#15 |
Drives: 2017 Toyota 86 860 Special Edition
Thanks everyone. Lot's of good info and opinions. I'm still deciding on which fuel to run primarily. The E-85 takes a big hit on mileage and I drive about a 100 miles a day. However, it's about $0.60 cheaper... At any rate. Thanks again.
#16 |
Wise old man
Drives: 86 GTS
its not worth it if you are going to do big mileage. sorry.
your mpg will take a 30% hit. |
| The Following User Says Thank You to Surok For This Useful Post: | why? (08-09-2018) |
#17 |
Drives: Frs
i do 100 miles a day, I just fuel up every other day instead of every third day....its still cheaper for me to run e85 than 93 per mile
JDL UEL Turbo GT2860RS, AP Racing BBK, Verus Splitter/diffuser/canards, Sard rep carbon wing, TFF bash bar, HKS hi power, Tein Flex A, Hotchkiss FSB, Radium MCB, Konig Hypergram 17x8, FS Indy 500, 6k HID, Whiteline trans bushing insert, Verus AOS, grimmspeed strut brace, Racerx oil cooler w/ setrab 619, ES steering rack bushings, Whiteline subframe bushings, Toms tails, STi mirror caps, IRP shifter, TRD Steering wheel
#18 |
I did ~80 miles a day for a couple of years too when I first bought my car.. Fueled up every 2 days too on E85.
I wasn't worried about MPG though.. too busy driving the snot out of it.
#19 | |
How do I shift?
Drives: '13 GBS BRZ
Never going back to 91 unless on trips.
#20 | |
Drives: 2017 BRZ w/PP
Hate to be that guy but ethanol is pH neutral, so how is e85 acidic?
#21 |
Senior Misanthrope
I know this is an old thread, but if anyone is still concerned with long-term use of E85, this is the most recent UOA I have after using E85 for roughly 40k miles.
#22 | |
The Fail Boat
Drives: CWP S.B.
#23 |
Drives: 2023 BRZ
#24 |
Senior Misanthrope
#25 |
Drives: 2023 BRZ
Whoa, nice. I've never done an oil analysis, but change it every track weekend. Maybe I'll go longer now. I use Mobil 1, too.
#26 |
Drives: BR86
If you get the oil hot, ie: 212F, it will last longer
. . . with the proviso that the tune isn't overly rich.
#27 | ||
I'm more worried about the additives than the E85 itself ![]() I guess only time will tell... |
#28 |
Drives: 2023 BRZ
Yeahhhh... I'm pretty sure that's not a problem. My oil gets to 270 on track days.
Director of Rocky Mountain 86CUP
| Long term E85 use | redrocket89 | Engine, Exhaust, Transmission | 92 | 06-28-2021 05:40 AM |
| Long-term adverse effects of Whiteline chassis inserts? | ApexEight | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 18 | 09-07-2017 07:13 AM |
| long term and short term | brichard0625 | Engine, Exhaust, Transmission | 7 | 08-26-2013 08:56 AM |
| Fuel Trims - Long term and short term | victorb | Engine, Exhaust, Transmission | 6 | 03-27-2013 02:18 PM |
| Short Term and Long Term Fuel Trims | naikaidriver | Engine, Exhaust, Transmission | 3 | 03-18-2013 09:55 PM |
