Old 07-24-2018, 07:16 AM   #1
dstrout
dstrout's Avatar
Just camber plates and LCAs?
I am on a completely stock suspension running 225 R-S4’s. I’d like to get some camber for track days, which is the only use the car sees.
Is it reasonable to start out with front camber plates (HVT non-rising) and rear LCAs (TBD) to try for about -2 deg all around using the stock dampers and springs? I’m saving up for some MCS 2WNR’s, but that won’t be until this winter.
Thanks!
dstrout is offline   Reply With Quote
Old 07-24-2018, 07:18 AM   #2
EffaressNOOB
EffaressNOOB's Avatar
Drives: Halo 2016 Scion FR-S, 6MT
Thanks!
Camber bolts should get you close to -2 up front... and they’re cheap!
Enkei TFR (Copper) 17x9+45 | Hankook Ventus V12 Evo2 245/40 | Tein Flex A
OFT Stage 2, E85 | Kraftwerks Skunk2 CAI
Open Flash Unequal Length Header
Invidia N1 CatBack
InstaGram: 49RJ
EffaressNOOB is offline   Reply With Quote
Old 07-24-2018, 10:09 AM   #3
ZDan
ZDan's Avatar
Drives: '23 BRZ
Yeah, I'd go camber bolts up front and wouldn't bother with LCAs. Get RCE Yellows instead. Less $$$, lower c.g., more track-appropriate spring rates, and probably get you your -2° camber all around or thereabouts.
Old 07-24-2018, 12:15 PM   #4
wparsons
wparsons's Avatar
SPC camber bolts in the lower holes, stock lower bolts in the upper holes. Should get you to -2 easily. You don't want equal camber front/rear due to the suspension design (rear gains camber through compression, front does not). I'd stick with -2 front and -1 to -1.5 rear.
flickr
Old 07-24-2018, 12:45 PM   #5
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
-3F/-2R is a good starting point and be prepared to add more, yes camber plates and lcas are perfect, if you want more than -4 you'll need bolts or slotted struts.
Wparsons is right you probably don't want equal camber and it's a track only car so go ahead and get aggressive, think about the compatibility of your camber plates and eventual suspension, not all combinations work well.
ineedyourdiddly
Old 07-24-2018, 12:55 PM   #6
wparsons
wparsons's Avatar
Depending on the wheel offset, he probably can't get much more than -2*F without rubbing tire on spring perch or going to camber plates.
flickr
Old 07-24-2018, 01:06 PM   #7
ZDan
ZDan's Avatar
Drives: '23 BRZ
Equal camber front/rear is fine. WAY better than the stock 0 front -1.25 rear!
Reducing rear camber to something way less than ideal just to make it less than front camber isn't the right approach IMO...
Ideally, camber plates and -3 or more camber up front. But given that this is an interim setup anyway...
Camber bolts, lowering springs, stock rear LCAs = lotsa fun for minimal $$$
Old 07-24-2018, 06:00 PM   #8
carlovestela
Drives: 2015 Firestorm FRS
Im lowered trd springs.
-0.4 front
-2.2 rear
Stock lca and no camber bolts
carlovestela is offline   Reply With Quote
Old 07-24-2018, 06:04 PM   #9
ZionsWrath
Thanks
ZionsWrath's Avatar
I have the cam bolt, camber plates and rear lower control arms. Cam bolt alone got me -1.5 which is nowhere near enough on track
I still get edge wear, my shop recommends at least stiffer springs they said stock is too soft its stillngoing to roll over the tire edge even if they add more camber. I run 200tw tires, as I understand it would be worse with track tires.
I got a set of bilstein b8 and rce tarmac springs but never got around to installing them as the rears are cross threaded and i never ended up trying to fix or replace them.
So for nowni just deal with the edge wear.
Old 07-24-2018, 11:35 PM   #10
JMon85
JMon85's Avatar
Drives: 2019 WRX
That's what i did~ not lowered, Whteline camber bolts & rear LCA. I went -1.5 all around, no regrets. However for track day I'm sure you'll want more neg up front as memebers have stated.
JMon85 is offline   Reply With Quote
Old 07-25-2018, 05:40 AM   #11
dstrout
dstrout's Avatar
Thanks all - very helpful!
Old 07-25-2018, 12:54 PM   #12
carlovestela
Whats the recommended camber for daily?
Old 07-25-2018, 02:52 PM   #13
wparsons
wparsons's Avatar
Stock specs...
Depends on what you're after. Running too much rear camber compared to front will make it understeer more and can (and likely will be) slower than taking a bit of rear camber out to have it rotate better.
flickr
Old 07-25-2018, 03:18 PM   #14
ZionsWrath
Thanks
ZionsWrath's Avatar
OEM camber bolt would be fine on a DD. Depends on your driving style though? Do you get even tire wear at stock specs (no camber)? If so adding camber will shorten the life of your tire in the form of inside edge wear.
It might be worth it for you, but that is an individual decision and why stock is 0 camber.
Which LCAs for decent amount of camber? sqd Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 06-04-2015 06:36 PM
FS: HVT Non-raising camber plates & WL camber bolts trippinbillies40 Brakes, Suspension, Chassis 1 05-16-2015 10:00 PM
Best bang for the buck camber bolts and rear LCAs? BRZZZZZZZZZZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 02-20-2014 10:17 AM
Question about adjustable LCA's vs Camber Plates vs Camber Bolts djdnz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 03-28-2013 12:38 AM
