.
If you are handy and had the right tools you could probably get a tap and die with the same thread pitch the auto shift know uses and make your own.
Or just buy one lol.
My butt dnyo didn't like it
jordan7831 is offline   Reply With Quote
The Following User Says Thank You to jordan7831 For This Useful Post:
FRSBRZGT86FAN (08-09-2018)
Old 08-08-2018, 12:26 PM   #3
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Thank you!
I googled "shift knob extender" a bunch of stuff came up. I am sure if you took the time to sift through the results, you could find something that would work at a fair price. ( I mean it is just a threaded metal rod - How much do you want to pay? )
I LIKE TIRES!
JohnJuan (08-09-2018)
Old 08-08-2018, 02:20 PM   #4
Aluma007
Drives: 2017 Brz
you can manual shift with the knob?? mine doesn't have that feature, It doesn't go up or down on the lever, just to the left to engage the paddles.
Aluma007 is offline   Reply With Quote
Old 08-08-2018, 02:22 PM   #5
Vital
Drives: 2015 BRZ
Try it again, i know it feels like it doesnt shift up or down. I drove my friends 860 and i could shift from the knob just fine. It should have the "+/-" for shifting up and down.
The Following User Says Thank You to Vital For This Useful Post:
Leonardo (08-08-2018)
Old 08-08-2018, 02:25 PM   #6
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Yes, I can put my car in Drive and then pull my shifter to the left to engage "manual mode". Then the shifter should push forward and back to change gears.
I LIKE TIRES!
Old 08-08-2018, 02:54 PM   #7
Aluma007
Drives: 2017 Brz
INTERESTING! i'll try next time i go out
Old 08-08-2018, 03:45 PM   #8
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
..you can also still use the paddles during normal D but after a few moments if you don't continue to use the paddles it goes back to being full auto.
HKz is offline   Reply With Quote
The Following User Says Thank You to HKz For This Useful Post:
Old 08-08-2018, 04:20 PM   #9
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
open your cellphone and download Wish, I think i saw what you want there before....... except it's dirt cheap.
Wait you wanna extend the shifter not the paddle...? I have some weird image in my head now, I think we need the expert here @Tcoat @humfrz
Old 08-08-2018, 04:58 PM   #10
What would I know about extending an AT shifter?
Now if you wantta go old school
86geek (08-11-2018), chaoskaze (08-08-2018), finch1750 (08-09-2018), humfrz (08-08-2018), norcalpb (08-08-2018)
Old 08-08-2018, 05:19 PM   #11
Yep, like mentioned, get a piece of pipe and a tap & die and make it as long as you wish. -
chaoskaze (08-09-2018)
Old 08-09-2018, 12:44 AM   #12
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Talking
Man you guys do not disappoint. You came you saw and you conquered.
The Following User Says Thank You to chaoskaze For This Useful Post:
humfrz (08-09-2018)
Old 08-09-2018, 02:31 AM   #13
leevanf
leevanf's Avatar
The replies are hilarious guys! But seriously i just want to know will the Raceng one fit? I of course like the material and finish of it too..
Old 08-09-2018, 03:01 AM   #14
mrg666
pessimistic skeptic
mrg666's Avatar
This adapter might be useful for fitting taller shift knobs made for manual
https://www.amazon.com/Kei-Project-S.../dp/B01H2SPAWU
18x9.5 stock height stock struts etherealfall Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 07-11-2017 05:44 AM
FS: Stock Short-Throw Shifter, Springs, and Rear Shifter Bushing bergy Transmission and Driveline 8 10-20-2016 09:57 PM
Coilover options capable of slightly increasing ride height. Mechazawa Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 12-31-2014 01:23 PM
Post Your Stock Height 86! VakaGT FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 03-19-2014 07:09 AM
BRZ vs 86 stock ride height Moe AFRICA 2 11-21-2013 08:35 AM
