Old 08-04-2018, 06:42 PM   #1
Rybot
Rybot's Avatar
Drives: Subaru BRZ Series.Blue
Replacement/Aftermarket Front Sway Bar Reinforcement Plate
So after dailying my car for 4 years, there are obviously some points of wear and rust (I live in the midwest).
The one component that I really want to replace (arguably not really a critical piece, mind you) is the front sway bar reinforcement plate.
Part 10 is the one in question.
The lower section facing the ground has gotten crusty and definitely bubbled/split paint.
I was wondering if anyone has found an aluminum, or better coated replacement/aftermarket component.
I've searched around, and unless my keywords are bad at finding alternatives to OEM replacements, I can't really find anything.
I know an option is to refinish them by taking off the current rust and paint, then repaint/powder coat, but I feel like these components are some of the first under chassis parts to rust out.
Anyone got a lead?
Rybot is offline   Reply With Quote
Old 08-04-2018, 08:02 PM   #2
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
Take off stock parts, throw them in muriatic acid for an hour or two, prep for paint and then paint them. All in all you'd only be out around $30.
Trueweltall is offline   Reply With Quote
Old 08-04-2018, 08:36 PM   #3
Rybot
Rybot's Avatar
Will the acid remove just the rust and bubbled spots or is it going to strip most of the paint off?
Also, isn't there a specific "undercoating" type paint that would be perfect for places like this and inner fenders?
Old 08-04-2018, 11:49 PM   #4
Trueweltall
It'll take everything off.
Rear sway reinforcement brackets necessary? dutchman1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 03-07-2018 11:23 AM
FS: GTSPEC SWAY BAR REINFORCEMENT BRACE (REAR) andy86 Brakes, Suspension, Chassis 0 11-08-2017 01:20 PM
Does anyone have Perrin endlinks mated to an aftermarket front sway bar? loading_please_wait Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 07-22-2015 11:24 AM
WTB - OEM Sway Bar Reinforcement Plates and Stabilizer bar bolts loading_please_wait Want-To-Buy Requests 0 06-16-2015 01:58 AM
Aftermarket Front Bumper replacement THEmailman Cosmetic Modification (Interior/Exterior/Lighting) 11 04-16-2014 08:30 PM
