Old 07-19-2018, 08:05 PM   #1
Randomizer
Drives: Its stock nothing else....or is it?
Post Adjustable Endlinks
Okay guys give it to me straight. I bought some BC Coilovers that came with adjustable endlinks. I install the endlinks to the same length as the stock one (well close to stock). And now I want to do alittle of adjustment. So the taller endlink the softer it gets and the smaller the endlink the stiffer it gets right? Yes and No answer please. I check aeound in forum and nobody givung a straight answer.
Randomizer is offline   Reply With Quote
Old 07-19-2018, 08:52 PM   #2
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
If you're using stock sway bars I wouldn't play around with them too much. Depending on how much you are lowered the end links are used to take preload off your sway bar due to the new geometry created by lowering the car.
tyler_win_photo is offline   Reply With Quote
Old 07-20-2018, 03:42 AM   #3
DeaconRoc
Drives: GT86
No.
With the car on the ground adjust the end links so there is no preload (twist) in the arb.
Sent from my ONEPLUS A3003 using Tapatalk
DeaconRoc is offline   Reply With Quote
Old 07-28-2018, 01:48 AM   #4
Randomizer
Yes it is stock no point of getting a aftermarket since its my daily. But okay I won't touch it.
Old 07-28-2018, 01:24 PM   #5
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The reason for the endlinks is if you lower your car a bunch you risk the endlink contacting the LCA. So you can shorten it to gain clearance. There is not tuning to be done with them for performance gain.
brz, coilover, endlinks
Whiteline Adjustable Front Endlinks quiet-k Brakes, Suspension, Chassis 3 10-21-2017 02:26 AM
SPL Adjustable Rear Endlinks BNIB Akuma13 Brakes, Suspension, Chassis 2 10-12-2016 02:05 PM
FS: Whiteline Adjustable Front Endlinks Juanito08 Brakes, Suspension, Chassis 2 09-07-2016 09:42 PM
WTB. Front adjustable endlinks Fez96 Want-To-Buy Requests 3 06-24-2016 05:25 PM
Lowered car about 1.25" Adjustable Endlinks needed? Sportsguy83 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 19 07-21-2013 09:40 PM
