Old 07-09-2017, 12:21 AM   #1
dutchman1
Drives: 2017 86 6-Speed
Rear sway reinforcement brackets necessary?
I picked up a used TRD rear sway locally, but it came without the mount reinforcement plates. They seem to be oddly pricey from Toyota, and I'd have to run the stock ones to stay in street class autocross.
Are they necessary on a street/autocross driven 2017? I'll be running street tires on stock wheels, no R compounds or anything. The 2017 has a stiffer rear sway to begin with, so I imagine if there was an issue with attachment point strength it would've been rectified.
2017 86 set up for CS STX autocross
dutchman1 is offline   Reply With Quote
Old 07-14-2017, 08:23 AM   #2
dutchman1
I'm answering my own question in case anyone is wondering in the future.
Yes, you do need the reinforcement plates. The supplied bushings don't fit right without them.
The Following User Says Thank You to dutchman1 For This Useful Post:
venturaII (07-14-2017)
Old 07-14-2017, 10:28 AM   #3
norcalpb
norcalpb's Avatar
Personally I would if I had a bigger rear bar. Have you seen how the bushing brackets mount to the rear subframe? It looks like there's only 2 pinch welds on both sides of the mounting point. Once that snaps off it'll never go on the same way again.
Old 03-07-2018, 10:23 AM   #4
NJ Drive
Drives: 2016 FRS RS 2.0
Where did you find a part number for these? There isn't one listed from Toyota, and TRD has been unresponsive.
NJ Drive is offline   Reply With Quote
WTB - OEM Sway Bar Reinforcement Plates and Stabilizer bar bolts loading_please_wait Want-To-Buy Requests 0 06-16-2015 12:58 AM
GTSPEC Rear Subframe CNC Reinforcement Panels MicheleAbbate Brakes, Suspension, Chassis 8 02-04-2015 02:07 PM
Rear swaybar mount reinforcement. How important is it for 19mm bar? mike the snake Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 11-04-2013 06:50 PM
Sway Bar Mouting Brackets/Bolts Integrity sw20kosh Tracking / Autocross / HPDE / Drifting 3 01-16-2013 06:36 PM
Installing the AVO Rear Reinforcement Bracket AVOturboworld DIY (Do-It-Yourself) Guides 9 10-29-2012 11:44 AM
