Old 01-23-2018, 05:17 PM   #15
supercommode
supercommode's Avatar
Drives: 2017 Toyota 86 860 Special Edition
Thanks everyone. Lot's of good info and opinions. I'm still deciding on which fuel to run primarily. The E-85 takes a big hit on mileage and I drive about a 100 miles a day. However, it's about $0.60 cheaper... At any rate. Thanks again.
supercommode is offline   Reply With Quote
Old 01-23-2018, 06:48 PM   #16
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
its not worth it if you are going to do big mileage. sorry.
your mpg will take a 30% hit.
Surok is offline   Reply With Quote
The Following User Says Thank You to Surok For This Useful Post:
why? (08-09-2018)
Old 01-24-2018, 08:44 AM   #17
Submarinesonce
Drives: Frs
i do 100 miles a day, I just fuel up every other day instead of every third day....its still cheaper for me to run e85 than 93 per mile
JDL UEL Turbo GT2860RS, AP Racing BBK, Verus Splitter/diffuser/canards, Sard rep carbon wing, TFF bash bar, HKS hi power, Tein Flex A, Hotchkiss FSB, Radium MCB, Konig Hypergram 17x8, FS Indy 500, 6k HID, Whiteline trans bushing insert, Verus AOS, grimmspeed strut brace, Racerx oil cooler w/ setrab 619, ES steering rack bushings, Whiteline subframe bushings, Toms tails, STi mirror caps, IRP shifter, TRD Steering wheel
Submarinesonce is offline   Reply With Quote
Old 01-24-2018, 10:20 AM   #18
reeves
I did ~80 miles a day for a couple of years too when I first bought my car.. Fueled up every 2 days too on E85.
I wasn't worried about MPG though.. too busy driving the snot out of it.
Old 01-25-2018, 03:48 PM   #19
carsebuco
How do I shift?
carsebuco's Avatar
Drives: '13 GBS BRZ
Where I live, it ends up being same cost per mile. You fill up more often with e85, but it's priced much lower and a lot more fun.
Never going back to 91 unless on trips.
carsebuco is offline   Reply With Quote
Old 07-24-2018, 10:39 AM   #20
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
Hate to be that guy but ethanol is pH neutral, so how is e85 acidic?
Originally Posted by housecat View Post
I found a good read-up here: http://www.tundraheadquarters.com/bl...-running-e-85/
In case the link breaks, here's a copy-paste:
TLDR; E85 is acidic, hygroscopic, and more acidic when water-contaminated. Acid in the oil can hurt lubrication ability and corrode metal parts. Since the 86 isn't E85 compatible from the factory, it may not be as resistant to acid wear (citation needed). Frequent oil changes is good insurance when running E85, but likely not necessary in factory flex-fuel fitted vehicles.
From a personal experience, I can smell ethanol in my oil during an oil change. I don't have oil analysis data, but the smell is obvious. The presence of ethanol doesn't necessarily mean it hurt my car, but I'd rather be safe than sorry until we have more data about E85 reliability in the 86.
Old 08-09-2018, 04:46 PM   #21
kch
Senior Misanthrope
kch's Avatar
I know this is an old thread, but if anyone is still concerned with long-term use of E85, this is the most recent UOA I have after using E85 for roughly 40k miles.
The Following 10 Users Say Thank You to kch For This Useful Post:
alphasaur (12-18-2018), Cacophony (05-23-2019), carsebuco (08-10-2018), e30cabrio (09-01-2020), FR-S.13 (08-09-2018), Lantanafrs2 (08-09-2018), MugsBRZ (11-25-2018), Pat (08-09-2018), Teseo (07-23-2024), ZZT86 (08-09-2018)
Old 08-09-2018, 04:50 PM   #22
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Thumbs up
http://www.vpracing.com.au/product/vp-m2c try about 300ML in 1 tank of E85
I don't know why nobody clicked thank on that post. *Clicking intensify
Old 08-09-2018, 05:05 PM   #23
Pat
Pat's Avatar
Drives: 2023 BRZ
How many track days were on this sample?
Old 08-09-2018, 05:55 PM   #24
kch
Senior Misanthrope
kch's Avatar
Dunno for sure. Between 5 and 7.
Old 08-09-2018, 07:46 PM   #25
Pat
Pat's Avatar
Drives: 2023 BRZ
Whoa, nice. I've never done an oil analysis, but change it every track weekend. Maybe I'll go longer now. I use Mobil 1, too.
Old 08-09-2018, 09:59 PM   #26
ZZT86
ZZT86's Avatar
Drives: BR86
If you get the oil hot, ie: 212F, it will last longer . . . with the proviso that the tune isn't overly rich.
ZZT86 is offline   Reply With Quote
Old 08-09-2018, 11:16 PM   #27
reeves
I'm more worried about the additives than the E85 itself
I guess only time will tell...
Old 08-09-2018, 11:43 PM   #28
Pat
Pat's Avatar
Drives: 2023 BRZ
Yeahhhh... I'm pretty sure that's not a problem. My oil gets to 270 on track days.
Long term E85 use redrocket89 Engine, Exhaust, Transmission 92 06-28-2021 06:40 AM
Long-term adverse effects of Whiteline chassis inserts? ApexEight Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 09-07-2017 08:13 AM
long term and short term brichard0625 Engine, Exhaust, Transmission 7 08-26-2013 09:56 AM
Fuel Trims - Long term and short term victorb Engine, Exhaust, Transmission 6 03-27-2013 03:18 PM
Short Term and Long Term Fuel Trims naikaidriver Engine, Exhaust, Transmission 3 03-18-2013 10:55 PM
