Old 07-31-2018, 08:55 PM   #393
reeves
He's not lying. He will take your nice clean new slave apart even if you're not mystified. Priceless.
He had me at 'dust boot'
I'm sure they both work fine. I'm just using the OEM one until I get my clutch problem fixed.. then I'll swap it again.
Old 07-31-2018, 09:47 PM   #394
I flicked a booger in yours while you weren't looking.
Old 07-31-2018, 09:53 PM   #395
Well, looky there! I guess it is a little bit shorter outboard of the mounting holes. Meh. It's fine.
I was wrapping up at work. Now that I took a second look at home on the couch, I can see the difference. Guess I was the one fixated on the dust boot.
Old 07-31-2018, 11:49 PM   #396
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
I thought the pedal felt wookiee.
Old 07-31-2018, 11:53 PM   #397
Old 08-11-2018, 09:33 PM   #398
muffinz
Drives: 2013 DGM BRZ Ltd
So I've been living under a rock and spent the last 5 years driving my car with a stock unadjusted clutch...
Until I found this thread when I started looking for reasons why my clutch was squeaking recently (fork needed to be greased)
After reading the original post in this thread I recalled how all of my non brz/frs-owning friends that had driven my car always complained about how awful the clutch was. I immediately ordered an OEM Subaru 3/4" clutch slave cylinder and stainless clutch line.
I installed the parts, flushed the fluid and bled all the air out, and also adjusted my clutch pedal closer to the floor and I now have an amazing clutch experience. I can finally shift smoothly while feeling whats going on through the pedal. It's soooooooooooo worth doing. Just do it already. Even if you've spent 5 years and 46,000 miles driving on the stock setup like me lmao.
muffinz is offline   Reply With Quote
Old 08-12-2018, 09:17 PM   #399
Originally Posted by muffinz View Post
Just do it already.
Yay!!! Welcome to the clutch awareness club.
Old 09-20-2018, 11:56 PM   #400
jflogerzi
jflogerzi's Avatar
Anyone in SoCal wiling to help a member do this? I am not that mechanically inclined(I only do bolt on stuff) I pay in beer and food.
2013 Series 10 FRS #553
Old 09-21-2018, 10:49 AM   #401
ermax
ermax's Avatar
This is bolt on stuff though. It literally took me 5mins.
Old 09-21-2018, 11:37 AM   #402
n0thing
Drives: Subaru BRZ
https://www.rockauto.com/en/catalog/...+cylinder,2044
Any one of those will work?
n0thing is offline   Reply With Quote
Old 09-21-2018, 12:56 PM   #403
Originally Posted by n0thing View Post
You picked the correct vehicle. Can't speak to the accuracy of their database but as long as the bore of the cylinder you receive is 3/4", you're good to go.
I recommend against going super cheap. Tolerance/materials/finish all affect service life.
Old 09-21-2018, 01:20 PM   #404
Old 12-23-2018, 02:57 PM   #405
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
I think I need to do this..... cuz i spent the last 4 & half years & 67000 miles not modding the clutch...
Old 01-04-2019, 07:55 AM   #406
Legend@wheels
nenber
As it looks like it has no cons at all - im going for it!!
2 q's-
1 -The big diff is by changing the cylinder alone,right?
Changing the hydraulic line and/or removing spring is just an extra?
2 after doing that where is the most safe position(to make sure no damage will occur in the long run) for the pedal? 1:1 with the brake pedal height is ok?
Legend@wheels is offline   Reply With Quote
clutch line, slave cylinder
Clutch Engagement Improved! enjoyminutemaid Engine, Exhaust, Transmission 53 11-07-2018 06:31 PM
Can steering feel, tactility, be improved? Without sacrificing adjustability? Trettiosjuan Suspension | Chassis | Brakes -- Sponsored by 949 Racing 101 08-16-2016 08:14 PM
Aftermarket Clutch Master and Slave? Yruyur Engine, Exhaust, Transmission 5 07-27-2013 10:22 AM
Hate the feel of the clutch FRSGeek Engine, Exhaust, Transmission 18 07-10-2013 01:24 PM
Clutch feel? Shit Luck Engine, Exhaust, Transmission 5 04-21-2013 05:32 PM
