Old 08-04-2018, 04:26 AM   #1
Verl0r4n
Drives: GT86
Ls3, LT4 z06 size difference
Im thinking about doing a swap but before you tell me to just buy a corvette I live in australia and Z06 here starts at about $200k.
What I want to know is what the physical size difference between an LS3 and an LT4 is. The reason im interested in the LT4 is because the blower set up makes it appear to be shorter than an LSA so it might still fit under the bonnet but I just dont know, or will I an LSA fit anyway?
Sent from my SM-G950F using Tapatalk
Verl0r4n is offline   Reply With Quote
Old 08-04-2018, 04:42 AM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Simple, a used Z06 would cost a lost less. Just say'n
Also your google-fu is super weak. Took me 2 seconds to type in ls3 dimensions and got my answer. You can do the same. Unless you want me to hold your hand while doing it.
Honestly it all comes down to time and money. If you got both any engine combinations is possible. Good luck. Happy googling.
Old 08-04-2018, 04:42 AM   #3
Boudin
Drives: Soon
I sent an email to Vorshlag asking this exact question as I am also intrested in doing an LT swap. I'm hoping the motor mounts are the same.
Sent from my SM-G965U using Tapatalk
Boudin is offline   Reply With Quote
Old 08-04-2018, 01:15 PM   #4
Zer0
Drives: 2015 frs
My LT4 is scheduled to arrive Monday. I will be starting the swap around the 20th after I return from vacation. I will be posting the build on my build page. I can tell you if the mounts bolt up this week.
Zer0 is offline   Reply With Quote
The Following 2 Users Say Thank You to Zer0 For This Useful Post:
Boudin (08-04-2018), DustinS (08-06-2018)
Old 08-04-2018, 05:27 PM   #5
Verl0r4n
Drives: GT86
That'd be awsome
Old 08-06-2018, 02:16 PM   #6
Zer0
Drives: 2015 frs
Bolt pattern is not going to work on the Vorshlag mounts for an LT motor. The LT pattern is taller and wider. I will get a measurement later this week. I just held it up to the block to get the will it bolt straight up or not question answered.
The Following 3 Users Say Thank You to Zer0 For This Useful Post:
Boudin (08-07-2018), Sportsguy83 (08-06-2018), wutsaiu (08-07-2018)
Old 08-07-2018, 04:26 AM   #7
rakanet
Drives: 2013
Nice build
try this mount
https://www.dirtydingo.com/shop/prod...oducts_id=1621
https://www.amazon.com/2014-up-Engin.../dp/B01FG3MVDO
rakanet is offline   Reply With Quote
Old 08-07-2018, 09:25 PM   #8
Zer0
Drives: 2015 frs
I like the idea of them but then it will raise the engine. Most likely i will make new engine side of the mounts if the crossmember side of the mount will work with where I want the engine positioned. If not I will build them 100% new, and sell the Vorshlag ones.
Old 08-07-2018, 09:29 PM   #9
Verl0r4n
Drives: GT86
Sweet, also do you have a link to where you'll be posting your build?
The Following User Says Thank You to Verl0r4n For This Useful Post:
Zer0 (08-07-2018)
Old 08-07-2018, 09:31 PM   #10
Zer0
Drives: 2015 frs
Don't know how to post a link. Member car journal (long term build)
Old 08-09-2018, 02:12 PM   #11
Zer0
Drives: 2015 frs
The LT bolt pattern measurement I got was
4 3\4" X 3 5/8" center to center on the holes. I was measuring it still on the pallet at an awkward angle, but I think it was accurate. I'm going to try to make some plates using those measurements. I will post pics of them bolted up when completed as well as any adj to my numbers.
Old 08-09-2018, 02:12 PM   #12
Zer0
Drives: 2015 frs
Old 08-09-2018, 08:35 PM   #13
Zer0
Drives: 2015 frs
I drew up the design for the plate just need to make it now.
Vorshlag plate in picture center to center on the holes is
4 13/32" X 3 3/2". That was what I got anyway.
Old 08-09-2018, 08:56 PM   #14
Zer0
Drives: 2015 frs
Vorshlag plate set on drawing. Not to far off but not enough material to modify it
Difference Between V2.076 and V4.03 NyX_Nick Software Tuning 2 06-01-2018 11:00 AM
What is the difference between.............. vmastros Scion FR-S / Toyota 86 GT86 General Forum 12 05-29-2016 08:58 PM
Think all tires of the same size ARE the same size? Draco-REX Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 09-26-2012 09:41 PM
